Verify please...raising the rod for the LSPV increases rear braking?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Sep 23, 2021.
  1. Sep 23, 2021 at 3:31 PM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    By raising the rod for the LSPV it increases rear braking. Correct? I invision the body lowering via load thus pushing the rod up. Thanks
  2. Sep 23, 2021 at 4:15 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I think that is how it works. Putting a heavy load in the bed would lower the bed toward the ground and essentially raise the rod at the lspv?
    Rachelsdaddy[OP] likes this.
  3. Sep 23, 2021 at 4:44 PM
    Rachelsdaddy
    Southern NH
    That’s how I see it. I suddenly am having a lack if rear brake issue and I’m assuming my problem lies here. I already installed the 2” bracket to accommodate the lift. Thanks
  4. Sep 23, 2021 at 6:21 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Yes, that’s how it works. The rear brakes need to be adjusted up as well. Depending on your weight, you might can go up more, and get better braking power.
  5. Sep 23, 2021 at 6:56 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There is a really interesting set of "On-Vehicle Diagnostics" in the FSM. It looks to involve attaching SST pressure sensors to the front DS and rear DS wheels, and then testing the pressure with and without load in the bed, and then adjusting the "fine-tune" on the axle end of the LSP & BV system:
    I say interesting because I think "stock height" and "I'm lifted 2 inches" are relative to factory springs 20 years ago, and doubt any ability to correctly determine how much a truck is lifted at this point. I know we generally say, if you lift 2" get a 2" bracket and move on... but what if you did that originally (15 years ago) and now you've installed new springs, and the lift amount vs stock is (reasonably) undeterminable at this point.
    It would be helpful to actually be able to determine a DIY way to measure this, and ultimately be able to fine-tune "A" into correct specifications.
    Black DOG Lila likes this.
  6. Sep 23, 2021 at 6:59 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I remember you saying you shared my braking problem, and just want to let you know that I did raise the LSPV and nothing changed. Not to say it's not better to leave it.
  7. Sep 23, 2021 at 7:13 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Mark the adjustment rod where it is, and move it up in small increments. You can always go back to your mark. Test drive and see how it feels. As long as you don’t lock up the wheels, or they grab and lunge you forward, I think you’ll be ok. I’ve always adjusted them by trial and error.
  8. Sep 24, 2021 at 5:05 PM
    Rachelsdaddy
    Southern NH
    I did share your braking problem till I replaced the booster, my brakes are mucho better but the rear ain’t quite right. Hardly get any oil through them when the kids pumping the brakes. Front is fine….
    treyus30[QUOTED] likes this.
  9. Sep 24, 2021 at 5:07 PM
    Rachelsdaddy
    Southern NH
    Yeahhhhh….. I ain’t going through all that sh*t…… thanks
  10. Sep 24, 2021 at 5:08 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I have that tool… it works nicely.
    But super time consuming
  11. Sep 24, 2021 at 5:09 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Is the weight of the truck on the wheels while bleeding ?
    SLAPS 65 likes this.
  12. Sep 24, 2021 at 5:13 PM
    Empty_Lord
    Dan
    Are the rear drums properly adjusted? That’s usually the problem I run into at work when people feel they’re not working very well.
  13. Sep 24, 2021 at 10:06 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Just a regular sized replacement? I think I've heard of larger, yet compatible boosters
  14. Sep 25, 2021 at 8:46 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Not surprising from you.
    Care to share the details of that tool? Does it fit into the bleeder valve port? assuming it does, that means it probably has to be bleed once in place, and that is the time-consuming part?
  15. Sep 25, 2021 at 11:45 AM
    Rachelsdaddy
    Southern NH
    Mine was obvious, it started weezing loudly and the braking was big time horrible. I adjusted the arm on the lsv, the little lift bracket was only a 1.5”, got the extra 1/2 via the adjustable rod. Brakes are fine now. My booster must have been slowing failing….
    Empty_Lord[QUOTED] likes this.
  16. Sep 25, 2021 at 11:46 AM
    Rachelsdaddy
    Southern NH
    I don’t know if it matters, logically it wouldn’t but I’ve heard of stranger things…. It was on the ground
  17. Sep 25, 2021 at 12:08 PM
    Empty_Lord
    Dan
    As you’d imagine it’s just hook up to bleeders and go… it’s not super difficult, but it’s annoying to use.. they were throwing it out at work. So me being me, I took the opportunity to dumpster dive for it lol.
    doing it by feel is how I go most of the time, but with the frame swaps I use the tool. It’s faster since I’m already there
