Valve cover spark plug gaskets stuck, any advice?
Discussion in '1st Gen. Tacomas (1995-2004)' started by old4x4yota, Jan 19, 2019.
  1. Jan 19, 2019 at 5:17 PM
    old4x4yota
    old4x4yota [OP] Member
    1996 Tacoma extra cab v6 4x4
    Hey guys, I am replacing the valve cover gaskets on my 1996 tacoma 3.4 and all was going smoothly until I tried removing the spark plug gaskets, they are as brittle as can be.
  2. Jan 19, 2019 at 7:14 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    You will have to keep working them with a punch until you can bend them enough to grab an edge with pliers then pull it out. That is what I had to do with mine.
    Be careful not to scar the surface too bad when trying to get it out.
  3. Jan 20, 2019 at 3:30 PM
    old4x4yota
    ended up using a chisel to fold the sides down, it actually worked really well
    cruxofthebisquit likes this.
