using radio on accessory without the truck running runs my battery down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by farmerfromkansas, Jun 2, 2022.
  1. Jun 2, 2022 at 4:33 PM
    farmerfromkansas
    farmerfromkansas [OP] Member
    2014 regular cab base truck
    My heater fan is off, wonder why my battery runs down just using the radio for 10 or 15 minutes with the key in the acc position, not on, and the truck not running.
  2. Jun 2, 2022 at 4:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like your battery is getting weak, have you had it tested recently?
    wi_taco likes this.
  3. Jun 2, 2022 at 5:18 PM
    Waasheem
    Waasheem
    2007 xrunner
    Like dm93 said, battery is probably getting weak. Sometimes you can find a decal with a month/year. If it's past 3 years and a cheap battery, or 5 years and a good one, it's probably time. If you're in the backyard listening to the radio and got a battery charger, hook it up, then it should start when you're done.
    You'll find several opinions, just like oil, on what's best. I've been a interstate user for years, which I'm now questioning because the last 2 only made it 3 yesrs.
    If you have a multimeter, it might have a peak button. With the engine off, hook it to the battery, set it on dc volts, press peak twice, it might say low, meaning peak low volts. Start the engine. I've seen 10.4v or higher on new batteries. Less than 10 is getting weak. 9.5 or less, time to start shopping for a replacement. Sometimes if you take a battery brush to the terminals and posts, you'll get a better number.
    deanosaurus and Dm93 like this.
  4. Jun 2, 2022 at 5:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Battery life is greatly affected by the climate you live in, in a hot climate like where I am 3 years is the average life of a battery no matter what brand but in a cooler climate you may get 5-7 years out of one.
    My original lasted 4 years, Interstate has been lasting 3 years.
    We sell Interstate where I work so I get them at cost but it doesn't seem to matter what brand you get they all last about the same, just avoid the bottom tier "bargain" batteries that many stores sell.
  5. Jun 2, 2022 at 5:56 PM
    Waasheem
    Waasheem
    2007 xrunner
    Sounds right. When I bought my Tacoma, it had a 8 year old true start Toyota battery that still tested good. But driving it 2 days a week killed it.
  6. Jun 2, 2022 at 6:00 PM
    farmerfromkansas
    Interesting that it is probably the battery. I buy the Johnson controls batteries at Walmart. Years ago I bought 2 car batteries for my combine, and they went bad at 10.5 years. They were 5 year batteries.
  7. Jun 3, 2022 at 12:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Since I maintain the family cars and help my friends with theirs, I bought a battery load tester, or battery analyzer, a Topdon AB101 $40. Its my most used diagnostic tool. Its quick and accurate. I test the batteries at every oil change, before long trips - pretty much, any time I open the hood.
    Last year I told my sister my tool recommended replacing her battery; she procrastinated and her battery died 3 months later, stranding her while running errands.
    winkel and davidstacoma like this.
  8. Jun 3, 2022 at 3:09 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    @Chuy - I see your family & extended family has a lot of Toyota products, and 3 with over 200k miles! Good to see that - I just got my first ever Toyota 3 weeks ago, also an '07 Tacoma 4X4, now with 146k miles.
    Re: batteries - I've checked the oil a few times on mine, this post makes me realize I need to check the date on the battery. It's starting fine, but would be good to know. There's an online reference that indicates typical battery life based on geography. Where I am in the Northeast, it's averaging around 5-6 years. Interesting that in warmer climates it was less.
  9. Jun 3, 2022 at 4:56 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @Stelcom66 Yep, batteries hate heat more than the cold. I couldn't explain the exact cause but the observation stands.
    Stelcom66 likes this.
