Uniball or ball joint UCA's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by samizman, Mar 8, 2019.
  1. Mar 8, 2019 at 11:09 PM
    samizman
    samizman [OP] Active Member
    2001 Tacoma SR5 4x4
    Bilstein 5100's with OME 881 springs in the front, trail gear add a leaf spring, K&N polumer cold air intake, and Walker exhuast with muffler delete with Denso sensors, (no check engine light) . Cooper all terrains stock size. 21.2 mpgs and I drive a little crazy lol.
    So I'm wanting/needing new UCA's, I live in PHX, AZ so its a dry climate where rust isnt really an issue. Im looking at TC's, Camburg, JBA, and Icon. Would the uniball be the better choice since Im in a desert climate and rust and crap arent a big deal, or should I go with the ball joint and not have to even worry about it. Professional advice and personal experiences please!
  2. Mar 9, 2019 at 4:57 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Who do you think we are.. professional?..... :rofl:
    Anyway if you live in AZ I’d say it’s preference. If use uniballs make sure to keep them clean if using ball joint make sure to grease them as advised in owners info. Do what you want. I have ball joint since I’m in salt belt.
  3. Mar 9, 2019 at 8:25 AM
    samizman
    2001 Tacoma SR5 4x4
    Lol a lot of people in here have wild opinions that end up talking about completely different shit, thanks for the input!
    DW85 likes this.
  4. Mar 9, 2019 at 9:15 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I just installed TC UCA’s and my truck rides so much better. I figured I’d see a big difference when I installed my FOX 2.0’s and I was honestly more impressed with changing out my UCA’s than my shocks. If your going to lift your truck than the UCA’s will definitely make a difference. If you have the extra money, I’d do it! :thumbsup:
  5. Mar 9, 2019 at 9:24 AM
    samizman
    2001 Tacoma SR5 4x4
    Thanks Joe! That's definitely good hear! I put on the Bilstein 5100 lift last year and it feels like it's definitely lacking something, hopefully this will fix it! Did you get the uerthane or the Heim joints?
  6. Mar 9, 2019 at 10:00 AM
    F250orelse
    F250orelse Well-Known Member
    Michael
    Arkansas
    2022 Tacoma double cab trd 4x4
    ome 886 springs-shocks suspension, bfg’s 285’s. Camburg uca
    I recently installed the camburg uniballs, if you off-road your truck just slightly like I do you will need to clean them and lube them regularly. But I like them so far.
    samizman[OP] likes this.
  7. Mar 9, 2019 at 10:05 AM
    QMEDJoe
    Joe
    I got the urethanes. I figured the heim’s would have been overkill.
    samizman[QUOTED][OP] likes this.
  8. Mar 9, 2019 at 10:07 AM
    samizman
    2001 Tacoma SR5 4x4
    Nice, how long have you had them?
  9. Mar 9, 2019 at 10:08 AM
    QMEDJoe
    Joe
    Also, if you go with Total Chaos, mine squeak a little because the installers torqued them to spec and I’ve read that some people dial it back a little bit to stop the squeaking. I don’t have a torque wrench so I’ve been just dealing with it. Not sure if this is a problem with all of them with the urethane bushings?
  10. Mar 9, 2019 at 10:10 AM
    QMEDJoe
    Joe
    Probably about 6 months. I was pleasantly surprised in how she handles off-roading that much better. I’m maxed out on my Fox 2.0’s and that causes some stiffness (from what I’ve read) but this definitely smoothed things out a bit.
  11. Mar 9, 2019 at 10:14 AM
    samizman
    2001 Tacoma SR5 4x4
    That's good to know, I'll be installing them myself so I'll be able to mess with it, if I do go with the TC's (which I'm thinking I am) I'll make a thread and hopefully find the squeak free torque value
    QMEDJoe likes this.
  12. Mar 9, 2019 at 11:05 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    Total Chaos has a youtube video about the proper way to lube the joints so that they don't squeek,
    I was just looking at it today...
    -Mike
    yote, samizman[OP] and QMEDJoe like this.
  13. Mar 9, 2019 at 4:17 PM
    samizman
    2001 Tacoma SR5 4x4
    Is it on their web page?
  14. Mar 9, 2019 at 6:16 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    JBA seems to be great for the price.
  15. Mar 10, 2019 at 4:43 AM
    hubcapsc
    Here's the one I was thinking of: https://www.youtube.com/watch?v=xvMdAX2uybs
    It boils down to: loosen the bolts at the bushings before you put in the grease or you'll
    end up with deformed bushings. If you've pumped in grease without loosening the bolts
    and your bushings aren't bad yet, the video shows how to release the pressure by holding
    down the valve in the zerk so the grease can spurt back out...
    -Mike
  16. Mar 10, 2019 at 7:59 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    No squeaking here just went liberal with good grease on the uerethane and just use wax for the uniballs and you’ll Never have issues.
    samizman[OP] and QMEDJoe[QUOTED] like this.
  17. Mar 10, 2019 at 8:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I would say that if you aren't beating the hell out of the truck, unis aren't necessary at all. Being in a drier salt free environment makes it easier to go that route if you choose, but BJs are perfectly fine for most people.
    I have TC's 1) "because I could" 2) I have mid travel Kings, so I wanted a little extra flex, too. 3) I won't be racing KOH, but I won't exactly be armoralling the tires, either, lol...
    Just spray them with some teflon lube every once in a while if they start squeaking. Mine haven't squeaked once yet.
    They're easy to install, I had my son do it, lol:
  18. Mar 12, 2019 at 4:54 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    I went with Total Chaos uni-ball upper A-arm and Donahoe coil-overs
  19. Mar 12, 2019 at 7:35 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Do the Uniballs! I’m running the MCM Fab LT kit which has upper uniball. Been on the truck for almost 2 years. I’m in Southern AZ as well.
  20. Mar 12, 2019 at 7:41 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Just to be different, I went with SPC UCAs that have an actual ball joint. Have yet to install them tho.
    Adude likes this.
