Used Leaf Springs from v6 base to I4 base?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wabisabi, Jan 31, 2020.
  1. Jan 31, 2020 at 12:49 PM
    Wabisabi
    Wabisabi [OP] Active Member
    2012 SR5 2.7 5spd man 4x4 AC
    I have a 2012 Base 2.7l 4x4 115k miles that sagged a good amount with 10 bags of 50lb wood pellets in it (500lbs). I am thinking that it may need some new leaf springs, as it also bounces a fair amount in the rear over bumps.
    On CL nearby are some leaf springs with 3 leafs plus the fourth shorter one on the bottom. Mine have only 2 leafs with the one shorter one on bottom. I know the truck it came off was a v6 2006. Does it matter? I do not a lift, just for the ability to handle more weight and improve the ride.
    Anything I should know or find out?
    Thanks,
  2. Jan 31, 2020 at 12:51 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    14 year old springs are gonna be just as beat as yours. Find some takeoffs from a 3rd gen.
    whatstcp likes this.
  3. Jan 31, 2020 at 1:03 PM
    Wabisabi
    Thanks for input... I forgot to mention these used springs were new in 10/17 when frame was replaced, and the were used for about 1 year before being taken off... so they are only about 1 year old.
    IS there a difference btwn 3rd gen and 2nd gen, other than age?
  4. Jan 31, 2020 at 1:05 PM
    hoarder23
    Shay
    NJ
    Scratches
    Then they would be a decent replacement, if the price is right.
  5. Jan 31, 2020 at 1:22 PM
    Wabisabi
    Good to know... I am wondering if these would be a slightly more expensive but better fit and guaranteed not to be compromised already:
    2005 - 2015 Toyota Tacoma 4x4 / Prerunner Heavy Duty rear leaf spring, 4(3/1) leaves $169 each
    https://www.generalspringkc.com/product_p/90-297hd.htm
    BillsSR5 likes this.
  6. Jan 31, 2020 at 1:25 PM
    hoarder23
    Shay
    NJ
    Scratches
    Those are a solid option, just be aware that's the price per each, not a pair.
  7. Jan 31, 2020 at 1:27 PM
    Wabisabi
    Yeah, maybe worth it, as it looks like would increase payload over OEM.
  8. Jan 31, 2020 at 1:29 PM
    Wabisabi
    The $100 for shipping makes it a bit less appealing...
    $442.40
    without hardware.
  9. Jan 31, 2020 at 10:28 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Just installed those springs on my 12 double cab 6 ft. bed SR5 last weekend. So far I like them. My truck had the 4 leaf pack to start but the third leaf broke on both sides. These springs are heavier than the stock springs and lifted my rear end even with a cap. In a few weeks I will start a thread reviewing these springs (after they have settled).
  10. Feb 1, 2020 at 6:47 AM
    DG92071
    DG92071 Well-Known Member
    Do the 3rd gen rear springs lift a 2nd gen?
  11. Feb 1, 2020 at 7:05 AM
    hoarder23
    Shay
    NJ
    Scratches
    No
    DG92071[QUOTED] likes this.
  12. Feb 3, 2020 at 3:48 PM
    Wabisabi
    Look forward to hearing how these new leaf spring are Hugh Morron.
    I am gonna keep looking on CL and see what comes up, will plan on doing leaf and front and rear struts. I am not looking for lift, are the front coil overs different for V6 and I4?
  13. Feb 8, 2020 at 7:26 AM
    Wabisabi
    Good news, just bought the suspension off 2019 TRD front coilovers, rear shocks and leaf springs, with less that 5k miles for $250. Any sense if there will need to be any other mods on the ECGS bushing, or diff drop or carrier bearing (tbh, I don't know what any of these are, just reading about them in the lift sections).
    Now for some PB Blaster time...
