UPDATE! Found front-end popping noise.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpeySquatch, Nov 14, 2018.
  1. Nov 14, 2018 at 4:56 PM
    SpeySquatch
    SpeySquatch [OP] Function over Form
    2016 TRD OR DCSB
    UPDATE 12/2
    Hey guys,
    I found the popping noise I was mentioning in the first (original)post below this one.
    Disclaimer:
    I do have a sway bar relocation spacer installed
    The bolt on the sway bar tie rods was rubbing the very end on the bottom coil of the spring.
    Luckily (after I removed to sway bar) I could paint the scratch with the same silver color paint I use on my truck now (silver taco).
    I rode without the sway bar for a bit and did some angled turns out of/into the driveway as before with different speeds and body roll. No popping.
    Driving without the sway bar feels like a cloud over bumps! However, at highway speeds (50+) you can feel the way the body "sways", almost feels like and "S" movement through the body. I can see how this would get scary avoiding a head-on collision. I put the sway bar back on until my next offroad trip. It's seriously easy, and anyone who takes it off must understand you HAVE to take off the two front frame braces to get the entire bar out (6 - 17mm bolts) or you will fight the bar to the end...not that big of deal (< 4mins)
    Anyways, went and cut the little tiny bit that was rubbing, resumed and torqued everything to spec. Checked again by going in a and out of the angled curb entrance to my driveway. No popping.
    Anybody with 2.5" shocks may want to check this. See pics below
    This little bolt end was rubbing the coil.
    Scratch Driver
    Scratch Passenger
    Used washers to space bolt away from coil, but decided against this after looking at the tweaked boot angles on the rod. Took these out.
    So, I cut about 1/8-3/16" off the end of the bolt and added rubber silicone in case it ever did just barely make contact (doubtful).
    Painted the scratches (barely see blemish)
    __________________________________________________________________
    Original post:
    This has been mentioned before, but answers are vague.
    When pulling up and angled driveway while turning and experiencing some articulation (a little body roll) there can be a "popping" noise that occurs occasionally. It sounds like a coil settling as it twists in the coilover, a tied rod, or a rear shock clacking against the leafs.
    but, when underneath the truck I can not see or identify either of these. Is this a symptom of the frame twisting?
    I have checked and torqued:
    • Body Mounts
    • Tie rods
    • Necessary shock bolts
    • I even went as far to cover the rear shocks in electrical tape to identify any hitting although there was none
    Someone please give me peace of mind on what is occurring.
    Rockefelluh, AKGSD, ancient11 and 5 others like this.
  2. Nov 14, 2018 at 4:58 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Have you looked at the spring itself?
  3. Nov 14, 2018 at 5:06 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Replace the front coilovers...problem solved let me know when you get there
  4. Nov 14, 2018 at 5:10 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    If it is indeed the front body mounts (it was on mine) the torque means nothing.
    The rubber mounts were not installed properly from the factory - replacement is the only way to fix.
    Michael156 and shakerhood like this.
  5. Nov 14, 2018 at 6:21 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I have the same exact issue. Haven’t figured it out yet. First model year problems!
  6. Nov 14, 2018 at 6:30 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I have this too. How do I check my body mounts?
  7. Nov 14, 2018 at 6:37 PM
    Mojlnir
    Parker, CO
  8. Nov 14, 2018 at 8:41 PM
    SpeySquatch
    2016 TRD OR DCSB
    Definitly not the coil overs. They are brand new
    Catfish21 likes this.
  9. Nov 14, 2018 at 8:43 PM
    SpeySquatch
    2016 TRD OR DCSB
    Glad I’m not the only one. Think it is just a symptom of the vehicle. I don’t think it is the body mounts because it sounds like the leafs or frame flexing
    JoeCOVA likes this.
  10. Nov 14, 2018 at 8:44 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Possibly sway bar links if you have it on still
  11. Nov 14, 2018 at 9:29 PM
    Man Babes
    Man Babes Member
    Had this sound a few months ago with the stock bilsteins where at a certain speeds over bumps it made sort of clacking sound as OP described. I upgraded my shocks around 8000 miles with the trd pro bilsteins and the sound went away. Fast forward 10000 miles later now at 18000, the sound has returned. Now I did notice it happened more often after I got an alignment. At my first 5000 mile service I got it aligned from the dealership (it was pulling right) and that's when I started to hear it. Upgraded the shocks and got it aligned and the all was well with no sounds. Around 17000 miles my steering if off center for some reason and I get it realigned. Then whadda ya know, the sound is back.
    SheepCatActual likes this.
  12. Nov 14, 2018 at 9:59 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    How much steering when it pops? Almost maxed out, as in a very tight corner?
  13. Nov 15, 2018 at 12:18 AM
    SpeySquatch
    2016 TRD OR DCSB
    Wow, that’s weird
  14. Nov 15, 2018 at 12:19 AM
    SpeySquatch
    2016 TRD OR DCSB
    Turned 1/3 -1/2 of max
  15. Nov 15, 2018 at 12:20 AM
    SpeySquatch
    2016 TRD OR DCSB
    This may be the closest guess yet, are these those tiny rods that connect to the spindle?
  16. Nov 15, 2018 at 12:45 AM
    swissrallyman
    LCA would be my guess. Same with poster above who said his popping went away after alignment. Try loosening and re-torquing all your cam bolts with the wheels sitting on the ground. Either one of them is loose or you need new LCA bushings. Slap some grease on your steering stops as well while you are down there
  17. Nov 15, 2018 at 6:13 AM
    WOTaco
    Mine does it between 3/4 to full lock such as when turning into a driveway that has a ramped skirt.
    Joe jaramillo likes this.
  18. Nov 15, 2018 at 7:18 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yup
  19. Nov 15, 2018 at 11:28 AM
    SpeySquatch
    2016 TRD OR DCSB
    Could this really be it if it doesn't happen every time? I just got two alignments done by a reputable 4X4 shop.
    Could it be my bolt-on sliders making noise when the frame twists since they are connected?
  20. Nov 15, 2018 at 11:44 AM
    swissrallyman
    Look in the 2nd gen forum for knocking or popping LAC bushings.
