Vision Off-Road Creep & Se7en | Customizable/Removable Ring Included!
Discussion in 'Discount Tire Direct' started by Discount Tire, Apr 17, 2018.
  1. Apr 17, 2018 at 1:15 PM
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    With an impressive collection of wheels for a number of different uses and applications, Vision is focused on offering drivers the top premium wheels for any vehicle. Introducing the Vision Creep and Vision Se7en - which feature a detachable aluminum bead ring (not actual beadlock) that can be customized! Rock Rash rivets and bolts made of high-grade stainless steel are also included with finish options ranging from satin bronze to satin gray (varies by model).
    Click here for Vision Creep Availability and Pricing online through Discount Tire Direct
    Also available in-store by special order HERE
    Click here for Vision Se7en Availability and Pricing online through Discount Tire Direct
    Also available in store by special order HERE
    -BENEFITS & FEATURES-
    • Detachable aluminum bead ring
    • Bolt-in cap included
    • TPMS Compatible
    • Popular 5, 6 & 8-lug fitments
    • Rock Rash rivets and bolts are made of high-grade stainless steel
    • Available for stock and leveled/lifted applications
    • Low-pressure single-piece construction
    -WARRANTIES & RATINGS-
    • Lifetime warranty on the structure of the wheel to be free from defects in workmanship and materials.
    • 1-year warranty on finish
    • Load capacity:
      -5 lug: 2,500 lbs
      -6 lug: 2,500 lbs
      -8 lug: 3,650 lbs
