Vleds V6 Triton Extreme Amber light output concerns
Discussion in 'Lighting' started by arcticrobot, Oct 11, 2019.
  1. Oct 11, 2019 at 7:04 AM
    arcticrobot
    arcticrobot [OP] Well-Known Member
    2017 TRD Sport manual
    Hi guys. I am looking into getting my front turns a bit more visible. Looking at Vleds V6 Triton Amber (700 Lumen) and Extreme Amber (1400 Lumen).
    https://www.vleds.com/shop-application/turn-signals-front/7440.html
    Owning 1000 lumen mtb helmet light I know that thing just fries incoming traffic. Not sure how Extremes light output is directed and if it isn't too much.
    Does anybody know the light output of stock lights or runs 700 and 1400 lumen versions and can compare?
    Thank you.
  2. Oct 11, 2019 at 7:08 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    arcticrobot[OP] likes this.
  3. Oct 11, 2019 at 7:14 AM
    arcticrobot
    That is a good insight, thank you Andrew. I will look into that.
  4. Oct 11, 2019 at 8:07 AM
    rj_taco
    rj_taco Well-Known Member
    Keep in mind that unless stated, those numbers are raw led lumens. Out the front lumens drop with lenses and heat, not unusual to see a 30% drop in lumens or even more (40-50%) for bulbs that disperse the light using optics.
  5. Oct 11, 2019 at 8:11 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    still, even the 700 lumens is going to be noticeably brighter, and a much more color saturated light output than stock. I have the earlier version of these, and am happy with them.
  6. Oct 11, 2019 at 8:21 AM
    rj_taco
    Yes, I agree. I have a set of the V6 triton, plenty bright.
