Upgrade head unit and speakers or just the speakers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thebotti, Feb 14, 2022.
  1. Feb 14, 2022 at 10:19 AM
    thebotti
    thebotti [OP] Member
    Tom
    2020 Quicksand Tacoma SR5
    just minor so far, blackout , LEDs
    I have the non JBL stereo, is it recommended to update the head unit and all speakers, or just the speakers.
    Newbie here, so any suggestions would be helpful!
  2. Feb 14, 2022 at 10:42 AM
    1D6SR521
    1D6SR521 Well-Known Member
    Tampa Florida
    I did the Subaru tweeters only and I’m happy. Maybe I’ll do the locker door speakers at some point but the tweeters did the truck for me. I guess it all depends on how serious you wanna go and how picky you are with your music.
  3. Feb 14, 2022 at 11:53 AM
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    I have the non JBL stereo in my 2018 4x4 OR.. I did the Subaru tweeter upgrade, changed all the speakers to Kickers, and added the Kicker Key Amp which hides inside the passenger side dash..
    the OEM head unit pushes the upgraded speakers just fine.. couldn't be happier.. perfect balance inside the cab.. I was gonna add a subwoofer in the back but hadn't felt the need to do so yet...
  4. Feb 14, 2022 at 12:08 PM
    bimmerlev
    bimmerlev Well-Known Member
    Lev
    Los Angeles, CA
    2024 Tundra / 2023 BMW X5
    Got a none JBL Taco here too, definitely needs an upgrade.. The Subaru upgrade seems to be hella popular.
  5. Feb 14, 2022 at 12:10 PM
    SoCali_Guy
    California
    TRD OFF ROAD
    Do what I did bro.. its very cost effective.. and you'll be happy
    bimmerlev[QUOTED] likes this.
  6. Feb 14, 2022 at 12:23 PM
    thebotti
    Tom
    Ok, one question, what are the Sabaru tweeter upgrade? and which Kickers?
    admmck and Jab969 like this.
  7. Feb 14, 2022 at 12:31 PM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Jab969, SFcoma, Jesse H and 1 other person like this.
  8. Feb 14, 2022 at 12:32 PM
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
  9. Feb 14, 2022 at 12:33 PM
    1D6SR521
    Tampa Florida
  10. Feb 14, 2022 at 12:38 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    I started with the Kicker tweeters. Currently I am in the process of installing my sub. I went with the JL Audio Stealth series. It’s made as a direct fit for the Taco and is muck louder than the JBL and Alpine subs. Going to keep the stock door speakers for now and possibly upgrade them in the near future.
    https://www.jlaudio.com/products/sb-t-tacdcg3-10tw3-car-audio-stealthbox-94654
  11. Feb 14, 2022 at 1:16 PM
    dljohndrow
    dljohndrow Well-Known Member
    Dave
    2018 Tacoma
    I have an SR and of course non JBL. I added the Kicker speakers in all the doors and it was decent (the back doors were weak). Add the Kicker tweeters and it was better. Upgraded the head unit and it is far superior.
    JoeyDel likes this.
  12. Feb 14, 2022 at 1:24 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Did you add an amp to your upgraded Kicker speakers before HU upgrade? Or just running them off the factory HU wattage?
  13. Feb 14, 2022 at 1:27 PM
    dljohndrow
    Dave
    2018 Tacoma
    No amp and the sound was decent
  14. Feb 14, 2022 at 1:41 PM
    thebotti
    Tom
    This is great Information..I am gonna upgrade soon for sure.
    I upgraded my Interior to LEDS, but the vanity mirror is too bright, is there a dimmer type LED you have found?
    I used Bright white from Amazon
  15. Feb 14, 2022 at 2:11 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Sound would have been much better with a small amp. If you read most speaker specs, they will give you a range that the speakers perform in, say for instance of conversation 25-250 watts with a peak wattage of 350. This means they will produce sound as low as 25 watts and continually handle up to 250 watts, peaking around 350 before they blow. They were probably getting no where near their optimal power range from the factory headunit.
    @thebotti
    If you are going to go the route of replacing the factory door speakers, I would highly recommend you pushing them off a small amp before replacing the entire headunit. A headunit will cost you upwards of $1300 for a high quality name brand unit. A good amp will cost a fraction of that… most amps cost about $1 per watt, and you’ll probably only need a 100-250 watt amp.
    thebotti[OP] likes this.
  16. Feb 14, 2022 at 3:37 PM
    SoCali_Guy
    California
    TRD OFF ROAD
    Taco1004 likes this.
  17. Feb 14, 2022 at 5:08 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I have an SR and I did the Subaru tweeter upgrade. This is what you should probably try doing first. It is a big improvement.
  18. Feb 14, 2022 at 5:37 PM
    dljohndrow
    Dave
    2018 Tacoma
    kahanabob and thebotti[OP] like this.
  19. Feb 15, 2022 at 7:22 AM
    thebotti
    Tom
    im gonna try the kicker upgrade and add a amp later if needed.
    Got the Subaru tweets and the kicker 6x9s and 6.75 for rear
  20. Feb 15, 2022 at 7:28 AM
    SoCali_Guy
    California
    TRD OFF ROAD
    MaHoTex likes this.
