VHT nightshades ruined my day
Discussion in 'Lighting' started by Rd515, Jun 3, 2012.
  1. Jun 3, 2012 at 9:14 PM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    TRD Sport magnetic grey
    Window tint, painted badges, 17X9 procomp 7032, 275/75/17 Firestone destination AT
    Decided to tint my tailights this weekend. Looked up the thread "how to tint your tailights the right way." Followed it to a T (except for using gasoline to clean the light)
    After putting on the nightshade and cleat coats, I noticed a bunch of little cracks. They were extremely noticeable when lit up. I began wet sanding the paint and nightshade off, thinking that the nightshade didn't stick well (causing a cracked look...)
    But I got the nightshade off, and all the cracks were still there. Tailights ruined.
    Anyone had a similar problem. Calling the company tomorrow
  2. Jun 3, 2012 at 9:15 PM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    Has anyone*
  3. Jun 3, 2012 at 9:16 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    we need pictures
  4. Jun 3, 2012 at 9:16 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Yup. one of my friends did it to his third brake light and parking lights. got all cracked like what you said.
  5. Jun 3, 2012 at 9:18 PM
    Zimaura
    Zimaura Well-Known Member
    Nj
    San jose, CA
    05 4x4 Double Cab. level Kit, 33 inch BFGs
    Level Kit, 16inch Moto Metals, 33 BFGs, Flowmaster, tinted taillights, silver billet grills
    Damn that sux bro.
    Dont know exactly how the procedure goes, but whats wrong with the regular old autozone spray on tints? (Lens tint i think they are called... iirc)
    Got em on my tails...
    No problem whatsoever.
    No cracks no fading, and still looks clean.
  6. Jun 3, 2012 at 9:19 PM
    Zimaura
    Nj
    San jose, CA
    Also cheap.
    I think it cost me $5???
    Cheapest and fastesy mod ive done. Lol
  7. Jun 3, 2012 at 9:27 PM
    06TACOFIREMAN
    06TACOFIREMAN BaNgArAnG
    Caleb
    Alabama
    2002 Tacoma TRD offroad
    toytec 2in lift, 2nd gen trd offroad wheels, yakima roof rack, tool box, magnaflow muffler in the mail
    thats what i was about to say. that happened to me my first time trying my 3rd brake light. i didnt sand enough and coated it too thick. cracked like hell
  8. Jun 3, 2012 at 9:28 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did you clean it with gas? Gasoline is a nasty solvent and eats most anything.
  9. Jun 3, 2012 at 9:31 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Too bad the lights are ruined. I'm guessing the gasoline on the plastic lens covers might have something to do with the cracks. From what I've seen gasoline will melt or damage certain plastics. Good luck finding a fix.
  10. Jun 3, 2012 at 9:34 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ yep...i've had the same thing happen useing too heavy of a coat of spray paint. Also, too much clear coat will do the same thing to the paint underneth...better off with a few light coats than one heavy one.
  11. Jun 3, 2012 at 9:36 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm guessing not enough wait time to let the VHT tack before adding another coat.
  12. Jun 3, 2012 at 9:41 PM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    I have a spare set of tail lights. Where in California are you?
  13. Jun 3, 2012 at 11:54 PM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    I'll upload pictures tomorrow.
    I did not use gasoline to clean the tailight. I did not put a thick coat on.
    I think it was the wait time as mentioned above. I did 1 coat with VHT, them waited 20 mins and did 3 clear coats.
    Nonetheless, how will this cause cracks in the plastic? I can understand the paint causing a cracked look. But cracking the actual plastic?
  14. Jun 3, 2012 at 11:57 PM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    I actually already bought another pair. Did the process a little differently, turned out A LOT better
  15. Jun 3, 2012 at 11:58 PM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    Extremely helpful.
  16. Jun 4, 2012 at 12:00 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    must have been some sort of chemical reaction causing the plastic to crack. what did you use to clean the tail lights off with?
  17. Jun 4, 2012 at 3:28 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I can almost assure you you put too many coats on or applied it too thick. Also I would NEVER in a bazillion years use gasoline to clean ANYTHING. It's way too harsh for plastic. Next time just use rubbing alcohol.
  18. Jun 4, 2012 at 7:06 AM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    Simple green. Never would've thought that could cause a chemical reaction
  19. Jun 4, 2012 at 7:10 AM
    Rd515
    Rd515 [OP] Member
    Ricky
    California
    I used one light coat of the VHT. Held the can 6 inches away, passed over the tailight with 6 sweeps, no overlap. I did not want the lights to be dark at all, just a light tint.
    I didn't use gasoline to clean the light.
  20. Jun 4, 2012 at 7:14 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    why aren't all you tinted tail lite guys near me? I need some new front end parts and could use some extra cash. Nothing like rear ending someone and having them be the ones at fault for once.....
