using lock instead of pins on max coupler?
Discussion in 'Towing' started by Eagle200, Sep 14, 2023.
  1. Sep 14, 2023 at 6:02 PM
    Eagle200
    Eagle200 [OP] Well-Known Member
    2021 DCLB Off-Road
    I am buying a camper with a max coupler. i read online better to use locks instead of hitch pins. can someone point me to a lock that would be suitable for this job?
  2. Sep 16, 2023 at 7:02 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Search locking hitch pins many to choose from.
    remember always carry what you need to remove the locking pin when it will not unlock.
    reallifedog likes this.
  3. Sep 16, 2023 at 7:56 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    I have a fully articulating hitch and a standard shank and barrel lock that you can pick up from any auto parts or home improvement store’s trailer section will do the trick. If I remember correctly, I bought 5/8 in locking pins. The pic below was to document my generator for insurance purposes but you can see the locking pins on my rig (and one not pictured). I have a locking pin…
    1. On my Taco’s receiver that locks the tongue and female end of the coupler to the Taco
    2. On the trailer where the male part of the articulating hitch joins the female end
    3. On the trailer that secures the male coupler to the trailer
    One thing to note is that locking pins are not tapered so it is a bitch getting the pin into the trailer if it isn’t perfectly lined up. For this reason I keep a t-handle hitch pin as a backup and since it is tapered I can get the trailer close enough that the tapered t-pin will go through, then I remove it partially and insert the locking pin.
    Hope this helps.
    Bivouac likes this.
  4. Sep 18, 2023 at 5:33 PM
    Eagle200
    2021 DCLB Off-Road
    Thanks all
    Bivouac likes this.
  5. Sep 26, 2023 at 12:52 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Remember, you can always use Grade 8 bolts. Not lockable, obviously, but strong enough to do the job.
