Viair onboard air compressor wiring for Auxbeam switch panel help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blazer25l0, Dec 28, 2021.
  1. Dec 28, 2021 at 3:54 AM
    Blazer25l0
    Blazer25l0 [OP] New Member
    2017 Tacoma TRD Sport
    3/1 lift. Custom bed rack. Auxbeam switch panel.
    I need some help. I'm not the greatest at wiring. I've got a Viair compressor that I dont know how to wire it to my auxbeam switch panel. The compressor pulls a max of 23 amps. He auxbeam panel has 2 30 amp connection spots available. So I know the switch panel can handle the amp draw. Just don't know how the compressor and pressure switch connector up to the control box. Any help would be greatly appreciated.
  2. Dec 28, 2021 at 4:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Will the switch just disconnect power to the compressor to keep it from running when you don`t want it to??
    All you need do is break the circuit from the compressor to the power source with the proper circuit protection in the circuit.
    The pressure switch does the same thing opens the circuit for the motor.
    If you need a Schematic drawn send me a PM
  3. Dec 28, 2021 at 4:29 AM
    Blazer25l0
    A diagram would be very helpful to me .
  4. Feb 10, 2022 at 7:14 PM
    Electrify135
    Electrify135 Trd offroad
    Tony
    2020 trd off road
    Interested in seeing how this panned out and how you mounted it
  5. Feb 11, 2022 at 6:02 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    same, at 23 amps you would need a remote switch and relay setup.
  6. Feb 11, 2022 at 6:46 AM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Saw this vid a while back.
    https://youtu.be/jsRGuHM7ffA
    Iqudayo and Norsemanvike like this.
  7. Feb 11, 2022 at 7:08 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    This is a great idea. I have a BlueSea in that spot, but there should be another spot in the engine compartment to accommodate.
  8. Feb 11, 2022 at 7:34 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    I think same area but passenger side of engine bay
    Norsemanvike[QUOTED] likes this.
  9. Mar 3, 2025 at 10:17 AM
    JFiske
    JFiske New Member
    Colorado
    3rd Gen 4Runner
    Curious to bring this back... I have a Vivitar compressor and Auxbeam switch panel. I wanted to assume that, like adding lights, I can just plug the negative and positive lines into another switch position in the Auxbeam fuse box and call it a day.
    I did just this and I seem to get no power when I switch it on from the Auxbeam panel.
    What might I be missing?!
  10. Mar 3, 2025 at 11:01 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I don't have the Auxbeam but I believe the first obvious question is did you use either of the 2 button locations that can support up to 30 amp draw? There are only 2 out of 8.
    Also what gauge wiring did you run from the Auxbeam to the inflator?
  11. Mar 7, 2025 at 3:49 PM
    JFiske
    JFiske New Member
    Colorado
    3rd Gen 4Runner
    That is a great question... all spots looked the same with just select fuses that can be changed and 30a relays in all positions. I'll have to double check the gauge of wire, but it's the wire that is already installed in the compressor that normally has the battery clamps.
