URD MAF Calibrator Installed; Now Check Engine Light!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocsTacoma, Aug 18, 2014.
  1. Aug 18, 2014 at 6:44 PM
    DocsTacoma
    DocsTacoma [OP] Well-Known Member
    DFW, Texas
    2012 Tacoma DCSB 4WD //TRD Sport
    BFG Mud-Terrains, TRD Skid Plate, TRD Exhaust, AFE Pro Dry-S Air Filter, Flyzeye Interior LED Light Bar, Bilstein 5100's (Front @ 1.75"), Firestone Ride Rite Air Bag System, Avid Light Bar
    Truck: 2012 Tacoma TRD Sport 4x4
    Engine: 4.0L V6
    Intake: Volant CAI (powercore dry filter) with intake scoop
    Exhaust: TRD cat-back exhaust
    I recently installed the Volant CAI intake on my truck (no issues), and after doing extensive research, decided to go with the URD MAF calibrator to maximize my gains from the CAI.
    Shortly after receiving the MAF calibrator, I was told that URD did not currently have a map/tune for the Volant CAI system! Therefore, I was given a "blank" MAF calibrator, and told to tune it myself. :eek:
    So, I contacted my local dyno shop, and got the truck in there this morning. We put it on the dyno and ran the software (Split Second R4 engine management) and he began tuning the map (results posted below). It was dynoed on a Dyno Dynamics dyno, which I was told, reads much lower than a Mustang Dyno (for what its worth)!
    3 hours (and $350) later, we reached a plateau at around +16whp! During the process, we got several check engine lights; all of which were cleared with an OBDII reader.
    I left the shop, and shortly after got another check engine light (P0101) along with the "traction off" light!
    I have no idea what is going on, and based on this experience, I'm considering removing the URD (piece of sh*t) calibrator :smash::annoyed::facepalm:, reconnecting the ECU wires, and going with a Unichip!
  2. Aug 18, 2014 at 7:11 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    10% increase is pretty nice for anything less than a blower. Sorry im no more help than that but do u no what that code means? I would say u have to be on a boarderline too lean tune, just rich it up a bit.
  3. Aug 18, 2014 at 7:33 PM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    How the hell are you only at 150hp with the v6. Years ago I ran mine on a dyno and got 212hp at the wheels. That was with DT long tubes, URD TCAI, URD pipe bomb, magnaflow exhaust and no tune on the maf calibrator. I never did tune it because I couldnt find a shop that knew how to use the r4 software
  4. Aug 18, 2014 at 7:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The P0101 Code is for the MAF Circuit:
    This is what it says:
    P0101
    • High voltage: Conditions (a), (b) and (c) continue for more than 10 seconds (2 trip detection logic)
    (a) Engine speed less than 2,000 rpm
    (b) Engine coolant temperature 70°C (158°F) or higher
    (c) Voltage output of Mass Air Flow (MAF) meter more than 2.2 V (varies with Throttle Position [TP] sensor voltage)
    • Low voltage:
    Conditions (a) and (b) continue for more than 10 seconds (2 trip detection logic)
    (a) Engine speed more than 300 rpm
    (b) Voltage output of MAF meter less than 0.83 V (varies with TP sensor voltage)
    I agree with you. You learned a very expensive lesson. Take the garbage off and return the truck to stock. 16 HP isn't worth the pain and expense and a broken truck.
  5. Aug 18, 2014 at 7:42 PM
    offgrid taco
    ned
    mass
    I think your tune is just to aggresive. You should talk to Gadget at URD. He should be able to point you in the right direction.
  6. Aug 18, 2014 at 7:45 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I don't know man. What's the AFR? on the dyno sheet? Can't really tell if it's shit*y calibrator or tuner doesn't know what he's doing. I mean 150-163 hp? That's the same stock horsepower on my 22 yrs old integra with a VTEC 1.8L engine. Something doesn't add up including the CELs (check engine light) going off.
  7. Aug 18, 2014 at 7:47 PM
    DocsTacoma
    DFW, Texas
    I spoke to Gadget shortly after receiving the MAF calibrator, and pretty much got nowhere with him!:facepalm: I was shocked to learn that they don't even have a map for the Volant CAI, yet they're happy to sell it to you (with no disclaimer listed on their website)!
    I will NEVER do business with them again!
  8. Aug 18, 2014 at 7:55 PM
    offgrid taco
    ned
    mass
    They dont offer a map for many mods. The preloaded maps they do offer are just starting points anyhow because each truck is a little different because of manufacturing tolerances.
  9. Aug 18, 2014 at 7:58 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Dude get a grip, hundreds of people use the URD MAF re calibrator and it works great. You can absolutely feel 16 hp and you will find better mpg at highway speeds too. I've had one for years and it was dyno'd and clearly provides gains. A CEL is not a " broken truck " the person that tuned the MAF clearly just made an error it has nothing to do with the URD product itself. It sounds like his tech is the prob, not the URD MAF product... Three hours to tune with plug n play software at $100 per hour - how about you redirect your aim at that obvious problem... I'm surprised the code reader didn't throw an I-D-10-T user error code.
    OP - DO NOT waste your money on any Unichip products for a Taco.
  10. Aug 18, 2014 at 8:08 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    It really sounds like you mis understood that the URD MAF re calibrator would be a plug in and go item for you ? Why would you be shocked that they did not have a pre set map for your intake ...Volant has a very small market share to begin with and any device such as an MAF re calibrator should always be fine tuned even if it came with a generic pre loaded map as no two vehicles are truly identical. It is a great reliable product but it takes some " know how " to set up properly...Just as any sort of mapping software does. It really sounds like your tech took you for a ride. Three hours of labor to set up that device is insane, It seems your experience would have been vastly different an far cheaper with an experienced tech...I called URD and inquired about R4 experienced folks in SoCal, made an appt and was in and out in an hour total.
  11. Aug 18, 2014 at 8:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The tuner is also an idiot. The stock V6 4.0 liter 1GR-FE is rated at 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane.
    I don't know where they came up with the 150 and 165 HP... Something wrong!
  12. Aug 18, 2014 at 8:24 PM
    DocsTacoma
    DFW, Texas
    It was dynoed on a Dyno Dynamics which read extremely low; there's a reason they're called "heart breakers"!
  13. Aug 18, 2014 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What do you work for URD? You have your opinion and I have mine.
    I will agree the Tuner is an Idiot. No evidence there were any gains looks like nothing but losses. Down from 236 HP down to 165 HP. [​IMG]
    I will stand by my opinion that these little gains are worthless and cause more problems than they are worth. This post is a case in point. There are many other post about this ( not just Tacoma's ) all over the internet. The same holds true for CAI's. Garbage.
    Some ( not me ) would argue with you about Unichips also...
  14. Aug 18, 2014 at 8:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Low would be a few horse power numbers. Yours was a loss of 86 HP somewhere. Makes no sense. Your Tuner is a moron.
  15. Aug 18, 2014 at 8:30 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Pretty sure the dyno is reading RWHP, Stock rating is at the crank.
    Kyitty likes this.
  16. Aug 18, 2014 at 8:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Even still. My estimation shows that at 236 Crank HP should be putting out approximately 190 or so HP at the rear wheel. That is still 40 HP less.
  17. Aug 18, 2014 at 8:40 PM
    offgrid taco
    ned
    mass
    Are you sure you connected it properly. Its been a long time since I installed mine but Im pretty sure only one wire is actually cut. The rest are just spliced to. Bad splicing could cause resistance that would throw the MAF values way off. The table of values for the tune should be relatively smooth with no drastic changes from cell to cell just a gradual tapering.
  18. Aug 18, 2014 at 8:52 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Those numbers sound correct for an Un corrected dyno dynamics. They're honestly the most accurat BWHP dynos.... i believe multiply be 1.22 to average a Dyno Jet
    I hope your guy explained this...
  19. Aug 18, 2014 at 9:12 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, I do not work for URD but I have worked in retail for 25 years so I'm pretty good at spotting someone mis directing their problems with service at a product or their problems with a product at service. The " worthless " thing here is people confusing their opinions with fact and in the process disparaging someone's quality product. The product does not cause problems as you have stated " cause more problems than they are worth " fact = incompetent installation and buyers that don't do their homework cause problems - not the device itself.
    How can you stand by your opinion that 16 hp is worthless ? A CAI with a properly set up MAF re calibrator yielding 16 hp is quite clearly not worthless. That makes about as much sense as saying your tires are worthless because the kid at the tire store didn't put air in them...you guys gonna talk shit about BFG for that ? A CAI with a properly tuned MAF calibrator adding 16 hp and increasing mileage is clearly not worthless, fact.
    I would like to hear your fact based UniChip argument as I am extremely familiar with their product for our trucks. Go ahead and justify that $ to benefit ratio for a Gen 2 Taco UniChip set up vs a CAI and MAF calibrator...and don't forget to factor in that the plug and play UniChip gains are minimal so you have to hit a dyno and pay UniChip certified tech to tune it for you to get anywhere hear the fantasy numbers people claim.
  20. Aug 18, 2014 at 9:44 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Probably a wiring problem. Installed mine, punched the throttle a few times, noticed a difference, NO CEL
