Using Jackstands Combined with Rhino Ramps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Apr 13, 2023.
  1. Apr 13, 2023 at 12:18 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    I have a 2WD SR5 Tacoma and I want to do a transmission drain and fill. I need the truck level in order to this, but lifted off the ground. I'm working with very limited space, so my thought was to use my existing Rhino ramps to raise up the front of the truck and two of these jack stands that have bottle jacks in them to raise up the back. Will this work?
    Jack Stand/Jacks: https://www.amazon.com/Alltrade-640...mzn1.fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc
    Rhino Ramps I have: https://www.amazon.com/RhinoGear-11...fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc&th=1
    MGMDesertTaco and RDT415 like this.
  2. Apr 13, 2023 at 12:21 PM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    Ramps up front and bottle jack / jack stands on the rear axle. Use a level to confirm you are level/even.
    Bcjammerx likes this.
  3. Apr 13, 2023 at 12:27 PM
    MGMDesertTaco
    I did rhino ramps under all four tires and supplemented with a couple of floor jacks for extra safety/leveling. Whatever works, just be sure you're safe and the truck is level.
    10thMTNgrunt, mquibble and Stevie17 like this.
  4. Apr 13, 2023 at 12:32 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I live dangerously. No jacking up at all and slight incline driveway. :cool:
    02Duck, econwatch, Stevie17 and 4 others like this.
  5. Apr 13, 2023 at 2:14 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I did something similar last fall and almost killed myself so I would advise against it. I had the front on ramps and was jacking the rear with a floor jack when the truck rolled back off of the ramps and pinned me shoulder to shoulder between the rear bumper and the garage door. I had to twist myself 90 degrees to get out. The jack handle tried to go through the garage door but didn't and that's probably what saved me. I had no major injuries but took months to recover.
    You really want to block the front wheels before you jack the back which you can't really do with them on the ramps. You can put the front on ramps and then jack the front enough to put jack stands under the front and then jack the back (this is the way I would normally do it - I don't know why I decided to do it differently).
    If you do decide to do it, I would recommend figuring out some way to apply the brakes while you are jacking so the front wheels can't move.
    MT_Head, willtill and Stevie17 like this.
  6. Apr 13, 2023 at 3:13 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Make 4 ramps, like these 2 in front at 4 inch lift. You can make them with "drop in" middle sections that resist rolling. You cam make them taller if you need more than 4 in (in my case 2 layers of flat 2x4s and 1/2 in plywood) of extra clearance. Regardless ... solid wood under the tires and drop-in middle sections to prevent rolling.
    Bagman likes this.
  7. Apr 13, 2023 at 3:47 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Those combo jacks look good as some people think bottle jacks are good enough and don’t realize that they are not Jack stands, they are only for lifting. I would also put your spare underneath the crossmember for extra safety in case the stand locks fail. Do those have a locking key? Harbor Freight had to do a recall on similar Jack stands because they’d fall just by accidentally hitting the release lever. So now they have a locking key you can’t pull out when they have any weight on the stand - much safer!
    RDT415 likes this.
  8. Apr 13, 2023 at 6:18 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    If you do not have the right equipment to lift your vehicle, get the dealer or someone with a lift to service your truck. Your life is worth more than a $200 trans service fee.
    Your health ins copay will probably be more than the $200 trans service fee if you injure yourself.
    MT_Head and BumfukKansas like this.
  9. Apr 13, 2023 at 7:47 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Had a similar experience but was fortunate to escape uninjured.
  10. Apr 13, 2023 at 8:28 PM
    RichochetRabbit
    The wood pads were used to install skid plates with rear tires on the ground chocked and e-brake set. But I also knew that I wanted more room to work and could crawl back out if the truck was at normal clearance and I had to get out.
    But only because of all that I was safe-enough.
  11. Apr 13, 2023 at 8:55 PM
    MannyS
    Republic of Texas
    MT_Head and RDT415 like this.
  12. Apr 13, 2023 at 9:09 PM
    RichochetRabbit
    This is the OSHA version of Where's Waldo?
  13. Apr 13, 2023 at 9:15 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Just put back in the amount that ya drained out. Buy a cheap gallon pitcher and mark the spot.
    MannyS likes this.
  14. Apr 13, 2023 at 9:16 PM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    Seems legit.
    The locking feature on those combo bottle/jacks is a nice touch. I’m with ya on the locking pin though, fool proof and won’t pop out under load.
  15. Apr 13, 2023 at 10:32 PM
    erok81
    Imposter
    How do you like this jack stand?
    MannyS[QUOTED] likes this.
  16. Apr 13, 2023 at 11:21 PM
    RichochetRabbit
    This solution seems a tab-bit permanent ...
  17. Apr 14, 2023 at 12:31 AM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    I know the OP has a 2WD, and so using the ramps in the front are a bad idea. But if you have 4WD, then the ramps would work if you place the truck in 4WD first and leave it in park before jacking up the rear.
    I suppose the OP could use the ramps in the rear and jack up the front.
  18. Apr 14, 2023 at 2:21 AM
    Library unicorn
    Library unicorn New Member
    This is my setup when I need a lot of wiggle room, no issues.
  19. Apr 14, 2023 at 9:04 AM
    MT_Head
    MT_Head Well-Known Member
    2023 ELM Tacoma MT
    I just picked up a pair of 6 ton jack stands for like $60. 2 sets and an HF bottle jack will set you back about as much as two of those integrated jacks and be considerably safer
  20. Apr 14, 2023 at 9:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just sayin', but I have done almost all of my maint with the wheels on the ground, including pulling the trans for a throw out bearing swap.
