Unistrut bed rails in a 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Aug 12, 2019.
  1. Aug 12, 2019 at 11:40 AM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    i was looking at doing the unistrut bed rails that someone showed me in the tundras.com forums. Wondering if anyone has done that mod in a 1st gen? Do the small side walls at the top of the bed hold much weight? Do aftermarket attachments fit them well? Anything that slides that could hold a shovel? I’m picturing something that lets me unlatch the part closest to the bed and then slide the shovel towards me and then detach the other attachment. I think with the unistrut you have to bolt everything into the rail but thought I would ask.
  2. Aug 13, 2019 at 2:28 PM
    Natenite
    Springfield Mo
  3. Aug 13, 2019 at 2:31 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Got a link to an example? I’ve always wanted to try this, the unistrut would be a lot stronger than the bed sides, you would have to bolt them on with a large square washer behind each nut.
    Natenite[OP] likes this.
  4. Aug 13, 2019 at 3:16 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    This, right?
    (from Tundras.com)
    Pretty sure there are people who have done similar things with their first gens.
    If you mount in that same location, you'd need to use riv-nuts, and I'm not sure how much space is between the outside and inside fender material at that location. Might not even be enough for a riv nut.
    I used riv-nuts for my highlift mounts, but those were riv-nutted quite a bit lower, then I used conventional bolts/nuts on the inside edge of the bed rail.
    Either way, I wouldn't use that to tie down anything heavy...
  5. Aug 14, 2019 at 2:11 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    I mounted strut on top of my bed rails.
    Under the bed mat I some rust. I cleaned it up and coated it but it was weaker and looked bad.
    It was great having all the tie down points.
    Then I got a neeting that hooked across it and it worked great for camping trips.
    Then I was having problems with sticky fingers so I cut 3/4 plywood and slid it in the strut to make a heavy duty cover. I could set my camp right up on top of it and have gear strapped above and below.
    Now im building an offroad camper and I left it as my base.
    tacoma_ca and Wulf like this.
  6. Aug 14, 2019 at 2:18 PM
    970btu
    Ty
    Las Vegas
    Some will hate it but for me it's the function.
  7. Aug 14, 2019 at 3:59 PM
    Natenite
    Springfield Mo
    This is interesting. I have a camper shell
    So I can’t do it this way though. I would assume if it’s strong enough to put in the top is should be strong enough to hang on the inside just below where you did. I only want to mount stuff like a shovel and maybe a hi lift if I ever get one. Thanks for showing this!
    970btu[QUOTED] and Wulf like this.
  8. Aug 14, 2019 at 5:59 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Unistrut is plenty stout for attaching just about anything. I would expect to the weak points to be the bed rail or however it is attached to the bed rail
    970btu and jbrandt like this.
  9. Aug 15, 2019 at 7:36 PM
    970btu
    Ty
    Las Vegas
    Wulf is right, much stronger than the bed its mounted to.
    2 most common sizes,
    1 5/8x 1 5/8 the deep or
    1 5/8 x 7/8 the shallow
    Galvanized coating or painted
    You can get it in 12 or 14 gage
    even aluminum from Granger supply.
    Lowe's and home depot carry it but is usually cheaper from an electrical supply company.
    There are a ton of mounting accessories and brackets, bolt and nut combinations for them.
    The grown up erector set.
  10. Aug 16, 2019 at 10:14 AM
    Natenite
    Springfield Mo
    I was able to mount a bit of unistrut in the bed. Added some cone nuts and quick fists and created a sliding shovel mount. Allows me to get the shovel out without having to get into my campershell covered bed. Not perfect but I think it’s gonna work. Not bad for my first mod. Couldn’t find anything similar so I had to wing it. I’m sure there are ways to improve it but I’m not that smart.
    970btu likes this.
  11. Aug 16, 2019 at 10:30 AM
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Here are mine:
    The mounts slide on and off and I have seen accessories for them. I wouldn't trust them for a ton of weight but they would 100% hold a shovel.
    Area51Runner likes this.
  12. Aug 16, 2019 at 5:14 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    This is awesome. Great ideas. On my to do list for sure.
  13. Aug 16, 2019 at 7:42 PM
    Natenite
    Springfield Mo
    B11FC084-B701-4AD6-BA2C-85FFE974646F.jpg E17E42F1-7726-4441-AEEF-2C4ABB2B5944.jpg 75829EF1-8AA2-44C7-82AF-2682D9830343.jpg
    CSC, 970btu and Wulf like this.
  14. Feb 29, 2020 at 10:00 PM
    CSC
    CSC Well-Known Member
    Craig
    Grand Canyon, AZ
    1999 Tacoma TRD
    This is just what I’ve been looking for! Got the Quickfist, just need the Unistrut and accessory parts. Can you tell me exactly what you used to connect the quickfist to the Unistrut? Cone nuts and square washers between the strut and quickfist? Did you have to drill out the quickfist to use a larger mounting bolt? Thanks for your help!
    970btu likes this.
  15. Mar 1, 2020 at 11:57 AM
    Natenite
    Springfield Mo
    Yeah I sued the 3/8 inch cone nuts. I think that’s what they called it. I drilled out the hole in the quick fist a bit, didn’t need much. Ran bolt straight into the first and spin the whole fist into the nut. I keep it loose so it slides but you can snug it up for a more fixed mount.
  16. Mar 1, 2020 at 12:02 PM
    CSC
    Craig
    Grand Canyon, AZ
    1999 Tacoma TRD
    Many thanks Natenite!
  17. Mar 1, 2020 at 2:13 PM
    Natenite
    Springfield Mo
    Your welcome. Glad it helped someone. Super simple so you should have no problems.
  18. Mar 1, 2020 at 4:32 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    I suggest staying away from using this section of the bed as a secure point for these items. Over time, the attach points will be come weak and fail.
    Might I suggest looking at USCargo for secure hold down ideas.
  19. May 29, 2020 at 11:47 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I just built a support rack for my bed shell the floor of my truck with unistrut pretty damn stout. I haven’t tested it yet but I think the shell will fail way before the unistrut will. I tied it directly into the rails of my shell with 5/16 grade 8 bolts then my prinsu rack Goes onto the rains putting all the pressure on the legs mounted to the bed.
  20. May 29, 2020 at 1:30 PM
    Glamisman
    Glamisman Well-Known Member
    I have used the factory captured nuts that are for the tie downs at the front and back of the bed.
