USB charger can't keep up with phone
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scritch, Nov 4, 2017.
  1. Nov 4, 2017 at 9:02 AM
    scritch
    scritch [OP] Well-Known Member
    john
    2017 Tacoma SR5 Double-Cab Long Bed
    None as yet
    I have noticed that my USB cable can't charge the phone as fast as the phone needs, at least when running Google Maps for navigating, or when streaming music via Bluetooth.
    Is the USB port low on power, or could it be my older phone (Samsung S4) or the cord?
  2. Nov 4, 2017 at 9:04 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Could be the cable. Get the thickest gauge cable with the shortest length absolutely necessary.
    See old USB would be alright as these phones were low voltage ~5v and didn't need high amperage to charge. As the phones get more aggressive and USB charging rates go up we need better and better cables to reliably carry that voltage.
  3. Nov 4, 2017 at 9:05 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Broken
    over60 likes this.
  4. Nov 4, 2017 at 9:05 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    More than likely it's heat related. The phone will change it's rate of charge based on how hot it's getting. If I mount my phone on the vent with the heat on, it won't charge at all. Try keeping your phone cool. Also, it could be dirty inside which would cause it to run hotter.
    Canufixit likes this.
  5. Nov 4, 2017 at 9:37 AM
    scritch
    john
    None as yet
    So, a charger plugged in to the cigarette lighter might be better?
    4X4Flyr likes this.
  6. Nov 4, 2017 at 9:40 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    The built in USB is only 1amp which is a slow charge for new smart phones. You will need to use your own 12 volt adapter with a 2amp output
    Big tall dave and TacoCat like this.
  7. Nov 4, 2017 at 9:41 AM
    Junior314
    Junior314 Well-Known Member
    Northeast
    '17 MGM OR DC/SB
    Cosmetic.
    What he said.
  8. Nov 4, 2017 at 9:41 AM
    Hoangde
    Hoangde Well-Known Member
    The built-in Usb port not made to charging the phone. It is to use as data port for media player and firmware upgrade. The port only provides up to 500mA (standard industry specifications).
    If you have your smartphone screen on at all time then you need at least 1A just to provide enough power for that application,
  9. Nov 4, 2017 at 9:44 AM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    AmazonBasics Dual-Port USB Car Charger for Apple & Android Devices - 4.8 Amp/24W, Black/Red https://www.amazon.com/dp/B072C7R4CD/ref=cm_sw_r_cp_apa_13E.zbJTJWE6T
    This is the charger I have been using for years now. Both ports are two amps so a passager can also charge their phone quickly. And to keep the clutter down its plugged into the 12 volt port in the center console.
  10. Nov 4, 2017 at 9:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Get one of these (Edit: or the one above that I didn’t see while looking for it):
    https://www.amazon.com/AUKEY-Charger-Output-iPhone-Samsung/dp/B00M6QODH2?th=1&psc=1
  11. Nov 4, 2017 at 9:57 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Wal-Mart has 12v to USB adapters for $5
  12. Nov 4, 2017 at 9:59 AM
    OnHartung'sRoad
    ...this is the best one, it has the added benefit of getting to mall crawl for it!! :)
  13. Nov 4, 2017 at 10:05 AM
    Plain Jane Taco
    USA
  14. Nov 4, 2017 at 10:29 AM
    Plain Jane Taco
    USA
    Says the guy with a street-bound PreRunner. :anonymous:
    grubburg likes this.
  15. Nov 4, 2017 at 12:53 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    That USB port on the dash is for INPUT......!!
  16. Mar 7, 2020 at 8:41 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
  17. Mar 7, 2020 at 9:15 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i have similar. very nice to monitor electrical system voltage (typically 13.7VDC) when not using usb ports. when using usb ports (on mine anyway) the readout is useless.
