Valvoline or Toyota Transmission Fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pwier, Aug 19, 2024.
  1. Aug 19, 2024 at 3:34 PM
    pwier
    pwier [OP] New Member
    2009 Silver Tacoma TRD Sport
    Is Valvoline Multi Vehicle Max Life ATF full synthetic equal to Toyota Genuine ATF Type T-IV? Does it work just as well?
  2. Aug 19, 2024 at 3:37 PM
    Bishop84
    Bishop84 Well-Known Member
    Your truck uses Toyota WS fluid, but ya consensus is its better, and easier to purchase.
    Only thing is, I'd want to only switch over if I did a pan drop, not just a spill and fill. I'd want to convert as much as I could over.
    Taco-Obsessed and pwier[OP] like this.
  3. Aug 20, 2024 at 7:54 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I have done a drain and fill every 75k with Valvoline MaxLife ATF. Currently at 250k. No issues.
    pwier[OP] likes this.
  4. Aug 20, 2024 at 9:48 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Toyota fluid.
    Williston and pwier[QUOTED][OP] like this.
  5. Aug 21, 2024 at 4:24 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Could be wrong, but pretty certain 2010 was the year they introduced WS fluid.
    My truck is a 2010 I bought new the last day of 2009. When it was time for a trans fluid change, no aftermarket fluids were labeled as WS. That said, I researched and found previous year transmissions, that utilized the T-IV fluids ran the same internal clutches and components. WS fluid was found to be a fuel mileage goal fluid, with nothing special about it. Therefore, my truck, a 2010 Prerunner has been running Mobil 1 ATF for over a decade.
  6. Aug 21, 2024 at 3:40 PM
    Bishop84
    WS was used on all V6 Tacomas as of 2005, pretty much every toyota after 2005 uses WS.
    Only the dinosaur 4 speed 4 banger tacomas used TIV but V6 sport is 100% WS.
    Black97v6MT and 3JOH22A like this.
  7. Aug 21, 2024 at 3:59 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    I have used Valvoline and Castrol engine oil, conventional and synthetic, in my cars for years, including some that went 300k+ miles and never had an oil-use or internal engine issue on any of them. I currently use Mobil1 most of the time, but have no doubt that either of those brands aren't at least the equal to it.
    That said, when it was time to change the transmission fluid in my current truck, I used Toyota WS.
  8. Aug 21, 2024 at 4:11 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I did a pan drop and then a full flush with Valvoline while purging all of the WS fluids. I’ve been doing pan drops and refills will Valvoline and a bottle of LubeGuard for prevention. So far everything’s great. So I vote for Valvoline over WS.
    Rob MacRuger likes this.
  9. Aug 21, 2024 at 6:40 PM
    Taco-Obsessed
    Micbt25 likes this.
  10. Aug 21, 2024 at 7:15 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I would like to see transmission failure data that attributes early transmission failures to WS fluid. If that’s not available, everything else seems speculative based on fluid specs but not actual performance or failure data.
    The most recent post from the thread linked above is from a member who switched away from WS at 280K miles. So his transmission apparently did just fine for all that time on WS, many miles more than most members here will put on their trucks…
    spitdog likes this.
  11. Aug 23, 2024 at 4:05 PM
    Micbt25
    TM
    I’ve consulted gearcruncher when it came to all things tranny related, he’s a great source!
    Taco-Obsessed[QUOTED] likes this.
  12. Aug 23, 2024 at 4:37 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You can buy genuine Aisin WS fluid from rock auto for less than $7.50 a quart.
    Micbt25 likes this.
  13. Aug 24, 2024 at 10:51 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It is not equal but it is compatible per Valvoline’s product data sheet, which you can view on their website. I, too, have been using it with no issues. I first used it on our 2007 Lexus ES350, then my 07 Taco, and most recently on daughter’s 20 RAV4, all of which call for WS. As a Type IV replacement, I used it on a 07 Corolla and 06 Camry. However, the consensus among transmission mechanics is to do a flush, as oppose to a drain/refill, when switching brands.
    Micbt25 likes this.
