Upper control arm bolts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hiluxski, Feb 8, 2017.
  1. Feb 8, 2017 at 3:27 PM
    Hiluxski
    Hiluxski [OP] Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    hey everybody I was wondering if anybody who has removed their upper control arms has any tips for getting out those bolts. On my 4Runner you could unclip the AC line on the passenger side and slide right past. the driver side was even easier. These bolts are hitting the inner fender almost dead center. I could bend the fender lip in a little but ?
    Does anybody have any tips for getting these bolts out other than just chopping them up with a sawsall but then again how do you install the new bolts ? It looks like they will hit the brake lines if I try to put them in backwards.
    Thanks
  2. Feb 8, 2017 at 3:29 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Some people cut the bolt, then reinstall a new bolt in the opposite orientation which is far easier to do.
    @Porter707 just did his this way.
  3. Feb 8, 2017 at 3:34 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    I bought new bolts for $9 ea. before I even started my project. I read the advice of others about bending the inner fender to get the stock ones out but didn't like that idea at all. You can push the brake lines out of the way enough to get the new bolt in (they flex). I used an angle grinder to get the old bolts out but sawzall, hacksaw would work just as well.
    blitzkrieg3002 likes this.
  4. Feb 8, 2017 at 3:57 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Don't install them from the rear (backwards). Do it properly - from the front. You do have to bend some metal to get them out and new ones in; that's what my installer did. It is not a huge deal and can be done fairly cleanly.
    otherphone and Blktre like this.
  5. Feb 8, 2017 at 4:04 PM
    niko5055
    niko5055 Well-Known Member
    24 Underground Sport Premium 4x4
    You've gotta bend the fender a little bit to make room
  6. Feb 8, 2017 at 4:13 PM
    Hogpauls
    Hogpauls Hmmmmmm.
    Near Boise
    '16 Tacoma BBP TRD OR Dbl cab mt ftw
    Like others have done I cut mine bought new ones and put them in from the opposite direction. I asked the Toyota mechanic who told me it makes no difference. Just wanting to know why you think this is improper?
  7. Feb 8, 2017 at 4:18 PM
    T4RFTMFW
    Popular fear is that if the bolt becomes loose, nothing is holding it in place except gravity.
    But, a non issue, as it's no easier to remove on accident as it is on purpose, and it only comes out one way when gravity is deciding which way it is. The same way it hits your fender, and prevents the bolt from being removed.
    not_nick, Drainbung, stun gun and 2 others like this.
  8. Feb 8, 2017 at 4:49 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    What are the bolt specs? I'll be getting new Uppers soon.
  9. Feb 8, 2017 at 4:55 PM
    ZIB
    ZIB Well-Known Member
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    Pelfreybilt front bumper steel full hoops Warn Zeon 10s winch Caliraised 20" slim light bar and amber 18w pods TRD exhaust Century High-C topper Stubs Welding SKO sliders Pelfreybilt Skids King 2.5 RR extended travel coil over with 650 springs and King 2.5 RR rear shocks Dakar leaf pack Total Chaos UCA BFG KO2 265/70/17 Cobra 75 wx st CB w/ 4' Firestik FS Rotopax 4 gallon gas can
  10. Feb 8, 2017 at 4:58 PM
    T4RFTMFW
    YE2KA, ToyLett and Hiluxski[OP] like this.
  11. Feb 8, 2017 at 5:06 PM
    ZIB
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    maybe make a video of your own on this install for others with 3rd gens?!?
    CaptainBart45 and Opihi59 like this.
  12. Feb 8, 2017 at 5:40 PM
    Dimestore55
    William
    Richmond, VA
  13. Feb 8, 2017 at 6:00 PM
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    i bent the driver side and cut the passenger side....
    otherphone likes this.
  14. Aug 19, 2018 at 3:50 PM
    broke_down
    broke_down highly opinionated with little experience
    2010 Green Tacoma Extended Cab
    I used an angle grinder and cut them off my truck. The bolt head doesn't slide out otherwise, as the front quarter panel is in the way. I bought some new ones off ebay... now I'm regretting that because I need new washers and nuts, but cant find anyone that will sell just those. Its odd, buying just the washers and nut from the dealer is almost as much buying the bolt with washers and nut from other on-line retailers. I did find that I can slip the new bolt in from the other angle.
  15. Aug 19, 2018 at 3:52 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    This.
    Don’t listen to me though. I’m one of the “ditches the sway bar” people. But I’ll install the bolt backwards without fear, I know what it takes to get it off, and it’s not coming off on it’s own.
  16. Aug 19, 2018 at 5:02 PM
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    I've done two UCA installs, one on a Gen 2 which was easy and only required a small amount of fenderwall bending, and just last week or so on a Gen 3. On my Gen 3 I cut the bolts, and installed new bolts "backwards." I did use proper torque, and threadlocker, and also make torque pen marks to see if anything loosens. I really doubt it is an issue at all.
    I looked at Nissan, their UCA bolt is actually 2 bolts, and theirs are installed "backwards" meaning that if the nut comes off, the bolt could fall out. This hasn't seemed to be a problem for them, why should it be for Tacomas? Just cut off heads, and then reinstall new bolts back to front w proper torque, and thread locker, make some torque marks w a paint pen and never look back.
    If you really wanted to pole vault over a mouse turd, spot weld the nut to the bolt thread, cross drill the bolt and put in safety wire or a cotter pin etc. It just doesn't seem this is real concern.
  17. Aug 20, 2018 at 10:30 AM
    17SandTaco
    17SandTaco Well-Known Member
    Conifer, CO
    2016 Tacoma OR
    I found the passenger side to be a pain in the ass to bend. The driver's side was very easy. For the passenger side, I ended up taking a long rod and hammer and went at it from the engine bay. I was able to move enough metal for the bolt to slide out. Just be sure to paint it after.
    YE2KA likes this.
  18. Aug 20, 2018 at 10:37 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Have cut off the OEM bolts and replaced them with OEM bolts from dealer. Put them backwards and no problems in 1 year.
    tacocart762 and ejewels like this.
  19. Aug 20, 2018 at 10:43 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    It's not that much more difficult on the 3rd gen. Much easier to have a second set of hands reaching down through the engine bay to hold the A/C line bracket out of the way on the passenger side. Driver side is super easy. Installing the bolts in the opposite direction is incredibly stupid, especially if you really wheel your rig. I have personally seen four 3rd gens now have their UCA bolts back out because they were installed backwards and all claim they were torqued properly. A little extra time and elbow grease to do it right never left anyone busted on a trail.
    YE2KA likes this.
  20. Dec 1, 2018 at 8:29 AM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    You’ve seen 4? OK. Funny how so many third gens install them backwards and are fine. If they fell out that easy obv something wasn’t right. I had a professional mechanic who’s done tons of this stuff tell me it’s completely fine.
    MR E30 likes this.
