Valve Cover Half Moon Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghostfart, Oct 27, 2020.
  1. Oct 27, 2020 at 5:31 PM
    ghostfart
    ghostfart [OP] Well-Known Member
    Oakland, CA
    2002 Tacoma XtraCab TRD
    (https://imgur.com/a/p1VKXtw)
    I think I have a valve cover leak either due to a cracked gasket or improperly placed half moon.
    Earlier this summer I had the bright idea to do some preventative maintenance on my 02 4wd Tacoma and replace my valve cover gasket. Well last week I started smelling burnt oil and found some oil seeping onto my exhaust manifold on the driver's side[​IMG].
    As you can see from these photos here, it looks like the Permatex Ultra Black Gasket Maker I used oozed out the sides. Did I use too much? I'm wondering if this is why the leak occurred?
    Any insight would be greatly appreciated!
  2. Oct 27, 2020 at 6:04 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Did you also do the cam covers back there (full moons)?
    There is a sticky above and a Youtube tutorial that's very helpful.
  3. Oct 27, 2020 at 6:07 PM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    Did you try rechecking the torque on the valve cover bolts?
    Did you clean and remove all of the rtv before applying the Permatex?
  4. Oct 27, 2020 at 8:00 PM
    ghostfart
    Oakland, CA
    @TacoTaco02 Yeah if I remember correctly I did remove all of the RTV and yes I recently retorqued the bolts but still leaking
  5. Oct 27, 2020 at 8:01 PM
    ghostfart
    Oakland, CA
    @cruxofthebisquit Yeah I did the cam covers. I got in their with my camera and didn't see any seepage near there. Mostly near the rear bolt close to the half moon. To me it looks like you can almost start to see some oil weeping out between the half moon and valve covers
  6. Oct 27, 2020 at 8:49 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    hate to say it but you'll prob. have to go back in. Some thing not jiving and unlikely to be able to see it from outside.
  7. Oct 27, 2020 at 8:53 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Going to have to take them out and do it again then. It's a pain I know. This time just make sure to make sure that all of it is well coated with permatex
  8. Oct 27, 2020 at 9:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    FWIW you could try cleaning it and dabbing a little rtv in there if you're not gonna have time to redo it immediately.
  9. Oct 27, 2020 at 10:05 PM
    ghostfart
    Oakland, CA
    I just cleaned up all the oil, retightened again and I'm going to monitor it over the next day or so. Might use that RTV trick if I have to, thanks for the idea @Dalandser but I'm starting to think I'm going to have to do it again...
    crazytacoman and Dalandser like this.
  10. Oct 27, 2020 at 10:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Probably will - I know if you're busy it might be awhile before you plan out a time for you to get to it.
  11. Oct 28, 2020 at 9:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    one of these other numerous VCG threads recently was implying this is a 20 to 30 minute task?
  12. Oct 28, 2020 at 9:23 AM
    rockies
    rockies Well-Known Member
    RockieMountains
    Tacoma
    Night_Wolf84 likes this.
  13. Oct 28, 2020 at 10:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you've done it enough times you're like a Tacoma pit crew sure. Watch this video and think about trying it in 30 minutes is doable - then again if you need to read how to do it or watch it to know how to do it, I don't think 30 minutes is realistic. What would I know though, a few months shy of 4 years and my truck's not out of the driveway yet...
    https://www.youtube.com/watch?v=N5fAXAuGozI&t=1585s
    GQ7227[QUOTED] likes this.
  14. Oct 28, 2020 at 11:50 AM
    ghostfart
    Oakland, CA
    The first time I did this job I went crazy slow, meticulously cleaned everything and it took me the entire weekend. I expect I can do it in a half day now that I know what I'm doing and don't plan on replacing everything on the air intake/throttle body, etc
    GQ7227 and Dalandser like this.
  15. Oct 28, 2020 at 7:31 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Good thing you likely do not have to replace your taco frame coating with such meticulous hahaha
    I Never thought it would take so long to do this task, it will be more than 2 years to get this done , it sucks bad
  16. Oct 28, 2020 at 9:13 PM
    crucescrawler9
    crucescrawler9 Well-Known Member
    Gary
    2001 Tacoma Cre 4x4
    Plenty of Odds and Ends
    I spray the heck out of em with carb cleaner, dry em out and get out some right stuff for those.
  17. Oct 28, 2020 at 9:19 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I say that. *I think your referring to the thread where the guy said his mech. wanted 1000 bux* I said it should be 2 hours book. Maybe 2.5
    Each one is. After upper intake removal and not counting putting it back. I can't gauge how many beers somebody drinks in between parts of a job. Some people guzzle, some sip.
    edit: I agree the spark plug seals can slow you down to.
  18. Oct 28, 2020 at 9:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I was only guestimating the time soley based on someone's estimate of the cost
    Beer was not a factor lol
  19. Oct 29, 2020 at 7:09 AM
    1997tacomav6
    Denver
    I spent probably an hour on each side or more with a dremel wire brush and a can of carb
    cleaner.
    If there’s any old gasket material or oil residue it will have a chance to leak.
    Did you get new cam plugs and half moons?
    I did and everything sealed up perfectly.
    Next time get new cam plugs and half moons.
    crazytacoman likes this.
