VIAIR 300P Engine Bay Mounting & Hardwiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Technique, May 10, 2022.
  1. May 10, 2022 at 9:18 AM
    Technique
    Technique [OP] Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    The VIAIR compressors seem to be very popular but I could never find a mount to purchase for it nor any guides on how to make one. With mounting in the engine bay, I also decided to hardwire it and put a switch inside the cab as well as run the air hose to the rear of the truck.
    This isn't a true step-by-step guide, but I wanted to share what I did so others who were in the same boat had something to go off of.
    Parts list
    I started out using some cardboard to create the template to cut my sheet metal and mark the holes for mounting. Then proceeded to cut the sheet metal to size and threw on some paint for the hell of it.
    Here is the compressor installed on the mount.
    Once the compressor is installed to the mount, I went and secured it into the engine bay as seen below. I mounted it in the top left corner as there were 3 pre-threaded mounting points. I also used a 90-degree connector to send the hose straight down.
    Mounted the air hose in the rear next to the license plate. It's a bit off-center because I mounted it up behind a piece of metal to make it sturdier.
    Next up is wiring. This part took me a minute to figure out but finally understood how relays and all that fun stuff worked.
    I snipped off the ends of the stock compressor wiring so it could be wired to the relay/ground.
    The 40A inline fuse cable goes from the battery to the relay. Stock compressor positive wiring goes to the relay, ground goes to ground. Then a 16-18awg wire goes from the relay to your switch inside the cab and that's pretty much it.
    Pretty happy with how it turned out. $15 for the metal to make the mount, $15 for the switch, $6 for the relay and used wire I had laying around. Beats paying $150 for the premade mounts. Hope this helps those who are in the same boat I was!
  2. May 10, 2022 at 10:28 AM
    caribe makaira
    Caribbean, Puerto Rico
    Finn-2187, Skydvrr and BriceP07 like this.
  3. Jun 10, 2022 at 12:45 PM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    nice, thank you
    Technique[OP] likes this.
  4. Jun 10, 2022 at 12:52 PM
    metalmule
    metalmule Well-Known Member
    21 DCSB
    thanks
  5. Jun 10, 2022 at 7:46 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Great job
  6. Jun 11, 2022 at 4:49 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Any concerns with the air compressor and heat from the engine compartment?
  7. Jun 11, 2022 at 6:10 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sweet. Maybe I should mount mine up there as well.
  8. Jun 11, 2022 at 8:00 AM
    Technique
    Alex
    Utah
    I don't think so. People have been mounting ARB compressors in there since the dawn of time. Time will tell.
    willtill[QUOTED] likes this.
  9. Jun 11, 2022 at 11:20 AM
    scouterjan
    Jan
    So far I just keep mine in the bag it came in. I don't off road very often so for now I just hook it up when I need it, but that's a convenient way if you use it a lot
  10. Jun 11, 2022 at 12:24 PM
    Technique
    Alex
    Utah
    I don't use my a lot, but I just needed more space in the cab, lol. And I liked the idea of having it ready to go whenever, not having to take it out of the bag and hook it up, pop the hood etc etc.
  11. Jun 11, 2022 at 6:40 PM
    metalmule
    21 DCSB
    This is a great reason to mount a compressor, saving space is a plus but you can also do neat stuff like this
    soundman98 and Spadi_5 like this.
  12. Jun 11, 2022 at 8:36 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I see we had the same idea :cheers:
    Technique[QUOTED][OP] likes this.
  13. Feb 27, 2023 at 8:41 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Any updates on how it’s holding up? I have a 450P that I was planning on mounting much like you did but I found that the P isn’t meant to be in the heat/moisture/dust where the C is built to be mounted in places like under the hood. I see you have a P series, is it doing ok under the hood?
  14. Feb 28, 2023 at 1:19 AM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I have an ARB mounted under my hood, the non-portable version. Did you mean to quote @Technique?
  15. Feb 28, 2023 at 5:35 AM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    Most likely…sorry!
    ktbell444[QUOTED] likes this.
  16. Feb 28, 2023 at 6:52 AM
    Technique
    Alex
    Utah
    Yep! It's still workin like a charm.
    TacoGeeloor[QUOTED] likes this.
  17. Feb 28, 2023 at 6:56 AM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    Awesome thanks
  18. Mar 6, 2024 at 2:50 PM
    cwk84
    cwk84 Active Member
    2019 TRD OFF-ROAD
    Lift and tires
    How did you connect to the relay?
  19. Mar 8, 2024 at 6:48 AM
    Technique
    Alex
    Utah
    cwk84[QUOTED] likes this.
  20. Mar 8, 2024 at 3:24 PM
    cwk84
    cwk84 Active Member
    2019 TRD OFF-ROAD
    Lift and tires
