very loud squeal at cold start up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tinker2, May 17, 2011.
  1. May 17, 2011 at 7:45 PM
    tinker2
    tinker2 [OP] Well-Known Member
    East Of The Big River
    When I start my truck after setting over night it squeals very loud. I think it is a pulley or the tensioner or the alt. are any of these parts covered under the power train warranty?
    I searched and couldn't find anything, maybe I didn't word it right.
    Thanks for any feedback.
  2. May 17, 2011 at 7:55 PM
    medic2230
    Murph
    Bama! Roll Tide
    Have you washed the engine or sprayed anything on it where it could have gotten on the belts? Could just be that the belts are loose.
    whatstcp likes this.
  3. May 17, 2011 at 7:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    tighten or replace the serpentine belts.
  4. May 17, 2011 at 8:08 PM
    tinker2
    No haven't washed the engine or done anything, it just started this a few days ago. The truck only has 55,000 miles on it, I can't imagine the serpentine belt could be bad already ?
  5. May 17, 2011 at 8:21 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    I've got a weird squeal / grinding noise on start up sometimes. Took to dealer and of course they could not duplicate the problem. :mad:
  6. May 17, 2011 at 8:31 PM
    tinker2
    I don't think you can tighten the belt on these thrucks, auto tensioner.:notsure:
    Mattsyota529 and tommie594 like this.
  7. May 17, 2011 at 8:32 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    As stated before, it's most likely the serpentine belt. The best way to test this is when you first start it up spray the belt with wd-40 or brake cleaner anything that lubricates will work, if the squealing goes away it's the belt, if not then it's a bearing somewhere.
    That's correct.
    tommie594 likes this.
  8. May 17, 2011 at 8:38 PM
    tinker2
    Thanks, I'll try that.
  9. May 17, 2011 at 8:54 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I've pretty much tried everything on mine and it still squeks. I've given up truing to fix it. I just let it warm uo for a few and it goes away.
  10. May 17, 2011 at 9:35 PM
    Greg337
    Greg337 Member
    I think I may have experienced the same squeal. It was during a week brutally cold -10 to -15 days. The battery had a bit of a struggle at each start and when the engine fired up it there was a loud squeal that occurred for 1 or seconds and abruptly stopped. I waited for 10 of the longest coldest minutes of my life to let the engine temp warm up enough to register on the gauge before setting off each time. My truck is about a year old and has less than 10K miles so I am pretty confident that there isn't any wearing out. I have no idea where the sound came from and it stopped once the temperature warmed up so... I dunno?
  11. May 17, 2011 at 9:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    It was the belt. The cold will do that to the rubber.
  12. May 18, 2011 at 12:20 PM
    tinker2
    Update: I just got a chance to look over the belt and pulleys. When I started the engine it was squealing, shut off engine and put a socket and ractchet on tensioner and worked it back and forth, restarted engine still squealing, turned off engine. Gave the inside of the belt a little shot of deep creep and the squeal went away, looks like its the belt.
    Thanks for all the replys. :yay:
    CowboyTaco and pungu01 like this.
  13. May 19, 2011 at 6:37 PM
    NelsonTacoma
    Tucson, AZ
    Glad to hear you got it figured out!!! :D:D:D:D:D:D:D
  14. May 19, 2011 at 9:42 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    When I cold start below 10 degrees I get a quick squeal (even when new). It's the property of the belt material.
  15. Sep 6, 2013 at 2:21 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have had the same problem twice (110k miles ) and in both cases a new belt resolved the issue. I could spray a silicon based lube on the inside of the belt and would it instantly go away.
  16. Feb 6, 2017 at 12:53 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I'm having the same problem just replaced 2 idle pulleys new belt and a new power steering pump/ pulley. I still have the squeak until late truck is hot.
  17. Aug 17, 2018 at 11:46 AM
    pungu01
    pungu01 Member
    2002 Silver Tacoma 2wd
    Good job!
    How did you figure out which belt was squealing? or did you deep creep all the belts?
    I have a similar problem with my 2002 tacoma...squeals loud on a cold engine, but stops when the engine has warmed up. Maybe I will tryout the deep creep treatment.
  18. Aug 17, 2018 at 12:21 PM
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    In the olden days I would use a bar of soap on the underside of the belt. Worked like a charm and stays around. And depending on the soap, you might get the smell of an Irish spring! :rolleyes:
  19. Aug 18, 2018 at 1:09 PM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Don't use lubricants or soap on the friction surface of your belt. With the engine shut off, apply a thin smear of plain white toothpaste to the friction side, then start the engine and let it idle. May take a few shutdown and reapply toothpaste before you get good effect and the squeal subsides, assuming the squeal was a belt slipping. The mild abrasives in the toothpaste remove the glaze from the belt rubber and help it grip the driven pulleys.
    This is a temporary fix until the belt can be replaced.
  20. Sep 3, 2018 at 2:08 PM
    pungu01
    pungu01 Member
    For now, the soap trick helped out a bit...I guess I will have have to replace the belts, but I am waiting for about 150k so I can replace the waterpump, timing belt, and the squeaking belts too.
