Valve cover leak, how bad is it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J89, Nov 4, 2017.
  1. Nov 4, 2017 at 3:02 PM
    J89
    J89 [OP] Active Member
    Vancouver
    07 DCLB
    So I'm not sure if this is a serious problem or what to do about it.
    But there seems to be a valve cover leak.
    A guy noticed it doing my oil change maybe 2 years ago. Maybe its spread a little bit since then, but not by much.
    Should I be concerned? Is there something I should do about it?
  2. Nov 4, 2017 at 3:06 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Thats not your engine block, looks like you have a valve cover leak... common issue and not a big deal.
  3. Nov 4, 2017 at 3:21 PM
    J89
    Vancouver
    07 DCLB
    Thanks I'll change some stuff so its accurate.
    Should I be concerned with this, is there anything I should do about it?
  4. Nov 4, 2017 at 4:23 PM
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    You can change the gasket or try tighten the bolts first as gaskets shrink over time.
  5. Nov 4, 2017 at 4:23 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Mine leaks in the same spot. 2010 with 124k just cleaned it up and see how long it takes to come back
  6. Nov 4, 2017 at 4:31 PM
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    --My 2006 looks like new
  7. Nov 4, 2017 at 4:38 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I had a Jeep that leaked like that. I changed the valve cover gasket, and it came back. I don’t think it was ever a real problem.
  8. Nov 4, 2017 at 5:51 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    If you want to change it, it's not that big of a job really. It's a rubber gasket that sits in a groove. Don't even have to scrape off any old gasket material.
    Had my valve covers off to install the exhaust cam gears that come with the UCON tuner.
    Although, if mine were leaking just a little, I probably wouldn't bother pulling the Supercharger off to change the valve cover gasket.
    bevo2000 and 12TRDTacoma like this.
  9. Nov 4, 2017 at 5:53 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Also, as was stated above, I'd start by re-torgueing the valve cover bolts. See if that takes care of it.
    GilbertOz likes this.
  10. Nov 4, 2017 at 8:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That doesn't look that bad yet.. if you can smell oil dripping on the exhaust manifolds and making a stinky smell then I would think about re-sealing them..
  11. Nov 5, 2017 at 12:23 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    As others have said the slight weeping you have observed should be monitored, but not worried over.
    A caution however should you chose to re-torque the fasteners:
    Note: Toyota incorrectly uses the Imperial units ft·lbf and in·lbf the specify torque values. This is incorrect as these are both units of work [distance times force] not torque [force times radius (distance)]¹. The proper Imperial units of torque are the lbf·ft and lbf·in; these are the units I will use in my discussion.
    The torque specs for the bolts and nuts (shown below) are just 80 and 89 lb·in--so make sure you use an appropriate torque wrench, most likely a 1/4" drive unit which typically have ranges of 20 to 200 lbf·in. Here are the specs for the right and left covers:
    head cover--RH (7.4 lbf·ft = 88.5 lbf·in)
    head cover--LH
    It should also be noted that the sealing gasket is a formed (not flat) seal seated in a channel at the perimeter of the cover, and that when torqued as described the cylinder head cover and cylinder head are in full metal to metal contact--i.e. the seal is compressed fully into the channel and further tightening of the fasteners will not further compress the seal.
    Bottomline: Checking the fastener torque is worth a shot however unless they are loose it is unlikely the weeping will be lessened--the real fix is a new gasket...
    ¹ - Toyota's use of ft·lbf and in·lbf is also contradictory to the metric unit N·m unit (force times distance) also specified. Most makers no longer use these commonly used but nonetheless incorrect units for torque, I was somewhat surprised to find Toyota continues to do so.
    Some readily available examples:
    2003 Suzuki Burgman 400:
    2006 Honda Silver Wing 600:
    2004 Ford 4.6L:
  12. Nov 5, 2017 at 4:53 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    my 08 had this, I tightened the bolt and it's been good ever since.
  13. Nov 5, 2017 at 6:48 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Maybe start using high milaege oil to swell up the seals a bit, they dry out and shrink with age.
  14. Nov 25, 2023 at 10:46 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Thread revival.
    I just noticed the same on my 2011 dcsb 4.0L w/ 178k mi.
    I suppose I'll start by checking the torque on those bolts when I change the spark plugs in 2k miles (at 180k).
