Visual Backspace Explaination - Simple Drawings of 5 wheels w/ different backspacing
Discussion in 'Wheels & Tires' started by Cape Codder, Apr 15, 2012.
  1. Apr 15, 2012 at 5:55 PM
    Cape Codder
    Cape Codder [OP] Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    As I'm no pro, I drew these up for myself to grasp the concept a little better.
    Thought I'd share 'em with others trying to understand Offset and Backspacing.
    I chose 3 wheels (now 5) that had good variations in Backspace, to make the visual differences, obvious.
    EDIT: 2014/06/15 - Added Two New Drawings of:
    Stock TRD Sport Wheel (5.5" B.S.) w/1" Spacer to Equal 4.5" Backspace
    Konig SixShooter 17" x 8" / 4.55" Backspace / 0mm Offset
    The top markings for fender and sidewall are for comparison purposes only.
    They are guesstimates and NOT TO SCALE, though they are measured the same in each picture.
    Centerline = Center of Wheel Width (not diameter)
    Wheel Width = Distance in Inches Between INSIDE Edges of Rim Flanges
    Offset = Distance in Millimeters (Positive or Negative) from Centerline of Wheel to (Hub) Mounting Surface
    Backspace = Distance in Inches from (Hub) Mounting Surface to OUTSIDE Back Edge of Rim Flange (back being towards Axle)
    Take note of the measurements to the INSIDE and OUTSIDE edges of the Rim Flanges (The overall Width of an 8" Wheel is 9")
    Hashed Blue Line = Mounting Surface
    Rim: Flat Circular Band Attached to the Outer End of the Spokes or
    to the Outer Circumference (Perimeter) of the Disk of a Wheel (if Solid not Spoked).
    It is Part of a Wheel, NOT THE Wheel! :frusty: Probably not the place, but I had to Do it :smack:
    Think I got it all right.
    I'm sure I'll be corrected if wrong, and I'll edit the OP as needed.
    See EDITS @ End of Post
    A Picture's Worth 1000 Words.
    Hope some of You find 'em useful
    3 Different Wheels in one Pic and the same 3 Individually:
    Stock TRD Sport 17" x 7.5" / 5.5" Backspace / +30mm Offset
    Added: Stock TRD Sport 17" x 7.5" / 5.5" Backspace / +30mm Offset w/1" Spacer,
    Effectively changing the Specs to 4.5" Backspace / 5mm Offset
    Enkei ST6 17" x 8" / 4.88" Backspace / +10mm Offset
    Konig Countersteer Type "X" 17" x 8" / 4.1" Backspace / -10mm Offset
    Added: Konig SixShooter 17" x 8" / 4.55" Backspace / 0mm Offset
    Stock TRD Sport Wheel 17" x 7.5" / 5.5" Backspace / 30mm Offset:
    Stock TRD Sport Wheel 17'' x 7.5'' / 5.5'' Backspace / 30mm Offset
    But with 1'' Spacer = 4.5'' Backspace / 5mm Offset
    Enkei ST6 17"x8" / 4.88" Backspace / 10mm Offset:
    Konig Countersteer Type X 17" x 8" / 4.1" Backspace / -10mm Offset:
    Konig SixShooter 17'' x 8'' / 4.55'' Backspace / 0mm Offset
    Copied the following here (TacomaWorld) somewhere, wish I could give credit, but don't remember the OP
    EDIT: OK Strike That.
    After Extensive Searching I found that:
    I followed a link, Posted by OZ-T to Here: Mickey Thompson Performance Tires & Wheels
    Therefore this is required:
    Copyright © 2012 Mickey Thompson Performance Tires & Wheels
    TO CONVERT OFFSET TO BACKSPACING:
    For positive offset wheels: (Wheel Width +1)/2 + (offset * .03937)
    For negative offset wheels: (Wheel Width +1)/2 - (offset * .03937)
    TO CONVERT BACKSPACING TO OFFSET:
    Backspacing – (Wheel Width + 1)/2 * 25.4 = offset
    EDIT Continued: During said Search, I kept finding this link also, Posted by numerous Members:
    https://www.rsracing.com/tech-wheel.html
    And last night, benright Posted the following link to a nice "Wheel / Tire Size Comparer" including Offset. Very Useful:
    http://www.rimsntires.com/specs.jsp
    CC
    JoshS, SR-71A, TRDSport10 and 3 others like this.
  2. Apr 16, 2012 at 5:47 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    *clap, clap, clap, clap*
  3. Apr 16, 2012 at 6:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    +1 CC
    lol...I made a similar thread on another site.
    Now we just need to get the n00bs to read it and thats gonna be hard because it's not in 2nd gen :D
  4. Apr 16, 2012 at 3:55 PM
    Cape Codder
    Jack
    Had to Edit the End of the OP with Credits and added a couple links
    Is this where I take a Bow ;)
    BTW: I've read numerous posts by you
    Do You rattle those figures off the top of your head
    Or do you carry a Wheel Spec book around with You?
    Thanks for the Applause
    Thanks, I understand Your point completely
    I guess this means I've finally shed my "n00bie skin", because I had the sense to post this here.
    Another indication might be, I'd rather post info (limited, though it may be) than questions
    Thanks again
    CC
  5. Apr 16, 2012 at 5:49 PM
    TexasTacoma37
    I have most of the measurement combinations that are commonly used on tacomas memorized, just from pure repetition.
  6. Apr 21, 2012 at 6:58 AM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    From a very new noobie. Thanks for the time you put into this post with the drawings. It answered two of my questions.
  7. Apr 22, 2012 at 6:02 PM
    Cape Codder
    Jack
    Glad you were able to make use of it.
    And Good Job, :thumbsup: for searchin' the right Forums.
    CC
  8. Jun 1, 2012 at 11:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this should be a sticky!
  9. Jun 1, 2012 at 2:14 PM
    Cape Codder
    Jack
    Thanks for the vote, I didn't think it was that good.
    Did keep it simple for others like me.
    You'll have to start the petition, though. ;)
    CC
  10. Jun 2, 2012 at 10:13 AM
    phantomblackgto
    phantomblackgto Well-Known Member
    Martin
    Parkville, MO
    2012 MGM TRD Sport 4x4 DCSB
    TRD exhaust, Debadged, Tacoma door sill protectors, Weathertech DFL's, Twoplankers center console organizer, Escort S2 cordless radar detector, AFE Pro Dry S air filter, Ultra Type 62 wheels 17x8 et +10 w/ 108mm - 106.1mm hubcentric rings, 265/70/17 Goodyear Wrangler Duratracs, Bilstein 5100's - front set to .85, Nfab 2" step bars w/ LineX coating
    I 2nd the sticky. Best illustration I've found, and I did a lot of searching. Calculating is one thing, but seeing the illustrations side by side really brings it together. Great job!
  11. Jun 2, 2012 at 11:12 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    great job!
  12. Jun 3, 2012 at 5:39 PM
    Cape Codder
    Jack
    My lady tells me, all us guys are visually oriented :spy:, hence the pictures worth a 1000 words
    Thanks
    Thank Ya
    CC
  13. Jun 19, 2013 at 8:13 PM
    Cape Codder
    Jack
    Taking another opportunity to bump this from page 50 for some of the new members.
    I'm sure they're looking in the correct thread, for this kind of info. ;)
    CC
  14. Jun 19, 2013 at 8:21 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    ^Mods need to make it a sticky or combine it with other threads with similar information.
    Good info
  15. Jun 24, 2013 at 5:55 PM
    Cape Codder
    Jack
    Thanks, I made it simple enough for me to understand :D
    Want to add a few more wheel variations, when time permits.
    I'll just bump it occasionally
    CC
  16. Jun 16, 2014 at 7:45 PM
    Cape Codder
    Jack
    Updated the OP with a couple of new Wheel Diagrams.
    - Stock TRD Sport Wheel 17" x 7.5" / 5.5" BS / 30mm Offset with a 1" Spacer changing it to 4.5" BS
    - Konig SixShooter 17" x 8" / 4.55" BS / 0mm Offset
    Thought the Specs would round out and compliment the original drawings
    Hope you find 'em helpful
    CC
  17. Mar 12, 2015 at 4:55 PM
    Cape Codder
    Jack
    For the newer guys & gals, with the need to know
    CC
  18. Nov 7, 2015 at 2:49 PM
    Cape Codder
    Jack
    Back to the top for new members
    CC
  19. Apr 28, 2018 at 6:06 PM
    Cape Codder
    Jack
    To The Top
    CC
  20. Apr 29, 2018 at 2:23 AM
    DrFunker
    DrFunker Well-Known Member
    This is not stickied huh?
