Vavoline Synthetic 75W90 for differentials and the transfer case?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spif, Mar 9, 2023.
  1. Mar 9, 2023 at 10:16 AM
    Spif
    Spif [OP] vehicle: 2014 Taco 4x4 double cab
    2014 Taco 4x4 double cab - 125k miles
    Is this gear oil appropriate for both front / rear differentials and for the transfer case?
  2. Mar 9, 2023 at 10:27 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is it the “appropriate” fluid? That’s is debatable.
    And it won’t be long before it’s debated in this thread.
    If it were my truck, I would have no problems running it in all 3.
    Don’t over think it, it’s a Tacoma. It’s nothing special that needs specialized fluids:thumbsup:
    Hayden334 and Spif[OP] like this.
  3. Mar 10, 2023 at 5:52 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Well said.
    Any 75W-90 gear oil will work just fine in all 3 locations. However I always like to offer this advice when someone asks this question. ECGS recommends Lucas dino 85w140 / 80W-90 for extreme cold climates in all of their applications. Which is what I run in my diffs and T-case.
    https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
  4. Mar 10, 2023 at 6:26 AM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
  5. Mar 10, 2023 at 6:49 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I use the mobile one 7590 LS synthetic and the front differential the transfer case and the rear differential no problems and 77,000 miles and I'm going to change it as soon as the weather warms up and I'm going to use the same product over again
    TOMB
    TnShooter likes this.
  6. Mar 10, 2023 at 7:26 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    As long as you change it out on time or ahead of schedule depending on use/years i really don't think it matters what synthetic you use. I change mine out about every 15,000 miles (7 years.)
  7. Mar 10, 2023 at 7:46 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah it doesnt mater what fluid you get, put 75w-90 gear oil, conventional, synthetic, blend. Just make sure to change it regularly (I do my rear diff every 30k and front n tcase every 60).
    The only thing that really matters if if you are an 08 or older with the mechanical clutchpack LSD in the rear, they can be a little picky.
  8. Mar 10, 2023 at 8:47 AM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    If you get the valvoline in the quart bags it makes it super easy to sqeeze it in.
  9. Mar 11, 2023 at 4:28 AM
    TAC0MAMA
    TAC0MAMA Well-Known Member
    Southern New Hampshire
    2010 Toyota Tacoma TRD
    I just used the Valvoline in my front diff and transfer case. Used the “bags” so it was super easy to fill. I was going to buy the Mobil 1 (like I did for rear diff a few months ago, but it’s not available anywhere near me that I could find. I just did it yesterday so we’ll see but so far so good lol.
    PlatyTaco likes this.
  10. Mar 11, 2023 at 9:09 AM
    jameswirl
    jameswirl Well-Known Member
    Denver, CO
    2010 Pyrite Mica DCLB TRD Sport
    I sure hope it’s the appropriate fluid for front/rear diff and TC. It’s what I use!
