Vacuum pump now a maintenance item 120k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Oct 21, 2023.
  1. Oct 21, 2023 at 11:53 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Looked at my owners Manuel today and it says to replace the vacuum pump at 120k miles? This a first lol I’ve never seen this in my other 3rd gen tacomas maintenance booklets.
  2. Oct 21, 2023 at 1:35 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I guess nothing lasts the life of these tacoma trucks anymore.:notsure:
    Gfenza89[OP] likes this.
  3. Oct 21, 2023 at 1:44 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Im 1/2 way there.
  4. Oct 21, 2023 at 1:46 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    To the tune of $300.00 dollars plus labor. I’m sure everyone will be jumping right on that one.
  5. Oct 21, 2023 at 1:58 PM
    Gfenza89
    I don’t think I’m gonna change it unless there is an issue lol. Wasn’t in the early model year recommendations
    TnShooter and zoo truck like this.
  6. Oct 21, 2023 at 1:59 PM
    Gfenza89
    Must be something we’re not understanding for them to suggest replacement
  7. Oct 21, 2023 at 2:01 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    That’s not new, that’s been in many owners manuals, though not all of them. It was definitely in the manual on some of the older trucks like 16-18. I wouldn’t touch it unless presented with a problem.
    zoo truck likes this.
  8. Oct 21, 2023 at 2:03 PM
    Gfenza89
    I’ve never seen that in any of my 3rd gem booklets
  9. Oct 21, 2023 at 2:04 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    This kind of tells me they’re seeing it fail at 120K or shortly thereafter. Failure is gonna affect the breaking, so I guess they got it listed as a preventative maintenance replacement
    3JOH22A and Gfenza89[OP] like this.
  10. Oct 21, 2023 at 2:08 PM
    BLtheP
    Plano, TX
    I dunno but it’s definitely been in some of them before. It’s been talked about here.
  11. Oct 21, 2023 at 3:37 PM
    Rusty66
    Rhode Island
    Mine is banging/knocking away so loud it will never reach 120,000 miles.
  12. Oct 21, 2023 at 9:03 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    One good reason to buy an off road over a sport or sr5.
    vivid02 likes this.
  13. Oct 22, 2023 at 1:33 PM
    zoo truck
    None
    Neither have i. I wonder if this is some safety thing that toyota is mandating it, so to cover their butt.
    Gfenza89[QUOTED][OP] likes this.
  14. Oct 22, 2023 at 2:39 PM
    JTScribe52
    JTScribe52 Well-Known Member
    Dan
    2018 SR5
    How difficult to change? DIYable?
  15. Oct 22, 2023 at 2:40 PM
    Gfenza89
    Not sure
  16. Oct 22, 2023 at 3:37 PM
    Drippy4x4
    Drippy4x4 Keeper of the Air Dam
    '22 SR5 Taco
    I believe it's listed in either the Highlander or Camry manuals..if I remember correctly.
    It's located on the passenger side head. Towards the rear of firewall. Totally DIY-able but there's not much room in that area...so it'll have to be fanangle it out. The only thing to look out for is the matting of the lugs on the camshaft and also keep the O ring in place when replacing the pump.
    I think Toyota made a consumable part is because the inside fins of the pump is made out of some sort of plastic.
    Look up broken vacuum pump in other make and models and you'll see the fins of the pump will shatter to pieces....causing no vacuum to the brake booster...and or possibly lock up the camshaft that it's connected to...causing even more headaches.
  17. Oct 22, 2023 at 3:47 PM
    Gfenza89
    So probably changing oil regularly would help prevent failure and keeping up with coolant changes
    joba27n likes this.
  18. Oct 22, 2023 at 4:15 PM
    Drippy4x4
    '22 SR5 Taco
    No coolant lines. Only oil runs to the pump to lubricate the moving parts. Hence the O ring sealing it to the block.
    Here's an old but still relevant TSB on vacuum pump noise issues.
    T-SB-0115-22 (December 22, 2022)
    Also, I believe the earlier Camrys with the 4 cylinders were having problems with the vacuum pump. The insides shattered under certain conditions...but Toyota pushed a recall out and revised that vacuum pump. Not sure what they updated..
  19. Oct 22, 2023 at 4:26 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I think Off-road and Pro’s exempted :D
  20. Oct 22, 2023 at 8:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My comment has nothing to do with Tacoma's but I was looking through a Hyundai Maintenance Schedule and the Power Steering Pump was listed at 90K Miles, never came across that before on any other vehicle.
