Upper control arm replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Uvince, Nov 30, 2019.
  1. Nov 30, 2019 at 8:40 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Hello, my name is Vince. I am going to change my upper and lower control arms and am wondering if there are any issues with removing the bushing bolts. Thanks in advance.
  2. Nov 30, 2019 at 9:08 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    TW Search Function, YouTube, etc.
  3. Nov 30, 2019 at 9:29 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Tried them and found only stuff on upgrading. One said there was an issue of hitting the body and not being able to remove, but no year was given and it was for several different models of tacoma. Answer if you can dont point to obvious things I could check. Nothing on tw after an hour search.
    Sergio W, ABNFDC and MadDaddy like this.
  4. Nov 30, 2019 at 9:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Nov 30, 2019 at 9:39 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    05-15 are all the same. Bend the sheet metal out of the way until the bolt clears, no year and model needed.
    DavesTaco68, whatstcp and TnShooter like this.
  6. Nov 30, 2019 at 9:42 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum!
    TnShooter likes this.
  7. Nov 30, 2019 at 9:44 PM
    burrito782
    08 TRD Off Road
    About to replace UCAs myself, so just went through the searching exercise and was able to find plenty of useful info to go off of (hence why I just named a couple areas to begin your search).
  8. Nov 30, 2019 at 10:37 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Thanks. Once looked for Uac bolt removal it became clear
  9. Nov 30, 2019 at 10:41 PM
    burrito782
    08 TRD Off Road
    So Vince, which method you going with?...bending the sheet metal liner OR hacking the bolt head off? ;)
    P.S. Welcome to TW! :mudding:
  10. Dec 1, 2019 at 2:18 AM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Sheet metal bend.
    DG92071 likes this.
  11. Dec 1, 2019 at 5:49 AM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Fun fact, no amount of bending was going to get the bolt out of mine. 3 people tried it. Your results may vary, but mine had to be cut off. So be prepared to cut if necessary.
  12. Dec 1, 2019 at 6:21 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    As much as I am a huge proponent of following what the book says, I installed mine in the reverse :anonymous: My thinking is the bolt is installed with the head facing down so if the nut were to ever come loose or fall off the bolt might work its way down and out via vibrations. I come from an aircraft mechanic background which is something I was taught to keep in mind so I just pushed that rule onto my vehicles. Ultimately, it's your vehicle and hardware should go back in the same way as it was removed but I believe they installed the suspension prior to the body panels going on. You could remove the side fenders and not have to deal with bending sheet metal like most of us have done but that's a whole new can of worms.
    -J
  13. Dec 1, 2019 at 8:05 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  14. Dec 1, 2019 at 9:07 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It’s a pain but everyone of them will come out without cutting the bolt, you got the new bolt in correct if it went in the old one will come out.
    TxFireman likes this.
  15. Dec 1, 2019 at 9:22 AM
    DG92071
    DG92071 Well-Known Member
    I'm fairly sure he was referring to bending the sheet metal wasn't going to work on his truck on getting the bolt out, not bending the bolt to get the bolt out.
  16. Dec 1, 2019 at 12:51 PM
    burrito782
    08 TRD Off Road
    https://www.tacomaworld.com/threads/importance-of-regular-inspections.640590/
    JustAddMud[QUOTED] likes this.
  17. Dec 1, 2019 at 12:59 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Don't be too sure. No one mentioned bending the bolt.
  18. Dec 1, 2019 at 1:57 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Thank you all. The video from you tube was very detailed and helpful. I'm glad I joined this group of taco lovers :)
  19. Dec 1, 2019 at 2:13 PM
    DG92071
    You're correct, no one mentioned bending the bolt - they mentioned cutting the bolt.
  20. Dec 1, 2019 at 2:16 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Just bend the metal with some channel locks. Installed my spc uca's in under an hour super simple
    DG92071 likes this.
