USB Charging Interferes With Bluetooth Music?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hollywood459, Feb 4, 2016.
  1. Feb 4, 2016 at 7:12 PM
    Hollywood459
    Hollywood459 [OP] Active Member
    Woodstock, GA
    2012 DCLB TRD Sport 4WD - Magnetic Gray
    Has anyone encountered the issue where while bluetooth streaming music, you plug your phone into the USB port to charge it, and it cuts off the music? I can see on the head unit's display that the music has been paused, so then I press play on my phone, can see the track time continuing (on my phone), and the word "paused" disappears from the head unit's display. But no sound will come through the speakers. BUT - if I unplug the phone from the USB charging cable, and press play again, voila - the music comes back! This is driving me crazy. It's useless to not be able to charge your phone and play music via bluetooth at the same time!! :mad::annoyed:
    Side note - I was able to beat this issue by plugging my usb cable into a cigarette lighter USB adapter... but I can't use the USB plug in the dash without having the above mentioned issue.
  2. Feb 4, 2016 at 7:21 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Your giving your phone 2 outputs for the music to go through, so it gets confused on which one it should use. Get what I'm sayin'?
  3. Feb 4, 2016 at 7:28 PM
    Hollywood459
    Woodstock, GA
    That would make sense if it was the AUX input I was talking about... but I'm just referring to the USB jack. Which is only capable of providing power for charging the phone, and not capable of transmitting audio signals.
  4. Feb 4, 2016 at 7:29 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Change phone to charge only.
  5. Feb 4, 2016 at 7:31 PM
    Ihatetacomas
    Dylan
    Elko NV
    Wait wait, so you CANT play music through your USB connection? Even with the Bluetooth turned off on your phone? My iPhone is able to do that but I don't know what kind of phone you have or if you have the tech package
  6. Feb 4, 2016 at 7:33 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    The USB jack is linked to the Head Unit (Stereo). That way you can upload software updates or play MP3s off a USB drive.
    So, as mentioned above the phone can't figure out whether to play by Bluetooth or USB.
  7. Feb 4, 2016 at 7:33 PM
    Hollywood459
    Woodstock, GA
    You can't use USB to transmit audio... You can use the AUX input (3.5mm) jack to do that, but not the USB port.....
  8. Feb 4, 2016 at 7:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Yeah but your phone may not realize that. There IS a data connection between the USB and the Head Unit. So there is some connectivity happening even if you can't use it.
  9. Feb 4, 2016 at 7:36 PM
    Ihatetacomas
    Dylan
    Elko NV
    Turn off your Bluetooth on your phone, it might work! The cord does more than just charging, I promise
  10. Feb 4, 2016 at 7:39 PM
    Hollywood459
    Woodstock, GA
    Ah, had not thought of the concept of playing MP3s from a flash drive... That makes sense. But... I'm assuming music on an iPhone etc. would not be playable through the USB jack since it is not likely in MP3 format (AAC, etc. most likely). So does this mean there is no solution to being able to stream bluetooth audio and charge your phone via the dashboard USB plug at the same time?
  11. Feb 4, 2016 at 7:39 PM
    Hollywood459
    Woodstock, GA
    I will have to try it... Completely did not think that could be a possibility, but I will check it out. Thanks for the tip.
  12. Feb 4, 2016 at 7:47 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I've seen folks here on TW that have installed USB charging ports in their dash that are NOT connected to the Head Unit. Last time I plugged my phone into the USB it wouldn't actually charge...
  13. Feb 4, 2016 at 8:02 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    That's incorrect. When you plug in your iPhone, the HU should recognize it as an audio source. For example, mine comes up with ___'s iPhone as an audio source ALONGSIDE Bluetooth. Mine does the same thing you're describing when I'm Bluetoothing audio and then plug it into the USB to charge. Playback stops and either I hit play (to continue playing over Bluetooth) or I switch to ____'s iPhone in the source menu (to play through USB).
    After plugging your phone into the USB port, I would try:
    1. Open the audio app you're using on your phone (Music, Pandora, etc) and select the AirPlay icon (looks like a rectangle with a triangle pointing up at the bottom) and make sure it's going to to your truck and not the phone.
    2. Go to your audio sources and select either USB or ___'s iPhone.
    Of course you have a 2012 and I have a 2014, which I know are different, but I'm assuming they're not WILDLY different. If you have one, try plugging a plain old iPod into the USB jack. It should let you play music off of it without Bluetooth.
  14. Feb 5, 2016 at 7:08 AM
    Hollywood459
    Woodstock, GA
    So what I've found is that I can plug in the phone via the USB port and then tap AUX on the head unit once to make it change from "searching for" a BT device input to the USB input. And you are correct, it does automatically play music through the USB input! Would definitely have never assumed that would work! My previous Taco was a 2008 so it didn't have all these cool features, ha... I'm going to do some additional "combination" investigating when I get a chance, but at least now the original issue is solved. Thanks for all the help, guys! :thumbsup::bowdown:
    Ihatetacomas likes this.
  15. Feb 5, 2016 at 7:40 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Glad you got it working!
  16. Feb 5, 2016 at 11:10 AM
    Ihatetacomas
    Dylan
    Elko NV
    Woo!
    @Kyitty that may be a cord problem, mine quit unexpectedly on me after a year and a half of never leaving my vehicle
  17. Feb 5, 2016 at 11:58 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    When you plug an iPhone into a USB port, it goes into iPod mode and can interfere with the bluetooth for phone calls. If you are just using it to charge your phone then I suggest using the 12v port instead. That USB port doesn't put out much power as it was designed as an iPod connection. The 12v port will charge your phone faster. As others have mentioned, it would be better to use a Windows formatted usb thumb drive or get a dedicated iPod. You should have more control over your music using the radio with usb than with bluetooth.
  18. Feb 5, 2016 at 12:31 PM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Mine takes phone calls over BT as normal when it's plugged in to the USB as an iPod.
  19. Feb 5, 2016 at 2:22 PM
    Hollywood459
    Woodstock, GA
    Yea, this is one of the "combinations" I was going to test this weekend. I would assume that should be perfectly possible, but the original issue I was having made it seem like I could have an issue with that as well. I'll post my findings for the different scenarios once I have them.
  20. Feb 5, 2016 at 3:12 PM
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    Hollywood459,
    When you play music on your phone using “Bluetooth” and connect the “USB” connector at the same time, the USB takes precedence hence you will not be able to hear music via the Bluetooth “source” selection on your head unit but you will hear in on the USB/Ipod headunit source. By the way, music via the USB cable sounds very much better than via Bluetooth. Godspeed.
