Uneven headlight beam width
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasonb02, Dec 30, 2022.
  1. Dec 30, 2022 at 4:01 PM
    jasonb02
    jasonb02 [OP] Member
    15 Tacoma SR5 2.7L Manual 4x4
    Boss audio apple CarPlay head unit, k&N drop in air filter, cali raised led pod light fog lights, ultra gauge
    2ACD9B2B-7B9A-49C3-9602-D518A24307A6.jpg So first off for all of the don’t put led’s in reflective housing haters, I’m not blinding anyone. I’ve properly adjusted my headlights down enough that I have not once been high beamed. Getting to the problem, my beam pattern width is not symmetrical as pictured. The bulbs are lasfit H4 9003 https://www.lasfit.com/products/h4-...-led-tail-lights~dz_low-high-forward-lighting
    What I’ve done so far:
    -Messed with the horizontal adjustment screw, doesn’t seem to make any difference. I went lock to lock and nothing changed.
    -swapped my driver side bulb with the passenger side, no difference.
    -twisted the bulb in the hold down device or clip, no difference in width.
    Not really sure what else I can do. If anyone has any info or suggestions it would be greatly appreciated, thank you!
  2. Dec 30, 2022 at 4:48 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    The bulbs are the problem and are they OEM headlight units?
  3. Dec 30, 2022 at 4:54 PM
    jasonb02
    Yes they are factory headlight assemblies. Is there a different bulb you would recommend, something brighter than factory?
  4. Dec 30, 2022 at 5:00 PM
    TegoTaco
    Ontario, Canada
  5. Dec 30, 2022 at 5:10 PM
    jasonb02
  6. Dec 30, 2022 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's the housings,. Not designed for LEDs. As you've found out.
    Go back to the 'clever' thread. You'll find at least 3 combinations you can build with as your budget allows
    b_r_o, ace96 and AJKlug1 like this.
  7. Dec 30, 2022 at 5:34 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note how there is the light above the hot spot “cut off”. That is glare that is blinding to other drivers. Lasfit makes terrible LED products, definitely not recommended. But to answer your question, you have the bulbs positioned correctly as easily indicated by your pattern. The issue is the bulbs.
    I’d suggest the Philips Racing Visions for best plug and play low beam which will offer a good increase in performance over stock and be substantially better than those LEDs.
    See updated +200 review
    Tungsram Platinums will offer better high beam, but the low beam will not be as good as Racing Visions.
    ace96 likes this.
  8. Dec 30, 2022 at 5:44 PM
    jasonb02
    I went back and read through, and I’m not interested in installing a harness and pulling the whole front clip apart. I do think I will try the Phillips racing vision bulbs instead of the leds.
    crashnburn80 likes this.
  9. Dec 30, 2022 at 5:46 PM
    jasonb02
    I saw these bulbs recommended in the ultimate headlight upgrade thread also. I think these are some halogens I can get with. I plan to try these out, thanks!
    crashnburn80[QUOTED] likes this.
  10. Dec 30, 2022 at 7:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    Well I said you had 3 options in that thread. You picked. #1.
    Did you notice he was the author of the thread? :D
    ace96 likes this.
  11. Dec 30, 2022 at 7:39 PM
    jasonb02
    Yes, I will admit I didn’t fully comprehend all of the instructions at first. After going back I realized there were some options other than installing a heavier duty harness. Also, I did not realize crashburn80 was the author of the post, very nice of him to chime in, thank you.
