USB won't recognize memory stick or phone
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnlyOneKeano, Aug 3, 2017.
  1. Aug 3, 2017 at 12:16 PM
    OnlyOneKeano
    OnlyOneKeano [OP] Active Member
    2017 Tacoma TRD upgrade
    Hey guys
    I just picked up my 2017 Tacoma TRD and the USB won't recognize my phone or my memory stick.
    I'm taking it back to the dealer in the morning for detailing and I'll speak to them about it then however I just thought I'd ask here.
    Anyone else have this issue? And any idea on potential fixes?
    Thanks guys!
  2. Aug 3, 2017 at 1:07 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Should just be able to stick in the stick with MP3's on it and it should play; however, it does have rules like.....
    Must have folders for Artist, etc.. It's in the manual..
  3. Aug 3, 2017 at 1:21 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Follow this guide, I had the same issue with regards usb stick.
    https://www.tacomaworld.com/threads/stealth-x-tacoma-maintenance-and-stuff.472106/#post-14301603
    As for your phone.....that's likely not normal.
  4. Aug 3, 2017 at 1:25 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    The stick cannot be greater than 16G. Not sure about phone. I have no problems with my phone or ipod.
    EB Group likes this.
  5. Aug 3, 2017 at 1:30 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Oldman808, over60 and EB Group like this.
  6. Aug 3, 2017 at 2:33 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    OnlyOneKeano[OP], over60 and Garyji like this.
  7. Aug 3, 2017 at 4:27 PM
    over60
    Muskoka, Ontario
    Plus 1 on this ^^^^... I've got the same mini stick and it will work with lots of tunes....!!
  8. Aug 3, 2017 at 4:44 PM
    Railrider
    Railrider Member
    2017 dlbcb trdor
    I just used a new 32gig formatted to fat32, works fine
    over60 and OnlyOneKeano[OP] like this.
  9. Aug 3, 2017 at 5:15 PM
    Tunngavik
    Alberta, Canada
    I've got same one - 32 GB formatted to FAT32. Works fine on my 2nd Gen.
  10. Aug 3, 2017 at 5:36 PM
    OnlyOneKeano
    EB Group[QUOTED] likes this.
  11. Aug 3, 2017 at 5:38 PM
    OnlyOneKeano
    Thanks for the reply
    I will attempt to format shortly.
    The USB stick is functioning fine in other devices (laptop etc)
  12. Aug 3, 2017 at 6:22 PM
    ayatollah
    ayatollah Member
    Just Outside the Tragic City in AL
    2017 TRD Off Road
    You can also cruise on over to http://www.verbatim.com/index/search.php?words=fat32+tool and download the SmartDisk_FAT32_Tool (Verbatim FAT 32 Tool). With this you can format flash drives larger than 32GB as FAT32 in Windows. I have a 64GB drive formatted as FAT32 that I keep in my truck and it works like a charm. Just plug in your flash drive, launch the executable and format.
    If you use this tool, make sure you don't have any other drives plugged in somewhere or just be very sure of what you're about to format.
    EB Group and OnlyOneKeano[OP] like this.
  13. Aug 3, 2017 at 6:45 PM
    nartmot
    nartmot Well-Known Member
    I noted this in another thread but basically when I plug my Samsung Note 5 into the USB port, it pretty much stops the USB port from recognizing or even supplying power to anything else. The thread is here: https://www.tacomaworld.com/threads/usb-port-issue.415115/page-2. My workaround is to turn the truck off and then back on again. The USB port seems to work fine with everything except my Note 5.
  14. Aug 4, 2017 at 12:18 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    fat 32.........got 1000 songs on my 32 gig stick,, i did have to devide them into 2 separate folders to get all songs reconized
  15. Aug 4, 2017 at 12:30 AM
    OnlyOneKeano
    I will format my card to FAT32 and update you guys. Thanks for the help.
    That still doesn't explain my phone though?
  16. Aug 4, 2017 at 12:39 AM
    smuckers
    smuckers :: cough cough ::
    Los Angeles
    Wish list: 17 TRD OR DCSB 4X4 6MT
    does anyone know if the stock radio play m4a/aac?
  17. Aug 4, 2017 at 1:32 AM
    OnlyOneKeano
    So I've reformatted to 'MS-DOS FAT', retransferred my music and it all worked fine.
    Thanks to all who replied for the very helpful information.
    I'm not sure if this issue is in any of the 3rd Gen Forum stickies ('mods and tips' or 'tips and tricks'), and I also don't know if I can add this to either of those, so I will summarize my issue with all the specifics, so if its unique or not been mentioned, it can be added.
    Memory Card - SanDisk MicroSD 64gb SDXC
    Operating system - MAC OS
    Vehicle - 2017 Tacoma DCLB TRD Upgrade Package (stereo with knobs at the bottom)
    Original Memory Card Format - ExFat - Not sure if this is how it came or if this happened when I first (brand new out of the box) plugged it into the MAC
    Reader: Using a simple Lexar microSD memory card reader that came with a Lexar memory card I bought last year
    Program used: Disk Utility (a program I believe comes pre-installed on all Macs)
    Procedure:
    1. inserted the reader with the memory card into the MAC and backed up all the files from it on to a separate folder on the desktop.
    2. Opened the program Disk Utility
    3. Selected the memory card (icon that looks like a hard drive) on the left of the screen
    4. Noted the format that it was in (written just below the name of the drive in the main screen)
    5. Of Five icons at the top Clicked 'Erase' which opened a pop up window
    6. Changed the name of the drive, and chose format MS-DOS FAT from the format drop down menu
    7. Clicked Erase in the same pop up window to confirm the action
    8. After the process finished (took about a minute, may be longer dependant on how much is on the card) I properly ejected the drive, removed it and plugged it back in
    9. Selected the memory card on the left of the screen (in the Disk Utility App)
    10. Noted that the format had been changed to 'MS-DOS FAT'
    11. Re-transferred all the files into the card from the back up folder I had placed on the desktop
    12. Ejected properly, removed it and plugged it into the USB in the truck
    13. Pressed 'APPS' on the stereo, and found that I could now click the 'USB' icon (it wasn't greyed out anymore) and VOILA all my music showed up, in folders for artists, exactly like I had transferred it onto the memory card.
    I hope this information can be useful to others!
    Again thanks to all who replied today, and assisted me in solving this part of the issue.
    I now need to tackle the phone not being recognized by the USB system, and if anyone has any ideas, i'd greatly appreciate it!
    taco2018x, EB Group and Tunngavik like this.
  18. Aug 4, 2017 at 2:15 PM
    EB Group
    Rudy
    Halifax
    Well that is telling. Interesting. Since the USB reformat worked I would try plugging in another phone maybe a Samsung or whatever, just to see if it's the Xperia that the tacoma doesn't like.
  19. Sep 2, 2017 at 10:23 AM
    Neil K
    Neil K Member
    Kamloops BC
    2017 Inferno TRD
    I am new to the Tacoma and I am having trouble understanding how to get the folders display in any kind of understandable order. Could you point me to the pages in the manual that explain how they must be setup?:confused:
  20. Sep 2, 2017 at 10:31 AM
    Lunabird
    Lunabird Well-Known Member
    It won't read folder but will only categorize based on artist, genres and composer. Pretty lame right?
