Vibration Goes Away While Taking Left Curves at 55mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma665, Jul 17, 2017.
  1. Jul 17, 2017 at 6:50 AM
    tacoma665
    tacoma665 [OP] Well-Known Member
    Wisconsin
    2001 DCSB SR5 4x4 Lunar Mist 2009 DCSB SR5 4x4 Black
    I recently noticed at about 55 mph, when I went around left curves the truck "smooths" out. There is a slight vibration felt in the seat when going straight or going around right curves. It is not real noisy just a slight vibration. I am thinking a right side wheel bearing is bad. Not sure if it would be front or back. Will jack up both to check wheel play. Any other thoughts or theories? Truck has 136,000 miles on it with no record of any wheel bearing replacements before I bought it.
    ChadsPride likes this.
  2. Jul 17, 2017 at 6:55 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob front wheel bearing, could be driveline related also...ujoint or center bearing.
    ChadsPride and BassAckwards like this.
  3. Jul 17, 2017 at 6:58 AM
    Lthompson
    Lthompson Well-Known Member
    is it possible a left side tire is out of balance?
  4. Jul 17, 2017 at 7:10 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Front left wheel bearing I'd think. Taking the turn removes the load from the left wheel.
  5. Jul 17, 2017 at 8:59 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I had a similar problem. I had vibes except when I turned left. It was the front passenger wheel bearing. BamaToy fixed me up. It's an easy job with the right tools.
    My wheel bearing failed at 20,000 miles.
    Alexely999 and ChadsPride like this.
  6. Jul 17, 2017 at 7:22 PM
    TacoGold
    TacoGold Well-Known Member
    Peter
    Austin, Texas
    2010 DCSB TRD OR
    Working towards an overland build
    Sounds like what I fixed by replacing the wheel bearing/hub with this:
    http://www.marionbumper2bumper.com/...-Lexus-GX470-2010-2015-Lexus-GX-460-p70724306
    On TW:
    https://www.tacomaworld.com/threads...-ive-done-the-work-you-save-the-money.288282/
    Was only noisier on the the drivers side (unless turning) but I replaced both sides and it was fixed.
    But yeah, I'd guess it's your bearing. I replaced the whole thing because it wasn't terrible expensive and I didnt have the pullers or press to replace the bearing only.
  7. Jul 17, 2017 at 8:06 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    ANother vote for bad wheel bearing.
  8. Jul 18, 2017 at 5:06 AM
    tacoma665
    Wisconsin
    I jacked up the front end and there is no wheel play in either of the front tires. The passenger tire sounds louder when I hand spin it vs the drivers tire. Not sure if that is bearing noise or the brake pads touching.
  9. Jul 18, 2017 at 5:26 AM
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    It's been my experience the wheel bearing that's loaded in the turn goes silent . As in , if a left turn silences the noise , it's the right bearing .
  10. Jul 18, 2017 at 7:20 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    That's my truck also, very whiny except for left turns. I have a new hubs, gusseted spindles and a big brake kit waiting for a free weekend to install.
