Upgrade from BFG Rugged Terrain to All Terrain KO2
Discussion in 'Wheels & Tires' started by docrameous, Dec 9, 2017.
  1. Dec 9, 2017 at 8:05 PM
    docrameous
    docrameous [OP] New Member
    I have a 2014 Taco Texas limited edition 4x4 double cab that came with Rugged Terrains P245/65R17. I have the opportunity to put the same tire on again, but am seeking advice on whether I should upgrade to the All Terrain KO2 LT265/65R17.
    My main use of the truck is to get me to work daily on a 10 minute commute, with the occasional long trips and off roading in Colorado. I'd like to keep the road noise and fuel mileage the same or a bit better. I frequently drive on wet road pavement.
    Stick with the RTs or go for the ATs? Or should I even consider something else? Many thanks for any advice.
  2. Dec 9, 2017 at 8:44 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    You might want to go with 265 70 17 KO2s C load, only around 45 lbs so not to heavy, great all round tire.
    I have them, but might give the Cooper ST Maxx a try next.
    crashnburn80 likes this.
  3. Dec 9, 2017 at 9:22 PM
    TacOMas'
    TacOMas' R 2 Bearded ladies better than 1?
    N.Ut.
    13' TRD white tacoma 6sp. Man.
    Not much,KO2’s-n-a sweet mirror relocation bracket ,, gathering info.
    The AT’s are great, I upgraded from the stock bfg 265/70/16, to the kO2 size 265/75/16 E. The difference in mileage,ride with the Heavy load range E is a real factor. Off road piece of mind is worth the trade offs for me. Perhaps load range C KO2’s may hit your sweet spot, as long as you make it to Colo. -n-getum-dirty.
    DavesTaco68 and Solid Seung like this.
  4. Dec 9, 2017 at 9:35 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I switched from 245/75/16 to 265/70/17 and lost 10 miles per tank
  5. Dec 9, 2017 at 9:38 PM
    Solid Seung
    Solid Seung GWOT Infidel
    New California Republic
    2013 SC V6 DCSB TRD OR 4x4
    TRD Supercharger aFe Stage-2 Si Pro DRY S CAI JBA Cat4ward Shorty Headers TRD Performance Exhaust PLX Wideband Air/Fuel Sensor Module Speedhut Boost & Wideband Air/Fuel Ratio Gauges CravenSpeed Flexpod ScanGauge SGIIFFP Computer Uni Filter Mod Mobil 1 Synthetic Oil Pelfreybilt Off-Road: Aluminum Front Plate Bumper, Rigid DOT/SAE Fog Lights, Pelfreybilt Hawse Fairlead & Flipster Winch License Plate Bracket, Aluminum IFS Skid Plate, Steel Standard Rear Bumper, Smittybilt 3/4" Black D-Rings w/Daystar Isolators & Washers KB Voodoo Tailgate Cap System King Shocks 2.5 Front Remote Reservoir Coilovers SPC Light Racing UCAs King Shocks 2.5 Rear Remote Reservoir Shocks OME Dakar EL095R Leaf Spring Set Wheelers Off-Road Front SuperBumps, Rear U-Bolt Flip Kit with SuperBumps Crown Performance Red SS Brake Line Kit Body Mount Chop Tandem Off-road 612 Bravo 17x8.5” Wheels BFG T/A KO2 285/70R17 Tires Redline Tuning QuickLIFT ELITE Hood Struts Redline Tuning Tailgate EZDOWN TRD Battery Hold Down Duralast Platinum Battery 24F-AGM OEM Black Grille Bezel TRD Pro TOYOTA Grille TRD Pro Black Headlights Sylvania Silverstar zXe H4 Lamps Rain-X Silicone AdvantEdge Wiper Blades OEM Running Boards OEM Tacoma Bed Mat AJT Design Climate Control Knobs WeatherTech Floor Liners Covercraft Carhartt Precision Fit Custom Seat Covers Emergency Assistance Kit First Aid Kit Salex Organizers Center Console & Glovebox OCD Anker 36W Dual USB Car Charger PowerDrive+ 2 Type S Drive Dash Camera Garmin nüvi 255W 4.3" GPS Navigator Steadfast Auto 8" Antenna Pioneer AVH-X3500BHS 2-DIN Multimedia DVD Receiver 6.1" WVGA iPod nano 8G (6th Gen) JL Audio XD700 Watt/5 Channel Amplifier JL Audio C2-650X & C2-650 6.5" speakers JL Audio 10W1v2-4 10" subwoofers (x2) in a JL Audio Stealthbox
    I second that. I did the same on my 2013. BFG TA/KO2 265/75/16 E rated. I like the heavier duty E rating for off road trails and the 75 is a little more wider than the 70, but still fit fine on a 16" rim. I only lost about 1 mpg from the stock BFG 265/70/16 tires. Plus the waffle pattern and sidewall are very unique and great looking.
    DavesTaco68 likes this.
  6. Dec 10, 2017 at 5:16 AM
    docrameous
    Thanks everyone. Very helpful. Did any of you notice a difference in road noise when you switched from Rugged Terrain to All Terrain KO2s?
  7. Dec 10, 2017 at 5:32 AM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    I found the K02 was not very good on wet pavement, stopping, starting also prone to hydroplaning without distinct channels in the tread
    inwood customs likes this.
  8. Dec 10, 2017 at 6:12 AM
    docrameous
    Wet pavement is a concern to me and in fact I spend more time in my daily commute on wet roads, than off roading. So I need to weight my criteria that while I hope for and want good snow/off road performance, safety on wet roads is very important.
  9. Dec 10, 2017 at 12:17 PM
    docrameous
    I am considering going to the Falken Wildpeak A/T3W. It seems to get positive reviews on performance off road, wet pavement conditions and it is snow rated with reasonable road noise. It seems some claim it is a bit weak in soft sand and dirt, but I can accept that for all the positives as I don't live close to any beaches or conditions that would exclusively be present in an offload experience.
  10. Dec 10, 2017 at 3:55 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Aren't they called
    'Rugged Fails'
  11. Dec 10, 2017 at 4:42 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    There are Rugged Trails and Rugged Terrains, the Terrains are a much better tire than the "Fails"
    TXpro4X4 likes this.
  12. Dec 10, 2017 at 4:47 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The aspect ratio means the 75 series is TALLER than the 70 series. Not wider tho
    Solid Seung[QUOTED] likes this.
  13. Dec 10, 2017 at 4:52 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just put them on myself in 265/70/17 C Load after having Cooper ST/MAXX in 265/75/16 in E Load. Loves the BF G's so far as we just got snow last night and they performed like a Boss. ST/MAXX's were nice but just so damn heavy.
  14. Dec 10, 2017 at 4:53 PM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    where's them red caps Rick?
  15. Dec 10, 2017 at 4:55 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    They don't fit and could not be modified to do so. They are on there way back to CamelBack
  16. Dec 10, 2017 at 4:57 PM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    well, that blows! The black ones still look good though!
  17. Dec 10, 2017 at 4:59 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yeah the Pro Center Caps need like a star metal snap in piece not a round, and honestly the kind of scratched just by holding them as the caps were really glossy coated.
