Use 4h on highway about one hour, is that hurt anything?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coyote1999, Feb 18, 2021.
  1. Feb 18, 2021 at 4:48 PM
    Coyote1999
    Coyote1999 [OP] New Member
    2000 Tacoma
    Hi , everyone, I forgot turn off the 4h on the highway about one hour, I drove 80 miles per hour, is that will be hurt anything?thanks
  2. Feb 18, 2021 at 4:50 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    As long as you didn't do any sharp turns on dry pavement, you will be fine. You can drive in 4h for as long as you please
    When the weather is bad I drive for hours in 4h
    Foster1, cr1k3t and Speedbird like this.
  3. Feb 18, 2021 at 4:57 PM
    Coyote1999
    2000 Tacoma
    Even 80 miles on dry highway ? forgot turn off the 4h after off-road twice, I really worry about hurt 4x4 system,you make me feeling better, thanks .
  4. Feb 18, 2021 at 5:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If everything is still working, you are probably just fine. There's not much you can do now anyway. :)
    Turning while in 4wd puts extra stress on your drivetrain, but doesn't destroy it instantly. In situations where you really need 4wd (e.g. off-road), it's still almost impossible to avoid all bind-up. Surface traction varies and you sometimes need to make a turn on a surface that has fairly high traction (e.g. rocks). It's just needlessly hard on your drivetrain to make turns in 4wd on dry pavement.
  5. Feb 18, 2021 at 5:07 PM
    gudujarlson
    Minnesota
    Driving in a straight line in 4wd on dry pavement is not going to put a lot of stress on your drive train. It's turning that is the problem. You'll notice that right away if you try to make a sharp turn on dry pavement in 4wd. The truck will resist the turn and then spin the tires. Try it once very gently at slow speed and you might get an intuitive feel for it. What's happening is that 4wd locks the front and rear axle together so that they must turn at the same speed but during a turn the road won't let the axles turn at the same speed. Something has to give; usually it is the tires losing traction and spinning. I'm guessing there are worst things you could do to your truck that Toyota isn't bothering to inform us because they are much more obviously bad (e.g. burn outs, jumps, power slides, climbing the back door in Johnson Valley, etc).
  6. Feb 18, 2021 at 5:08 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    If it’s still rolling down the road it’s OK. Is it ideal? No, but sometimes knowledge hurts in the long run and your components may wear out the very next time you try and use four-wheel-drive.
  7. Feb 18, 2021 at 5:17 PM
    TRDCal
    Canada
    2018 DCSB Sport MT
    Yes. You only hurt the 4x4 system if you cause binding (turning on dry pavement). If you're driving straight, all wheels are traveling the same speed so you're not binding it. No binding = no hurt.
    One caution, you can engage/disengage 4HI while moving but it has to be below a certain speed speed (I forget the exact speed but I think it is 60mph, look on your sunvisor). 4LO is a different story, must be stopped for engaging/disengaging that.
    Look up some videos on YouTube, that will probably help you understand better than a bunch of idiots on an internet forum.
    2000prerunner23 likes this.
  8. Feb 18, 2021 at 5:20 PM
    gudujarlson
    Minnesota
    I resemble that remark.
    McFlysRide likes this.
  9. Feb 18, 2021 at 5:22 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    no. it's cool as a cucumber in there.
    I don't know why people think they can "wear" out the 4x4 by doing little things like that . It's not like a bunch of wearable parts like clutches, or break pads, or fluid/seals holding it together. It's essentially solid metal gears meshing just like a differential. I mean sure you can wear out metal gears too over time or even the CV joints (the spherical balls and cage), but it's more of like snapping them then it doesn't work at all.... so it would be works good, good, good, boom breaks catastrophically all at once. I guess what I'm trying to say is if you didn't break it by doing what ever you did (driving in 4H on the road, or smashing it over the rocks) then it's probably totally fine... until it breaks completely. . wait what? you get what I'm saying!
  10. Feb 18, 2021 at 5:44 PM
    TRDCal
    Canada
    2018 DCSB Sport MT
    Haha so do I! I should have put a smiley in there, hopefully someone doesn't take me seriously lol
    Taco2022 and gudujarlson[QUOTED] like this.
  11. Feb 18, 2021 at 5:47 PM
    Myles G
    Myles G Well-Known Member
    Myles
    You’re fine
    ndoldman59 and shakerhood like this.
  12. Feb 18, 2021 at 5:52 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    My first gen makes this super obnoxious beeping sound and the 4wd indicator light flashes but it will not engage when you try to put it 4hi going more than 60mph. I have a push button on the side of the transfer case shifter. I've used it to wake up a sleeping passenger before...works well.
    I wonder if 3rg gens have something similar?
    Lt. Dangle likes this.
  13. Feb 18, 2021 at 5:53 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2006 5.9 Cummins , 2018 4Runner, 2025 gx550
    I’ve done more 4wd locked launches when I had my diesels then most could fathom. Every diesel that launches in a 1/4 mile drag uses 4wd. You have nothing to worry about.
    Lt. Dangle, skiploder and otis24 like this.
  14. Feb 18, 2021 at 5:56 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah you'll just wear out tires faster than you'll wear anything else out in 4h.
  15. Feb 18, 2021 at 6:01 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You hurt your wallet when you fill up!
    Otherwise, absent of sharp turns, you're probably ok. But try not to make a habit of it.
  16. Feb 18, 2021 at 6:41 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    It's totally fine.
    ndoldman59 likes this.
  17. Feb 18, 2021 at 7:03 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Half the kilometers my truck have on it are in 4H. It'll be fine. 75mph on snowy highways, but going straight it doesn't matter too much what surface you're on. Worst thing that you inflicted was a slight amount of wasted fuel lol.
    shakerhood likes this.
  18. Feb 18, 2021 at 7:10 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is a habit I have gotten into. When I put it in 4HI, I switch the center combo meter to an obscure screen. As I glance down to check my speed, I am reminded I am in 4HI.
  19. Feb 18, 2021 at 7:12 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    Unless you heard a BOOM you are fine
    Taco2022 likes this.
  20. Jul 24, 2021 at 6:21 PM
    TRDCal
    Canada
    2018 DCSB Sport MT
    As long as it's not making any funny noises and everything is working properly, you're fine. The system can handle a bit of abuse, I certainly wouldn't make a habit of it though
