Using spray foam to fill fenders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Keysmart.info, Oct 30, 2022.
  1. Oct 30, 2022 at 6:06 PM
    Keysmart.info
    Keysmart.info [OP] Active Member
    George
    Ontario, Canada
    2019 Toyota Tacoma TRD Off Road
    Elka 2.5 DC w/ 700 Eibach coils SPC Upper Control Arms JD Fabrications Lower Pivot Relocation 315/70-17 Toyo M/T on Black Rhino Primm Beadlocks Archive Garage Rear Hammer Hangers, shackles & cross member Deaver Stage 2 Leaf Springs w/ U-Bolt Flip C4 Hybrid Bumper w/ 12k SmittyBilt Winch
    So after doing some trimming and cutting of the fender flares the main part that really bothers me is all the mud and dirt flying into the door/hinges… recently some water has been leaking a bit past the door seals (mind you I live in Canada and we have some pretty shitty weather sometimes). So I was thinking of using spray foam to fill that empty part and maybe try to close it up some how.
    I know you can either buy or make your own fenders liners, but I feel like it can also rip off, and foam will harden up and just stick there. Is there anyone that tried it? I will be doing it as soon as I have a good weather and time…
    p.s maybe someone know a good quality product out there that can fill those empty spaces.
  2. Oct 30, 2022 at 6:30 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I wouldn't. Soaks up and holds water/salt. Look at all the rotted wheels on Chevy/GMC. They all had spray foam between box sides and inner wheelwells. That's what cause them to rot out. Same with cab corners, on them and older Fords.
    soundman98, Skydvrr, 513Mugsy and 2 others like this.
  3. Oct 30, 2022 at 9:08 PM
    erok81
    erok81 Well-Known Member
    Imposter
    My fenders are pretty chopped. I just used the factory foam thing, trimmed it, hit with some spray glue, glued it in. Nothing on my doors or hinges.
    Not the best pic but you get the idea.
  4. Oct 31, 2022 at 11:59 AM
    Keysmart.info
    George
    Ontario, Canada
    That gave me some ideas thanks!
    erok81[QUOTED] likes this.
  5. Oct 31, 2022 at 1:26 PM
    erok81
    Imposter
    No problem. Now I have to investigate what that oil splatter is. Hopefully just the tri-flow I may have liberally applied the night before. :fingerscrossed:
  6. Nov 1, 2022 at 11:14 AM
    Stewart
    Stewart Well-Known Member
    Kenosha, Wisconsin
    2017 Red SR MT AC 4x4 long bed
    OR Wheels, cruise, intermittent wipers, carhart seat covers, FT-7900R
    Seems like spray foam and water intrusion is a recipe for rust and probably some pretty good smells after a while.
  7. Nov 1, 2022 at 11:41 AM
    richb70
    richb70 Active Member
    Rich
    19 Pro
    Is this a result of doing a viper cut?
  8. Nov 1, 2022 at 7:41 PM
    Lcfj60
    Lcfj60 Active Member
    2022 Tacoma AC MT 4x4 TRD Sport
    I actually did this on my old 4runner (1985). It worked great for many years... actually improved the rust situation. I just made sure the water had a place to drain.
    I cut the fenders, filled with foam, rolled herculiner on the exposed foam and then painted to match the truck.
  9. Nov 1, 2022 at 8:19 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    What about closed cell spray foam?
