Using S mode as Tiptronic shifter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mastiffsrule, Jul 20, 2021.
  1. Jul 20, 2021 at 2:58 PM
    Mastiffsrule
    Mastiffsrule [OP] Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    What up all,
    I cannot find anything in the manual, here, or Google. Would using the S mode as a trip tonic type shifter cause harm? An example would be towing a heavier load where I wanted to control shift points, or hill climbing since I have a 2WD and want to stay in lower gear longer? (And yes 2wd is better)
    Thanks all.
  2. Jul 20, 2021 at 3:02 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I believe this is what the mode is for. It isn't manually shifting but rather limiting what gears it can use. Generally the truck will yell at you if you shift it into too low of a gear limit, but I'd imagine you wouldn't get there if you're doing it right.
  3. Jul 20, 2021 at 3:03 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Harm?
    No, it's actually much easier on the transmission to hold in a lower gear, rather than repeated shifting and torque converter slip. Both of which generate lots of heat, which can be an auto killer.
  4. Jul 20, 2021 at 3:06 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You can "control" the shift points by when you move the gear selection lever.
    Keep the engine below the RPM redline.
    Remember, the trans will not shift to a higher gear until Shift Control conditions are met.
    Example: You have the selector in "3", it won't shift into "3" until conditions are ready. It will go thru 1st and 2nd, then into 3rd. Gears higher than 3rd are prevented by your selection.
  5. Jul 20, 2021 at 3:07 PM
    Mastiffsrule
    Scott
    I am not sure if I explained myself correctly. I have that problem.
    This makes 100% sense, but I was thinking about staying in S mode as a normal driving mode. Basically making the auto a manual with no clutch if that makes sense. Sorry I’m bad at describing crap like this.
    davidstacoma likes this.
  6. Jul 20, 2021 at 3:09 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    No problem with that scenario. I tow my camper using that method frequently.
  7. Jul 20, 2021 at 3:10 PM
    RedWings44
    Michigan
    All S mode does is limit what gears the transmission can use. Example: if you're stopped and want to take off in 2nd, putting the transmission into S2 will not put you into second gear. It's still in first but it's limiting the transmission to 1st and 2nd gear. The truck will shift as normal up until that limit.
  8. Jul 20, 2021 at 3:12 PM
    Mastiffsrule
    Scott
    Ok,
    I think I got it then. Sorry I am slow on the uptake sometimes.
    This answered it. I basically wanted to control the transmission using the S mode. I wanted a manual of course when I bought my truck but none was available. I didn’t want to break the auto.
    Thanks all, and no one cracked on me. Should have waited until Friday to post:rofl:
    wiljayhi[QUOTED] and RedWings44 like this.
  9. Jul 20, 2021 at 3:15 PM
    Knute
    Don't under estimate the capabilities of the Auto. They are not fragile.
    Let it do its work. Just follow the Owner's Manual when towing and gear selection. All will be good.
    Chew, wiljayhi and Mastiffsrule[OP] like this.
  10. Jul 20, 2021 at 3:16 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Like @RedWings44 said, the S mode is really just an upshift limiter.
    S mode isn't going to hurt in daily driving either. I use it often.
  11. Jul 20, 2021 at 3:26 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Yes you can stay in S mode, I did it on a long trip just recently to see how it performed actually. But as said above by others it’s not like a manual, it limits the highest gear to what you select, If you select 4 then that’s as high as it can go. It can however automatically drop down to lower gears automatically if it needs to to maintain proper rpm for the conditions such as a steep grade or stopping. You can also manually down shift, from 5 to 4 to 3 etc., for engine breaking down a hill for example, or to increase rpm for more power going up a grade. You can up shift as well however it won’t shift unless or until the proper rpm range is reached. From my owners manual (though not that helpful):
  12. Jul 20, 2021 at 3:31 PM
    Mastiffsrule
    Scott
    I read that, but when it said AI shift it threw me off. I was not sure what that was and I gave up reading since the Arby’s drive thru line started moving
    davidstacoma[QUOTED] likes this.
  13. Jul 20, 2021 at 3:35 PM
    davidstacoma
    David
    NC
    ahaha I think it just means the Automatic shift control. as in Drive. Threw me for a bit there too. Might stand for Artificial Intelligence :rolleyes:
