Using 2" Lifting Blocks to Raise Rear 2"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Jul 23, 2012.
  1. Jul 23, 2012 at 2:30 AM
    parfleet
    parfleet [OP] Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    I installed Rancho Quick Lift Struts to the front of my 05 Tacoma PreRunner about a month ago. At the same time, I installed Rancho heavy duty shocks to the rear. I knew that the Quick Lift Struts could add up to 2 1/2 inches to the front. I was hoping that the heavy duty Rancho heavy rear shocks would add a couple of inches. The end result is that the front of my truck is 2 1/4 inches higher than the rear. I called the Rancho Tech Line and complained. I was told to give it about a month to settle on the front. Well, it's still 2 1/4 inches higher on the front. I was thinking about adding 2 inch block kit to the rear to get it to look somewhat normal. I have read that this is the least desirable of methods to raise the rear 2 inches but it is the cheapest. Has anyone raised the rear of their Tacoma 2 inches using this method and was there any negative consequences? I have left a message with Rancho over the weekend to help me resolve this issue once and for all or I'll get some Monroe Quick Struts, which are OEM, just to level off my truck. Any ideas?
    I'm going back to the dealership this morning to get the front end aligned for a second time. The chamber is still not right.
  2. Jul 23, 2012 at 2:42 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Rear shocks dont give you lift. You should look into getting a 2" Add a Leaf rather than the block. Toytec has them
  3. Jul 23, 2012 at 2:45 AM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Yeah rear shocks are only there to dampen yhe rear movements. The rear is lifted/supported by the rear leaf pack. If anything I'd go with an aal. It's cheap and gives a better ride than blocks
  4. Jul 23, 2012 at 2:45 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    also, please try not to make multiple threads on the same topic :thumbsup:
  5. Jul 23, 2012 at 2:46 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
  6. Jul 23, 2012 at 2:50 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  7. Jul 23, 2012 at 3:47 AM
    CayucosTacoma
    2004 Double Cab 4x4
  8. Jul 23, 2012 at 5:00 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    So you called Rancho to complain since you did not do your homework and didn't buy what was needed to level your truck?
  9. Jul 23, 2012 at 7:52 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    The general consensus is to stay away from blocks. However, I went with a 1 1/2" AAL on mine and still wanted a little more lift so I added a 1 1/2" Block a couple of weeks ago and I don't have any issues. I think as long as you stay at a 2" or smaller block you will be fine. The downside of running blocks is that it can cause issues with axle wrap and it can cause your leafs to wear out sooner. I don't have any issues with wrap and my leafs have 152,000 miles on them, so I don't think I can do much else to them. The positive side of adding a block is that it doesn't change the ride of the truck and it's cheap and easy to install. Let me add that if you are going this route you will want to make sure your shocks are long enough to handle the increased height.
