Using Slide Hammer For CV Axle Removal....?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Feb 27, 2021.
  1. Feb 27, 2021 at 5:38 AM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I'm a toolaholic and can't seem to help myself.....
    Has anyone tried using a "hook" attachment on a slide hammer to persuade the CV axle to leave the front diff?
    or.......
    ....using the choker cable method and a slide hammer with a 5/8-18 female rod end. (choker around CV axle, loop bolted to rod end on slide hammer)
  2. Feb 27, 2021 at 5:56 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I tried a BFSH (big fucking slide hammer) without any luck.
    I ended up turning the axle a little bit at a time to find the sweet spot and popped it out with a pry bar.
    These trucks have very stubborn axles compared to the GM trucks I've worked on.
    racerX969 and Crow Horse[OP] like this.
  3. Feb 27, 2021 at 8:26 AM
    Taco'09
    Taco'09 Well-Known Member
    Try the hook but use a couple of screw clamps to help keep it in place.
    Crow Horse[OP] likes this.
  4. Feb 27, 2021 at 10:27 AM
    SunsetDiesel
    SunsetDiesel Well-Known Member
    The slide hammer should help. The sudden shock loads usually does the trick.
  5. Feb 27, 2021 at 12:37 PM
    skimballc
    skimballc Active Member
    Shane
    ABQ, NM
    '07 Tacoma TRD OR DCSB
    I just did one of my axles and used this to make a loop around the end of the axle at the diff, and made a loop on the other end just clear of the hub and stuck a head of mini-sledge through it, yanked hard on the handle twice and it popped right out.
    hinmo24t and Crow Horse[OP] like this.
  6. Feb 27, 2021 at 1:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’ve used it and works great. Little setup time with the clamp to hold the hook in, but it usually pops right off after that
  7. Mar 4, 2021 at 4:16 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
  8. Mar 4, 2021 at 5:54 PM
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    An alternative method is lining up a flat spot on the inner CV and tapping it out with a flat chisel and hammer. I just rotate the CV and tap the flat spots (3 or 4 of them) until it pops free
    wi_taco and TacoFergie like this.
  9. Mar 4, 2021 at 6:36 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I'm preparing for when I do the passenger side. I think I have all the methods of CV axle removal covered - hammer/chisel, pry bar, cable choker w/slide hammer, "hook" w/slide hammer. The only thing I'm missing and it's preventing me from doing the driver's side (with ECGS bushing) is warm weather.
  10. Mar 5, 2021 at 7:21 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    This has been my method on every vehicle I've ever pulled axles on, though a pry bar works as a chisel too if you don't have good clearance....and thats a crap ton on many makes and models. No need to over think this guys.
    wi_taco and Ted Yoder[QUOTED] like this.
