UWS Tool Box Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by gagemc32, Feb 3, 2022.
  1. Feb 3, 2022 at 3:33 PM
    gagemc32
    gagemc32 [OP] New Member
    Gage
    2003 Black Double Cab Tacoma TRD
    The Tacoma has a 3" lift with spacers in the front and blocks in the back. There is a set of 16x 8 Method 305 NV rims with 295/75/16 Nitto Ridge Grapplers. The truck also has a aftermarket Sony head unit with two 8" power bass subs behind the seat. I have also taken the stock grill and cut out the center where I put a mesh insert along with a TRD badge.
  2. Feb 3, 2022 at 3:49 PM
    gagemc32
    Gage
    Here are some pics of it I took… not the best because it was a bit rainy and dark out
  3. Feb 3, 2022 at 5:55 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    You should have picked up the 60 Inch not 63
  4. Feb 3, 2022 at 6:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Send it back you got the wrong size .
    Did you not measure your bed to double check before ordering ?
  5. Feb 3, 2022 at 6:15 PM
    02hilux
    Planet: EARTH
    He didn't need to measure because everyone here on TW has it
    Wulf and Bivouac[QUOTED] like this.
  6. Feb 3, 2022 at 7:46 PM
    gagemc32
    Gage
    Yeah I used this forum like it’s meant to be used for… information. I saw others had it so I ran with it. I’ve had some say it’s the bed liner causing the difference
  7. Feb 3, 2022 at 9:03 PM
    02hilux
    Planet: EARTH
    Others bought the same part number as the one you purchased? Or just the same manufacture? Each tool box have different spec and manufacture changes the designed through the years.
    Wulf likes this.
  8. Feb 3, 2022 at 9:07 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    The 60 is the one you need for a first gen
    Wulf likes this.
  9. Feb 3, 2022 at 9:11 PM
    JimBeam
    JB
    2015 Tundra
    Wulf likes this.
  10. Feb 3, 2022 at 9:29 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    2nd and 3rd gen beds are a bit wider, so they can fit the 63" wide box. If you weren't looking in the 1st gen section, you may have seen information that doesn't apply to our trucks.
    Bivouac likes this.
