Vision HD 85 Soft 8??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justdoit, Apr 6, 2017.
  1. Apr 6, 2017 at 8:04 AM
    justdoit
    justdoit [OP] Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
  2. Apr 6, 2017 at 11:52 AM
    ClayCole
    ClayCole Member
    4cyl 2.7L 2TR-FE
    I just have factory wheels, but looking at the width and backspacing of factory wheels here:
    http://www.partsgeek.com/gbproducts...lUABi_QNASa01mS7FDwaAudr8P8HAQ&ad=47433949212
    It looks like factory wheels are 7" wide with 5.5" backspacing, meaning the center line of the tire is offset inboard about 2.0" from the wheel mounting surface with the factory wheels.
    The black steel wheels you posted are 8" wide with 4" backspacing, meaning the center line of the tire is approximately inline with the wheel mounting surface, so your tires will stick out about 2" more than if they were mounted on factory wheels. Obviously if you put wider than factory tires on, half that width is added to sticking out from the fenders as well. Seems like a reasonable choice if you don't mind them sticking out slightly, you could get some 4.5" or 5.0" if you want less sticking out.
    Cheers.
  3. Apr 6, 2017 at 12:33 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Make sure they clear the calipers
    Edit: ah, they are 17's
  4. May 24, 2019 at 8:46 AM
    Marco Aasterud
    Marco Aasterud The Reaper
    Marco
    Oceanside California
    2001 Toyota Tacoma TRD Off-Road Black INSTA: @thereaper01trd
    -CB radio -K&N performance air intake -Toyota FJ60 Inclinometer -FJ80 Grille Swap -'00 4Runner center console swap -Bushwhacker fender flares -Relentless Off-Road bumper -Pro-Comp wheels
    Im about to purchase these same wheels. did they end up working?
  5. Aug 8, 2023 at 11:17 AM
    hpalej
    hpalej New Member
    2017 Tacoma TRD OR
    I just got these wheels on my 2017 Tacoma TRD OR. They're 16" with do not clear the caliper and I painted them so I couldn't return. I first got 1" spacers but I didn't like how much they stuck out past the fender so I ordered 1/2" shims to try next.
  6. Aug 8, 2023 at 11:43 AM
    Taco401
    Taco401 Member
    Luke
    2011 Sport MGM DCLB
    Weathertech Rain Guards
    At least the Force is strong with your center caps. Good luck with the 1/2" shims, hope it works out for you... The wheels look good!
