Using Tacoma Truckbed inverter to supply a power station, despite Modified Sine Wave AC power
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roadkill69, Feb 3, 2024.
  1. Feb 3, 2024 at 6:43 PM
    Roadkill69
    Roadkill69 [OP] Well-Known Member
    1998 Xcab 4x4 SR5 V6 TRD-OR; 2021 TRD-OR ACLB
    Truckbed Inverter use to supply a Power Station, and video. Applicable to Tune M1, OVRLND, and other canopy or wedge campers for an easy power recharge option.
    Was msging with someone today about 3rd gen Tacoma, power stations, and how to use the truckbed inverter to supply one. I know several other trucks have an inverter this would apply to, such as F150s.
    If you have an existing truckbed inverter in your model, you can make use of your alternator supply, and completely remove the need to get an alternator dc to dc converter, to isolate your start and house batteries, to limit current draw to avoid alternator damage, and to run thick 8AWG or 10 AWG cables from alternator to truckbed. You end up with a nice prebuilt alternator power supply, isolated from starter battery, ready to go.
    Here is a video I made, showing the issues involved, and a quick solution and success.
    Video shows using the 3rd generation Tacoma truckbed 120v outlet, to charge a Pecron e1500LFP power station. The problem with Tacoma power is that it is a Modified Sine Wave (terrible), not a Pure Sine Wave inverter. No power station tested so far will accept the poor malformed ac power, including Pecron e1500LFP, Bluetti AC200Max, Ecoflow Delta2 Max, and Jackery. So you can't just plug your power station into the AC and charge it, you have to somehow convert that nasty power to something your power station will take, which means some dc voltage and feed it into a Solar Charge Controller port.
    https://youtu.be/Pp2fd9_9oQ0?si=lFaO7Ywszmx32_04
  2. Feb 3, 2024 at 7:40 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The video is a good warning. People can destroy a battery charger/controller plugging it into the OEM AC inverter on the truck, that thing is really just made for running small AC motors like plug in AC car vacuums and standard AC blenders and should not be used with chargers. If someone ever hears a odd noise from a charger when plugged into an inverter, don’t keep it plugged in.
  3. Feb 4, 2024 at 6:29 AM
    Plaintaco
    Plaintaco Well-Known Member
    Houston, TX
    2023 Access Cab TRD Off Road
    I have not run into any issues with charging my Jackery 500 via the AC cord. But it does have a built in AC to DC “brick” in the cord.
    I’m interested in your installation of the rear bed lights in your access cab. Do you have a video for that?
  4. Feb 4, 2024 at 6:37 AM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    Same with my Jackery 240.
    ORtoCOTaco and YF_Ryan like this.
  5. Feb 4, 2024 at 7:34 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Good information. Last florida trip I used the 12v cigarette lighter adapter to charge my Bluetti while running a 12v fridge in the back seat. Bluetti was only used so fridge would run during stops when the truck was off. Planned to use the bed 110v receptacle on the next trip for the power supply. Will the pug trip or the power supply just won't charge?
  6. Feb 4, 2024 at 9:17 AM
    Roadkill69
    Good info. It seems the brick is just exactly what I show here, an Ac to dc charger, so it outputs dc to the power station whose motherboard accepts it.
    The issue apparently is in power stations that plug directly into wall, where the ac to dc conversion probably happens in a combined charger unit, just like many mppt solar charge controller/ ac charger combo units now-- the AC power is hitting a motherboard that has protections for inputs built in and not accepting.
    Rear bed lights came standard on 21 OR Tacoma.
  7. Feb 4, 2024 at 9:37 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The inefficiencies make my head itch, so I'd go through the trouble of running wires back to the battery. :laughing:
    Truckstop13 and bulalo like this.
  8. Feb 4, 2024 at 1:10 PM
    Roadkill69
    Meh, for making use of existing inverter, socket, and wires, the efficiency hit is pretty cheap.
    Also remember, I'm not hard wiring up a 2nd battery system, I am just plugging in a removable power station.
    Victron Orion dcdc 12 12 30 gives 360W, $215.
    25 or 30A over a 20ft total run, there and back 10ft, needs 6AWG. 15 ft each black red is $60 plus $10 crimps etc. Fuse and holder is $25.
    Total $320
    400W inverter draw x 85% ac to dc efficiency is 360W, same as above.
    85% inverter efficiency means alternator delivers 470W, which at 13v is 36A. Victron is 87% efficient, so it pulls 31.8A from alternator. So all said, it is a 4A difference to alternator, not much. Oh, and the power supply was $67.
  9. Feb 4, 2024 at 2:48 PM
    0xDEADBEEF
    For the setup in your video - 85% for the inverter, and then maybe another 85% for your AC-DC supply. 73% efficiency together. I can replicate teh same setup, without the losses, with about 20 feet of 12 ga wire, a fuse, and some connectors.
    I could see doing a bigger inverter though, just to take advantage of the higher charging rate. But thats a whole other can of worms, as you noted.
  10. Feb 5, 2024 at 2:22 AM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    Wall warts tend to fail because they use a transformer instead of a switching power supply, the stepped pulse creates a vibration that physically wears down the coil until a short is formed.
    There is indeed a convenience factor with the power stations where efficiency isn't of much concern if your trips are long enough that the station is always fully charged by the time you use it.
    Roadkill69[OP] likes this.
  11. Feb 16, 2024 at 11:29 PM
    Daulll
    Daulll Well-Known Member
    Saul
    SoCal
    2022 Tacoma OR
    what power supply did you end up using thinking about going this route with a 400w while driving MOD for my eco flow delta 2
  12. Feb 17, 2024 at 12:01 AM
    Roadkill69
    @Daulll
    I got a Drok 60v 8A. I tested it decently, may post video.
    1. Seems decent, but instructions to set constant amperage no matter volts are indecipherable.
    2. I set 18v, 5.3A, to get 100W, fed that to power station 100w max port fine.
    3. Set 60v, 6.8A, gave 385W or so. I need to plug a Kill a watt meter into truckbed then power supply tonthat, to see what it is pulling from truck.
    4. I already blew fuse...at 60V 7.85A it blew. Which sux, because it's supposed to be 480W power supply, but not really. The fuse is a 250v 5A, I got one at ACE hardware to replace. The 8A is what blows it. So now I am staying below 7A with it.
    5. I think it is decent, didn't see any voltage or amp fluctuations to worry me about inputting to my power station. Looks like I can run it at 350W or so from truck actually. Will post a video later.
    Here is link
    DROK 60V Power Supply, AC 110V 220V to DC 0-60V 0-8A 480W Buck Converter, Amp Adjustable Adapter Regulated 12V 24V 36V 48V 60Volt Switching Voltage LED Transformer Charger for Computer CCTV Lab https://www.amazon.com/dp/B0B18MM1YZ
    Giffinater and Daulll like this.
  13. Feb 20, 2024 at 9:23 PM
    Daulll
    Saul
    SoCal
    2022 Tacoma OR
  14. Feb 21, 2024 at 7:46 AM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    Can't you just use a pure sine inverter instead of the OEM one to resolve this issue?
    Chew likes this.
  15. Feb 21, 2024 at 7:54 AM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Same. Zero issues charging our Jackery 1000
  16. Feb 21, 2024 at 9:54 AM
    Roadkill69
    If you can find a psw inverter to replace the OEM one, that fits in there, post a link. You'll be the 1st guy in Toyota history to find it.
    You could splice off the wires and stick a new one under passenger seat, then run the output wires back. Or you could just run 12v cables from battery to your bed under the truck. Or you could buy a dc to dc charger and install it and then run cables under truck to pickup bed...
    ... the entire point of this thread, and exercise, is to NOT have to run nrw wires, but to actually make use of what is already installed in the truck ;)
  17. Feb 21, 2024 at 12:25 PM
    Roadkill69
    Good to hear you have an easy solution for your Jackery1000!
    So the Jackery 1000 has a power brick charger, that is basically the same as what I am doing here, using an AC to DC charger/converter. Older power stations, and small ones, used to come with a charger brick like this, to keep the power station small and light. New power stations, and 1500W or larger ones, all come with just an AC cord now. The charger is internal built into their motherboard.
    The Jackery 1000 ac charger can only charge at a max of 180 Watts with that brick. I am trying to make use of the full 400W my Tacoma provides, to charge my power station faster.
    Also, my Pecron will pull 1400W when charging from AC, if it is available! This is enough to trigger the over-current inverter protection on the Tacoma, and shut the inverter off, or even blow the protection fuse. Therefore, I need a device that ON ITS OWN can limit the watts to 400 or below. The old Jackery, charging at 180W max, has been bypassed for charge speeds by virtually the entire industry, all charging at 1000W or more now. So anyone with a newer power station will run into these issues, trying to use the Tacoma bed power supply.
    It's great that your Jackery 1000 lets you just plug in the brick and use it! But it is old battery tech, Lithium Ion not LiFePO4 safer chemistry, and no one who doesn't already have one, and does any research, would probably buy one now, its like buying an iPhone 4 now, but at the price of an iPhone 15!
  18. Mar 4, 2024 at 10:50 PM
    Roadkill69
    Made a new video, showing complete system and using my 480w power supply to charge the power station. Remember, this is a "brickless" power station, if yours has a brick and station pulls less than 400W, you could just use that. But my station will pull 700W and has no brick, so this power supply lets me set a limit of 400w so I don't trip the tacoma inverter.
    @Daulll
    https://youtu.be/QQK6141y1e0?si=7EpwTecwd9ft76wb
    Squam_Taco and grogie like this.
  19. Mar 5, 2024 at 10:38 AM
    Daulll
    Saul
    SoCal
    2022 Tacoma OR
    Great video thanks for the info again I ended up using the RS power supply. The eco flow lets u adjust the power intake on the app I just set it to 300w. So just need to make the time to do the always 400w mod now!
