USB LIGHTNING PLAYBACK ISSUES W/ENTUNE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 21cookie, Oct 17, 2020.
  1. Oct 17, 2020 at 3:54 AM
    21cookie
    21cookie [OP] Member
    Happy Valley, OREGON
    2019 Black Tacoma TRD PRO
    Got a 2019 taco and an iPhone X that used to be able to play music directly through the usb lightning connector. After I updated my iPhone to the newest IOS 14, every time I try playing Spotify while connected to the usb connector it says, “There are no music files to playable.” I also updated entunes but still ain’t working. Bluetooth still works but I like the sound quality when connected directly with the usb lightning better. Don’t think an iPhone X is too outdated for the system...any ideas?
    tacodreamer11 and diggyhawkins like this.
  2. Oct 17, 2020 at 3:59 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I'd be more willing to bet it is something on Apple's end
  3. Oct 17, 2020 at 6:04 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Apple is always having issues, especially after an update to their OS. Try deleting your phone from the head unit and removing the truck from your phone. Then pair the two together again.
    musicisevil likes this.
  4. Oct 17, 2020 at 7:22 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I haven't experienced any issues since the last Apple IOS update and keep my phone plugged into the USB port almost all of the time. I do use ApplePlay to play any apps on the phone however.
  5. Oct 17, 2020 at 10:18 AM
    21cookie
    Bluetooth still works. Unless you’re saying there’s a way to disconnect from the physical connection, which I have no idea how to do
  6. Oct 17, 2020 at 10:20 AM
    21cookie
    Sigh. I was only one year away from CarPlay..
  7. Oct 17, 2020 at 10:26 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    What kind of cord are you plugged in with? From the phone to the usb
  8. Oct 17, 2020 at 11:20 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    My bluetooth fails to connect all of a sudden. Wtf?
  9. Oct 17, 2020 at 11:39 AM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Had a slow moment. If it's an OEM cable from apple, try another one. If it's not OEM, then try an OEM cable. That would be my only suggestion as apple and I don't play well together. If that doesn't work then I'm sure others will be able to assist you more than I can.
  10. Oct 17, 2020 at 6:22 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    997A5CE8-D124-4003-A986-FED2602B74CA.jpg 997A5CE8-D124-4003-A986-FED2602B74CA.jpg 7A97B000-39C7-442C-9587-5092296EAE5C.jpg I had problems with my cable connection also. After some research what I found was a lot of guys fixed that part with the better apple cable. It’s a thicker cable that goes from usb type c to lighting. Then you grab a type c to big boy USB adapter and it solved it for me. I can connect my 11 or my wife’s also my daughters se works fine with it now. I’m not using the same hu as you 3rd gen guy’s I’m running a kenwood 907s but the problem was the same.
    tacodreamer11 likes this.
  11. Oct 3, 2021 at 5:57 PM
    WhiteySR
    WhiteySR New Member
    SOLVED: There are no songs available for playback. Please add compatible files to your iPod.
    Apple CarPlay requires at least 1 song in Apple Music Library to recognize your device using USB. I purchased and downloaded 1 song from iTunes Store and USB is now working with Spotify, etc.
  12. Oct 3, 2021 at 6:18 PM
    imtaso
    imtaso Well-Known Member
    Connecticut
    2020 trd pro
    Many
    I had similar issue, turned out it was my phone socket, worked fine after I cleaned it out, dust and lint. Hope it’s that easy for you.
  13. Jun 28, 2022 at 4:17 PM
    Climberdimer
    Climberdimer Member
    ‘15 Tacoma Double 4x4 LB
    my 2015 (stock stereo unit) just started doing this as well. Bluetooth works. Lightning cable swap to OEM did not clear the issue. Delete and reintroduce did not fix the issue. Gonna add a beefier cable (USB-C stepped down) and see what gives. Phone port is clean, wife's iPhoneX did the exact same thing as my SE. Ugh.
  14. Jun 29, 2022 at 8:10 PM
    Climberdimer
    Climberdimer Member
    Hopefully SOLVED. A buddy of mine plugged HIS iPhone in and it worked fine. So, he recommended I install Apple Music app to my phone. Did. Now it works as it did. Not sure why. Not sure I care. Try it.
    ktbell444 likes this.
  15. Oct 20, 2022 at 8:55 AM
    diggyhawkins
    diggyhawkins New Member
    Derrick
    2019 Tacoma TRD Sport
    I just purchased my truck two weeks ago, and I am having the exact same issue. I spent the morning at the dealership, for them just to tell me that they don’t know what’s wrong with it. And that it because it’s a 2019, it doesn’t have in tune/CarPlay. I just tried downloading Apple Music check, it didn’t seem to help. Would really like to know what to do,
  16. Oct 20, 2022 at 8:57 AM
    diggyhawkins
    Derrick
    Not sure if it’s worth mentioning, but I had a 2020 Camry prior to this truck, and it worked just fine. Same cord same phone
  17. Oct 20, 2022 at 9:25 AM
    Climberdimer
    Climberdimer Member
    Sounds funny, but download Apple Music app onto your new phone. Even tho I don’t use Apple Music, all my Spotify crap came back. Worked for me
    diggyhawkins likes this.
  18. Oct 24, 2022 at 10:46 AM
    diggyhawkins
    Derrick
    interestingly enough, the downloading a song from Apple Music worked!! I bought one song for .69 and everything’s fine now.
  19. Oct 24, 2022 at 10:54 AM
    Climberdimer
    Climberdimer Member
    AND, apple now has .69 more cents of ours…
  20. Mar 1, 2023 at 10:04 PM
    jovanyesteban
    jovanyesteban New Member
    Jovany Esteban
    Tacoma 2018
    HOW I SOLVED IT AFTER A YEAR:
    Make sure you have the “ITunes Music” app.
    You have to buy a song and have it downloaded to your phone. This way it will recognize the phone as an “ipod.”
    After buying one song and downloading it you can go back to spotify and use it. Don’t delete the downloaded song or the ITunes Music.
    Making it clear i fixed it by downloading “ITunes Music” NOT “Apple Music”
