Valve Cover Gasket OEM or Auto Parts?
Discussion in 'Technical Chat' started by VA_Taco, Apr 8, 2019.
  1. Apr 8, 2019 at 8:55 AM
    VA_Taco
    VA_Taco [OP] Well-Known Member
    Chino
    Virginia
    2012 TRD Sport 4x4
    6" w/35's
    So I just got a quote to replace the valve cover gaskets on my 98 V6 Taco, it has a small and slow leak. They quoted me $288 at my local shop, which is a lot cheaper than i thought. Question is, should I request OEM gaskets for an extra $28 or is the Fisher Auto Parts gaskets just as good?
    Sounds kind of obvious to go OEM now that I am reading this.
  2. Apr 8, 2019 at 5:59 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    OEM always
    VA_Taco[OP] likes this.
  3. Apr 8, 2019 at 7:46 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    OEM, I have no problem with aftermarket parts but for gaskets/seals I always go OEM since they aren't much more then aftermarket and since they lasted this long I figure the new OEM ones will last just as long.
    Rambo54 and VA_Taco[OP] like this.
  4. Apr 13, 2019 at 7:11 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    By "local shop" I assume you mean independent repair shop.
    I might want OEM as well, especially if I were going to keep the truck, but how would you really be able to tell an OEM valve cover gasket from after-market after the valve covers are back on? The shop is going to use whatever they can source quickly. VCGs for a 21 yr. old Tacoma will need to be ordered from a dealer and that will add to wait time.
    Even if you took this older truck to a dealer, they would install an after-market VCG. Repair shops want to get vehicles in and out asap.
    The only way you will know with certainty that you got an OEM VCG is to order from a dealer and install it yourself.
  5. May 5, 2019 at 6:48 AM
    Yota.jr
    Yota.jr Well-Known Member
    Vancouver Island B.C.
    18~Yota-xcab~6spd & 98 too:)
    Curious what was total bill to have this job done? Hrs & parts...?
