Upgrade the trash OEM backup camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by larkintx, Mar 30, 2023.
  1. Mar 30, 2023 at 8:29 AM
    larkintx
    larkintx [OP] Member
    Derek
    2020 Voodoo Blue TRD Sport
    lifted and bed cover
    I wanted to reach out and see if anyone has upgraded their oem backup camera. My hope is that the backup camera can be upgraded and that the new camera can fit in the oem housing.
  2. Mar 30, 2023 at 8:35 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    I added a higher res front camera to mine and it turns out that it wasn't the rear camera at all but the resolution limit of the screen in your dash. I don't know if the rear camera is matched to the screen or not, but it seems like you'd have to replace the head unit as well to achieve your goal.
  3. Mar 30, 2023 at 8:36 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    You'll have to replace the whole system, not just the camera. Be sure to post up how it goes.
  4. Mar 30, 2023 at 8:44 AM
    larkintx
    Derek
    I recently upgraded to the any time backup for the front view and that camera is noticeably better on the same head unit. I do agree that the head unit screen isn't the best but at this point I don't want to loose my Toyota connected services like remote start etc.
  5. Mar 30, 2023 at 8:50 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    This is good to know. Compared to the wife's Forester my rear-camera-view on the screen isn't as clear.
  6. Mar 30, 2023 at 9:16 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I upgraded mine to a Kenwood CMOS 740HD but I’m not happy with the mount the audio shop used. I’d like to get a bracket 3D printed to mount it. Either that or a small aluminum fabbed bracket. I swapped it back to stock for the time being, but I’ll get back to it eventually. It sure is nice to have a more clear camera, though the factory one honestly isn’t bad at all for what it is. The factory is bad if you blind it with a bright license plate backup light bar, because the blinding light reflects off walls/garage doors and blinds the camera.
    I don’t think you’ll have much luck upgrading with a factory head unit, I don’t know of any plug and play options.
    daveeasa likes this.
  7. Mar 30, 2023 at 9:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's not the camera. The 2020+ have just horrid processing to the head unit. It's kinda shocking.
    For example:
    MT_Head likes this.
  8. Mar 30, 2023 at 9:29 AM
    BLtheP
    Plano, TX
    I didn’t feel any real difference in camera quality using factory camera between 2021 HU and aftermarket HD screen Kenwood.
    my 21 camera also looked the same on the factory HD as one of my friends 16 did.
  9. Mar 30, 2023 at 9:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Who knows where that signal is processed though? Without schematics, it is hard to tell, but I would guess that one of the many ECUs is involved.
    All that I know is that all of the 2020+ Tacos that I have been in have abysmal camera quality compared to the 2019 and old. Toyota dropped the ball there, somehow.
    larkintx[OP] likes this.
  10. Mar 30, 2023 at 9:33 AM
    Firn
    Firn Well-Known Member
    White OR
    Oh man, here we go again. Not even friday
    Sorry OP but this seems to be the topic the trolls come out on the most. Get ready to be bombarded by those who think they are special because they know how to use their mirrors.
    Bottom line the issue has been talked about a lot and there isn't anything one can really do. The system Toyota uses allows at best less than SD resolution and that is every part of the system, from the camera to the wiring to the head unit. For comparison the system used has ten times lower resolution than 1080.
    I have attempted putting in a higher quality camera with no improvement, I even hacked in a video feed and the quality was much much worse than the screen displays even for album cover art. I still want to see someone pipe in a very high quality feed directly into the head unit (its just a couple wires) but have not seen someone attempt it yet.
  11. Mar 30, 2023 at 9:34 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Nothing wrong with the camera…but the res is garbage…
    Hogleg918 likes this.
  12. Mar 30, 2023 at 9:35 AM
    Firn
    White OR
    The head unit does the processing. The system runs a direct wire feeding a NTSC formatted signal from the camera into the back of the HU.
    IIRC the non-360 trucks have the same quality as the older trucks but for the 360 camera trucks the try to do too much manipulation of the already very low resolution system and it just trashes the picture.
    rmepilot and tonered[QUOTED] like this.
  13. Mar 30, 2023 at 9:36 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My biggest compliant is that its not a fisheye type lens. Its helpful when backing up in a parking lot to see more left and right when there's a car next to you blocking your view.
  14. Mar 30, 2023 at 9:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ah! Thanks. That is interesting. Still a let down.
    BLtheP likes this.
  15. Mar 30, 2023 at 9:45 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    And, we have a lot of stone and chip and seal roads in our area. Depending on weather, the backup cameras on my Tacoma and my wife's Kia are covered in crud and worthless. It seems silly to stop and clean a lenses to backup up when you have mirrors handy.
  16. Mar 30, 2023 at 9:47 AM
    Firn
    White OR
    So, I have said I have tried different cameras/video feeds....
    Still, the signal format is exactly the same as many aftermarket systems and I have seen them with what I feel is a better looking picture (maybe not higher res). I still want to try removing any and all wiring and connectors and then feed in the video signal from a known source that for sure outputs a very high quality (NTSC) signal, something like a modern DSLR camera or similar. The hard part is FINDING a good video source that still uses such antiqued communications.
    I cannot rule out that the lengthy and cheap wiring, lack of RF shielding, and multiple connectors is not in fact affecting video quality.
    I have a rear view camera from a dashcam, and a wiring harness...I might need to try this again.
    JerryHeller and tonered[QUOTED] like this.
  17. Mar 30, 2023 at 9:50 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    It does look kinda "grainy" in this photo...but honestly, it's not that bad. Only when it rains and the lens is covered with water.
    At least I can avoid backing into my fence!
    Mirrors...what mirrors? lol
    The weekend is almost here!
  18. Mar 30, 2023 at 9:53 AM
    Firn
    White OR
    @caribe makaira , do you have a pinout for the HU on 360 camera trucks? The service manual I found does not have the newer trucks.
    Not sure if there are multiple HUs for those.
    Specifically I would like to see what pin(s) have the camera signal from the various cameras and I know the pinout is different from the standard HU/Camera trucks
  19. Mar 30, 2023 at 10:15 AM
    BLtheP
    Plano, TX
    Last I saw, the camera circuit is pretty simple. Camera has 4 wires, 6V, -, video signal and video ground. Radio provides 6V when in reverse, then camera sends video signal to the radio. I dunno, I've heard the wire colors and maybe quantity changed over the years.
    All I can say is that my 2021 looks just like the rest. You can see that also by most of the trucks on auto trader having a demo of the backup camera in the pics. Looks the same across all years to me.
    I am curious if maybe the trucks you're referring to have the 360 cam. Now THAT setup is abysmal.
    I suppose mine could have been better on the aftermarket radio than stock, it's been basically since I bought the truck that I've had the Kenwood HU in there. But, I don't remember it being a noticeable improvement, so I really don't think so.
  20. Mar 30, 2023 at 10:29 AM
    BLtheP
    Plano, TX
    Looks like Firn already said along the lines of what I was thinking :thumbsup:
    tonered[QUOTED] likes this.
