Upgraded bypass pipe solution for coolant leak?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Dec 31, 2023.
  1. Dec 31, 2023 at 8:35 PM
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    Hey guys, I'm concerned with my 20 offroad having the dreaded coolant leak behind the engine in the bypass. I just paid this truck off. And I was wondering if anyone has seen a fix or basically an upgraded bypass pipe if it ever had to be replaced that could be used?
  2. Dec 31, 2023 at 8:39 PM
    2GRFKS
    2GRFKS 2nd gen Tacoma is the worst gen
    Your 5 year 60K powertrain warranty should cover this repair.
  3. Dec 31, 2023 at 8:59 PM
    JmsWms
    JmsWms Well-Known Member
    Jim
    Tennessee
    2017 Inferno TRD Sport AC 4x4
    Welcome to TW!
  4. Dec 31, 2023 at 9:29 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    You’re worried about about an issue that had been completely blown out of proportion by the internet . Don’t even worry about it
  5. Dec 31, 2023 at 9:37 PM
    InThePlains
    InThePlains Well-Known Member
    bbartol likes this.
  6. Jan 1, 2024 at 4:29 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Purchase an extended warranty if u are worried about it .
  7. Jan 1, 2024 at 5:50 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
  8. Jan 1, 2024 at 5:55 AM
    Gfenza89
    Only oil leaks are covered under powertrain I think
    MannyS likes this.
  9. Jan 1, 2024 at 6:00 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Sure…
    Kgbrev[OP] and shakerhood like this.
  10. Jan 1, 2024 at 6:14 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Check out this thread:
    Aluminum replacement for plastic rear coolant bypass joint | Tacoma World
  11. Jan 1, 2024 at 6:24 AM
    Gfenza89
    So you had the problem which sucks, doesn’t mean the other million 3rd gens will
    Phlogiston and Junkhead like this.
  12. Jan 1, 2024 at 6:30 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    0xDEADBEEF likes this.
  13. Jan 1, 2024 at 6:32 AM
    Gfenza89
    It could be no changing the coolant at 50k miles. The coolant becomes acidic over years and miles.
    Phlogiston, Junkhead and bulalo like this.
  14. Jan 1, 2024 at 7:59 AM
    Buck Henry
    Here's an idea, worry about it when/ if it happens. The amount of preemptive wailing and gnashing of teeth here is astounding!
  15. Jan 1, 2024 at 8:06 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Isn’t the interval 100k?
    Murd3rd and usmc2msu like this.
  16. Jan 1, 2024 at 8:25 AM
    Gfenza89
    That’s the max
    Junkhead likes this.
  17. Jan 1, 2024 at 8:32 AM
    0xDEADBEEF
    It’s what the schedule says…replace at 100k. Before that just inspect for leaks. What leads you to believe that replacing earlier is necessary? Let alone 2x as often?
    clownkillerloaf and usmc2msu like this.
  18. Jan 1, 2024 at 8:44 AM
    Gfenza89
    I always tend to cut the scheduled maintence in half for preventive measures
    Williston, Junkhead and bulalo like this.
  19. Jan 1, 2024 at 8:46 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    It’s his truck and he believes what he thinks is right. I’m with him too. No leaks at 90t miles yet. Will change again at 100t miles .
    Junkhead and Gfenza89 like this.
  20. Jan 1, 2024 at 8:48 AM
    0xDEADBEEF
    Ah ok
    Gfenza89[QUOTED] likes this.
