Valve cover gasket "While I'm at it", What else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthro4me, Oct 28, 2023.
  1. Oct 28, 2023 at 7:14 PM
    anthro4me
    anthro4me [OP] New Member
    Hey Y'all,
    I need to replace the gaskets on my valve covers cuz I'm getting some oil leakage, and I was wondering what else would be a good idea to address/look for while I'm at it. 2002 3.4L 4x4. I'm not very experienced at wrenching. I can do regular maintenance like brakes, oil changes, plugs, airflow stuff. My most ambitious project to date has been replacing my clutch master cylinder and slave cylinder, so for me the valve cover gasket is pretty new territory. Is there something I'd be dumb not to do while I have those off? Thanks in advance for any help.
  2. Oct 28, 2023 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Tube seals 1000% and reseal or replace the half moons in the cylinder head when its exposed.
  3. Oct 28, 2023 at 7:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pcv valve and hose(s)
    Spark plugs
    Check ignition coil boots and wires closely for cracks or arcing
    If the heater hoses are questionable they're easy to access with the upper intake removed
    Superdave1.0 and anthro4me[OP] like this.
  4. Oct 29, 2023 at 5:47 AM
    Av180r
    Av180r Well-Known Member
    Las Vegas
    1998 Tacoma SR5 V6 4x4
    Here is the list of parts I replaced at the same time I replaced my valve covers. It's not a terribly difficult job, but I'd reccomend taking your time and following a tutorial video from YouTube. Have everything prepared ahead of time.
    Toyota part # Name/Quantity
    11213-62020 Engine Valve Cover Gasket- 2
    11193-70010 Spark Plug Tube Seal- 6
    90210-05007 Engine Valve Cover washer- 16
    11188-62010 Engine Camshaft Seal/plug- 2
    17176-62040 Intake Manifold Gasket- 2
    90480-18001 PCV Valve Grommet- 1
    12204-62010 PCV Valve- 1
    11183-62010 Camshaft Plug (half-moons)- 4
    00295-00103 Oil Pan Sealer (FIPG)- 1
  5. Oct 30, 2023 at 5:51 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I'm adding the knock sensor cable to my valve cover job. I've read several posts here on TW to check your Valve shims to see if there in spec, and others have stated to send your fuel injectors off to Motor West for a rebuild while you doing this job. Just how far down the rabbit hole do you want to go.
  6. Oct 30, 2023 at 9:56 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Clean the throttle body. Make sure to get the metal gasket for it as well.
    leid likes this.
  7. Oct 30, 2023 at 10:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The wire harness; the loom on it will break and crumble and leave a bit of a mess so make sure you've got the shop vac ready. All the plastic you'll find there is brittle as hell.
    Use some heat-resistant wire wrap/tape to tidy things up as you put it back together.
    A lot of people focus on gaskets, etc. to replace in there but find out about the wire harness the hard way.
  8. Oct 30, 2023 at 10:04 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Also want to think about fipg/RTV. If you are ok letting it sit for a few hours to overnight, then Toyota FIPG or Ultra Grey is good. If you will need to immediately start the truck after repair, then I'd recommend right stuff black.
  9. Oct 30, 2023 at 9:29 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'd highly suggest watching this video before you decide what to do "while you're in there":
    https://youtu.be/N5fAXAuGozI?si=e7Y1Q8-ZRX_Yw6Yi
    And ultimately everything he does, you should do, unless you have any maintenance records indicating that maintenance item has been done recently.
  10. Nov 3, 2023 at 9:03 PM
    Peekoost
    Peekoost Well-Known Member
    Upstate, South Carolina
    2002 Xtracab 4x4 auto 3.4 Impulse Red
    Do you have the part numbers for the heater hoses? I can't seem to find them. Thanks
  11. Nov 3, 2023 at 9:08 PM
    Peekoost
    Do you have a part number for the knock sensor cable, I couldn't find anything. Thanks
    Do you have to replace the harness or just wrap it in the tape/wire rap? Thanks.
  12. Nov 3, 2023 at 9:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The wrap around it.
    Peekoost[QUOTED] likes this.
  13. Nov 3, 2023 at 9:53 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    the part number I ordered was 82219-34010, but use your VIN number to be sure. To answer your other question for KwikVette, I'm using some Telsa Tape I ordered from Amazon to wrap the wire harness up in. I ordered all my parts from Ourisma Toyota, which was previously known as McGeorge Toyota.
  14. Nov 4, 2023 at 6:13 PM
    Peekoost
    I still can't find anything on the heater hoses part numbers for the 3.4. Does anybody know? Thanks
  15. Nov 4, 2023 at 6:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just go to a parts store and buy them
