Up-Size Tires on 2013 Tacoma 4 x 2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EZ Duz'it, Jan 5, 2016.
  1. Jan 5, 2016 at 7:06 PM
    EZ Duz'it
    EZ Duz'it [OP] New Member
    -jwall
    2013 Tacoma SR5
    I have a 2013 Tacoma 4 x 2 that I would like to increase the size of tires as the factory ones are just about gone. I believe i have 15"x7" rims/wheels with P215/70-R15 tires. Is it possible and sensible to install 265/70R15 tires on this 2WD with 15" x 7" Rim ??
    EZ duz'it
  2. Jan 6, 2016 at 8:08 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    My suggestion would be don't go that big.
    1. Maybe a 225/70 max.
    2. 265/70 are much heavier, will lose mpg and power with the 4 cylinder.
    3. If you go larger than 225/70 you should go to wider rims, at least 7.5
  3. Jan 6, 2016 at 9:03 AM
    imageomega
    imageomega Well-Known Member
    Jarrod
  4. Jan 6, 2016 at 9:09 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    OP what is the final result you are looking for? are you just trying to put bigger tires on it without a lift? Or is this the beginning of a Mod spree???
  5. Jan 6, 2016 at 9:18 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP you have a 16inch rim at a minimum.
    You can go with a 265/75R16 (265/70R17 is the same diameter but with a 17in rim), without having to do any trimming. This is the largest size you can go without having to worry about mudflaps / trimming.
    Some will say a 285/75R16 will fit, but every single person i have seen with that diameter n width rubs fender flares etc when they actually flex their truck.
    ArcherTaco likes this.
  6. Jan 6, 2016 at 9:22 AM
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    All true and good info ^^
  7. Jan 6, 2016 at 10:14 AM
    evan
    evan Well-Known Member
    SK, Canada
    That should hold true if his 4x2 is a Prerunner. If he's driving a 5 lug 2 wheel drive then I don't think any of that applies.
    NeedmoreTaco and bigfoote13 like this.
  8. Jan 6, 2016 at 10:22 AM
    nd4spdbh
    SoCal
    ^ True, OP are you driving a 5 lug or a 6 lug truck?
  9. Jan 6, 2016 at 12:40 PM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
    So question to who ever may know im about to put the 3" rough country lift on my 13 PreRunner 2wd does anyone know if I can run the General Tire Grabber 33"s with out rubbing or cutting. Gonna put them on the stock 17" 6 lug 6 point star rims.
  10. Jan 6, 2016 at 4:52 PM
    texasfight
    texasfight Well-Known Member
    Doug
    2009 Super White double cab TRD
    Rigid 32 in light bar, Back Rack, 265/75r16 General Grabber AT2's mounted on FJ Cruiser Trail Team wheels
    I went 265/75r16
  11. Jan 6, 2016 at 5:02 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    You're going to have rubbing.
    Crash721[QUOTED] likes this.
  12. Jan 6, 2016 at 5:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    5 lug. Because 15" wheel and 215s stock.
