Upgrade rims on 5 lug
Discussion in '1st Gen. Tacomas (1995-2004)' started by Qtboi69, May 3, 2021.
  1. May 3, 2021 at 8:31 AM
    Qtboi69
    Qtboi69 [OP] Member
    1998 Tacoma 5-Lug 2.4
    Hey there, I'm pretty new to trucks in general so forgive if this is a dumb question.
    I've got a 1998 5-lug 4cyl (2.4) mini and and trying to get a little bit bigger A/T tires, this truck is stock everything and has 14 inch wheels. My question is if anyone knows if I can simply get a bigger rim (15 inch) for the truck? Apparently I should be able to fit 225/75/15 tires on this truck with stock suspension from what I've read
    I am currently running 215/70/14 tires.
    I've attached a screenshot of the rim I'm thinking about getting
  2. May 13, 2021 at 10:07 AM
    DrewZFoster
    DrewZFoster Well-Known Member
    97 5 lug base
    Following this thread, I like these wheels and I just want to bolt them on my 97 5-lug and forget about them. OP, keep this posted on your progress.
  3. May 13, 2021 at 10:16 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    You want to put 6lug rims on a 5lug ?
  4. May 13, 2021 at 10:19 AM
    DrewZFoster
    97 5 lug base
    No, they do have a 5 lug version of that wheel.
  5. May 18, 2021 at 7:42 PM
    kktxod
    kktxod New Member
    1998 Tacoma single cab 2wd
    I just got some Mazda 3 steel wheels that I bought on Facebook marketplace for $80. They are 16”. Put Toyo all terrain 215/70 R 16 on. Fit great and look great. The 225/75 was way too big and scraped. BTW the big issue is the center bore which is 66.1 mm. I had bought some Honda CR-V rims but even though the 114.3 bolt pattern was correct the center bore was only 60.1 mm.
    Qtboi69[OP] likes this.
  6. Sep 13, 2023 at 5:07 PM
    m7leyva
    m7leyva New Member
    Did you end up changing them? I want to put the 14inch rims on mine. Would you be interested in selling them?
  7. Sep 23, 2023 at 6:32 PM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    I put a set of Highlander 16” alloy wheels on my 5-lug 1994 pickup with 235/60/R16 FP7000 tires. 1.5” wheel spacers in the front and 1” spacers in the rear.
    The Highlander 2001-2007 bolt circle is the same as the 1994 Pickup 5-lug.
    Works nicely for me and the cornering is outstanding. Added a rear sway bar with PU bushings front and rear.
    I had them powder coated locally.
  8. Sep 23, 2023 at 7:51 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Can you post a picture of the 215 70 r16 mounted? Plz Plz!
    I’m thinking that is the size I will be going with
    Thanx
    I got a ‘5 lug rim solved’ somewhere
