Vertical Spare Tire Mount in Bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbow, Jul 6, 2016.
  1. Jul 6, 2016 at 6:24 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Does anyone know of a vertical spare tire mount that you can mount to the bedrail? I carry an extra spare on long wheeling trips and just a spare in the bed when I plan on wheeling a little harder. I searched and found that metalmiller used to make them. If you've got one and want to sell pm me. Thanks!
    I store my winch and other gear in a husky box in the bed and I want to minimalize the room the spare takes up, otherwise I'd go with a different style.
  2. Jul 6, 2016 at 9:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The problem with your plan is the side mount places a lot of stress on the rail which causes the bed side to flex and it will crack the bed side panel...
    Use with caution.
  3. Jul 7, 2016 at 3:30 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    You could make your own. Go buy a long carriage bolt. I forget the size head, but searching on here will tell you what is needed. Slide the bolt into the bed track to where you want it, and slide your tire into the bed and onto the bolt. Tighten a nut down on the bolt and that will hold it in place to the bed rail.
  4. Jul 7, 2016 at 5:54 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    yeah... looks like I'll have to make one when I get some time. I'll probably build some sort of base so that the tire's weight sits on the bed floor and use a bolt attached to some sort of bracket on the bed rail.
  5. Jul 7, 2016 at 6:20 PM
    Pigpen
    Northwest Montana
    Make a bracket that bolts into the rails and the bottom of the bed. You'll be less likely to ruin the bed sides that way. If you found the Metalmiller bracket, then you must have read about the problems.
  6. Jul 7, 2016 at 6:30 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
  7. Jul 7, 2016 at 6:35 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    As long as you use some backing plates you should be fine. For the other aforementioned reasons I just throw the tire in the bed and ratchet it in via some l-track. That's a good bit of weight to just be sitting on a single bolt in the rail.
