Vibration after Rotation and Alignment
Discussion in 'Technical Chat' started by afd23a, May 13, 2009.
  1. May 13, 2009 at 8:20 AM
    afd23a
    afd23a [OP] Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Got my tires rotated and balanced along with a front end alignment last week. Now I'm getting a lot of vibration through the steering wheel when above 30 or so. The shop tells me this can happen when rotating tires on vehicles with a solid rear axle. That the rear tires can have wear patterns that you don't feel until they are rotated to the front. The shop said they would take a look at it again for no charge. It had been about 8k miles since the last tire rotation, which I guess is a little long.
    Anybody else ever have this problem and what do you do to prevent it from happening?
  2. May 13, 2009 at 8:29 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I would have the balance checked again.
  3. May 13, 2009 at 8:46 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    like jester243 said have the balance checked
    unless the tires are that bad
    you can find this out by running your hands over the tires
    feeling for high low spots but the shop should have picked that up
    and said somthing :D
  4. May 13, 2009 at 9:01 AM
    Jester243
    Dan
    Spokane, WA
    You can try to have them force balanced.
  5. May 13, 2009 at 10:01 AM
    afd23a
    The Dynamo of Dixie
    They definitely should have said something if the tires themselves are really bad. It was done at a tire shop, you'd think they would take any opportunity to try to sell me new tires.
  6. May 13, 2009 at 10:02 AM
    afd23a
    The Dynamo of Dixie
    Thanks, I'm reading up on that since you mentioned it.
  7. May 14, 2009 at 7:52 AM
    afd23a
    The Dynamo of Dixie
    Ok, so I found the website for the Hunter GSP9700 and found a shop (from the same chain as before) in my area with one. Went this morning and had the tires rebalanced. The rears were a little off, but the fronts were right on. I watched the guy do it and he even hand torqued the lug nuts. He said there was a little irregularity in the wear pattern and there was 1/32nd difference between the outer and inner depths. I didn't get to drive it too much before I got to work, but it seems much better. I even got compliments on my truck from the tech.:D
  8. May 14, 2009 at 7:57 AM
    David Tarantino
    N.J.
    08 tacoma
    keep us posted let us know how it is on the ride home :D
  9. May 14, 2009 at 8:15 AM
    Jester243
    Dan
    Spokane, WA
    Hope it resolved your problem, let us know :thumbsup:
  10. May 14, 2009 at 10:13 PM
    afd23a
    The Dynamo of Dixie
    I drove it home and then out to my parent's house, so around 80 miles total round trip on the interstate. Much better. It seems to have fixed the majority of the problem. The steering wheel would wobble around 2 inches from left to right around it's circumference. As if you were turning very quickly back and forth from left to right. This is almost completely gone. There is still a little of that and a little drift, but it seems to vary with the condition of the road and it doesn't start at 30 mph.
    I highly recommend finding a shop with a road force balance machine when getting your tires balanced. :thumbsup: Thanks for the help David and Jester. It saved me from going back to the same shop, which I don't think would've solved the problem. They had told me the same thing on another vehicle I used to have before the Tacoma. I don't think I'll be going back there any more.
