Valve Cover Gasket OEM? FelPro? Mahle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Jan 13, 2025.
  1. Jan 13, 2025 at 7:22 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    My Valve Cover Gasket is leaking, and I need to replace it. Are the Felpro or Mahle gaskets worth using? Should I stick with OEM? I have time to do the job today, but I can't get the OEM gasket today. If none of the aftermarket parts are worth a damn, I'll just wait. I know Felpro and Mahle are usually reputable brands though.
    What about the Upper Intake Gasket?
  2. Jan 13, 2025 at 7:26 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I replaced my valve cover gaskets with OE Toyota. I did both since I was already there and I also replaced the upper intake gasket as well.
  3. Jan 13, 2025 at 7:28 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I'd PREFER to use OEM, but I'd also prefer to get it done today, while I have some free time, lol
  4. Jan 13, 2025 at 7:34 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Mahle would get my vote, they're OEM for tons of manufacturers and make good quality stuff. I've never had much luck with that Fel-Pro blue perma dry shit. Just make sure you use a dab of permatex ultra black where the timing cover meets the head before plopping your new gaskets down
  5. Jan 13, 2025 at 7:37 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    How many miles on your truck and/or how long did the OEM originals last? If it was more that 5-yrs/50,000 miles, unless you're leaking a quart per thousand, save yourself the aggravation and get the the OEM gaskets. Mine (original) are currently at 135,000 and still dry as a bone.
  6. Jan 13, 2025 at 7:46 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    180k, and I end up putting in a few qts in between oil changes. Changed my oil last night and there was only like 0.5 gal.of oil in the truck. Wouldn't be so bad if our dipstick wasn't the worst thing ever.
  7. Jan 13, 2025 at 8:04 AM
    Williston
    New England
    Ooof!! :eek: That's some leak! Call around and see if a dealer has them in stock or can get them next day. If not, I would go aftermarket: Mahle. Most dealers can get parts for you next day if you call when they open and can go pick them up. Same if I order them on-line through Toyota and select the pick-up at counter option.
  8. Jan 13, 2025 at 8:05 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Yea, funny thing is, I never get oil spots on my driveway. I'm guessing it's just gunking up before it can drip.
  9. Jan 13, 2025 at 8:21 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    If I order OEM, since they aren't in a kit, what parts do I need? I know theres;
    11213-AD010
    11214-AD010
    17176-OP010
    Do you know if the OEM gasket comes with new grommets?
  10. Jan 13, 2025 at 8:49 AM
    Williston
    New England
    Can't say and things change. Best thing to do is go to their site and enter your VIN to insure you get the correct pieces. Enter those parts numbers or check the diagram to see if anything else is required.
    https://autoparts.toyota.com/search?search_query=11213-AD010
  11. Jan 13, 2025 at 8:58 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    I put Fel-Pro gaskets on my '01 Avalon 10 years and 40K miles ago (Florida car). Anyone that is familiar with the Toyota 1MZ-FE will tell you what a PITA this job is. I have had no oil leaks since.
    Because of this positive outcome, I just bought Fel-Pro gaskets for the 1GR-FE in my '09 Tacoma, and will be installing them later this week. The Fel-Pro gasket part number is;
    VS 50634 R ~$20
    The Tacoma is currently just over 135K.
    Rob MacRuger likes this.
  12. Jan 13, 2025 at 5:29 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I replaced mine with felpro and they leaked. Wound up redoing with oem. oem has the spark plug tube gaskets as well as the proper little gaskets for under the bolts that go through the center area of the valve covers. Glad to hear the previous poster had luck with felpro on his Avalon but if do more searching on this site you will not find positive opinions on felpro.
  13. Jan 13, 2025 at 6:07 PM
    eherlihy
    Strange. I just did a search on "FelPro" in the 2nd generation forums, and can't find any complaints about FelPro valve cover gaskets.
  14. Jan 13, 2025 at 6:24 PM
    Meatballica
    Meatballica Member
    I replaced mine with one from the auto parts store, don't remember which brand but IIRC it was not the bottom dollar one and it was blue and it leaks. So I wish I would have gone OEM
  15. Jan 14, 2025 at 5:01 AM
    eherlihy
    That's two.
  16. Jan 14, 2025 at 4:22 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I used a Fel-Pro kit from Rockauto less than a year ago for valve covers and timing cover. They were marked made in Japan, appeared identical to OEM, and the valve cover kit had the spark plug donuts included. Excellent fit, no leaks.
    3JOH22A likes this.
