Undercoating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Colt357, Mar 1, 2022.
  1. Mar 1, 2022 at 8:34 AM
    Colt357
    Colt357 [OP] Member
    al
    2015 tacoma
    What is the best product to use for general undercoating. I have heard Krown, Fluid film, Pro 15 and so many more. Can anyone suggest the best for a DIY?
    Thanks
  2. Mar 1, 2022 at 8:44 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  3. Mar 1, 2022 at 8:53 AM
    Colt357
    Colt357 [OP] Member
    al
    2015 tacoma
    thanks rustygreen
    RustyGreen likes this.
  4. Mar 1, 2022 at 9:10 AM
    15yrstacoma
    15yrstacoma Member
    ed
    22 sr blk
    none
    About how many cans to do a thorough job?
  5. Mar 1, 2022 at 9:14 AM
    Colt357
    Colt357 [OP] Member
    al
    2015 tacoma
    I just went to rustygreens attachment and it gives you a chart and information on how many cans you will need.
  6. Mar 1, 2022 at 9:18 AM
    15yrstacoma
    15yrstacoma Member
    ed
    22 sr blk
    none
    Yes,found it,thanks.
  7. Mar 1, 2022 at 9:22 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Recently had Krown do mine (prior to winter).
    They did an excellent job and walked me through all my questions and concerns. They will put your truck on a lift and spray every nook and cranny.
  8. Mar 1, 2022 at 9:27 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Woolwax (thicker fluid film)
    wi_taco likes this.
  9. Mar 1, 2022 at 5:51 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I've used Woolwax, Fluid Film, RP-342, and Eastwoods' cosmoline over the years. I would not recommend anything that dries hard.
    I have a bulk sprayer, but if you don't have access to a lift like me I find the aerosol spray cans with the two-foot 360-degree tip easier to use when you're on your back with a mechanics creeper.
  10. Mar 1, 2022 at 6:07 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I like to do mine when it's really hot out. I'll start with something thick like Fluid Film then follow up with something a little thinner to help wick the thicker stuff into the sandwiched parts of the frame. I also spray up into the weep holes in the pinch seam at the bottom of the rockers and cab corners. Then, I spray up into the drainage holes in my doors. I also spray up into the box sides and front fenders above the wheel and let it run down into the fender behind the flares.
    When it's really hot out, I'll even get little trails of oil up the outsides of my doors. That tells me it's creeping up into the doors as well.
    I've even removed the inner panel of my tailgate and sprayed well in there. You can just spray into the drain holes there. If your body panels are going to rust, it will start at the seams in the bottom where the two layers are rolled together.
    My truck is a 2014 and it it pretty much rust free.
    Get it up on ramps or jack stands as high as you can, just be safe! And wear eye protection. Some type of N95 mask would be a good idea too. The stuff doesn't taste good...
    Jbjamn likes this.
  11. Mar 1, 2022 at 6:12 PM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Took 9 cans for me and I went overkill.
    Chose cosmoline because i don’t want to apply it yearly like you have to with FF and WW
    Why not?
  12. Mar 1, 2022 at 6:18 PM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    Anything that dries hard will eventually crack and then trap moisture against the metal, making rust even worse. Unless you're coating the dried stuff with something like Fluid Film, but that defeats the point of having it in the first place.
  13. Mar 1, 2022 at 6:23 PM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Ahh I understand. I wouldn’t think cosmoline would crack but I’ve only used it for one year so far. Have u seen it eventually crack? I know rubberized coatings are notorious for cracking
  14. Mar 1, 2022 at 6:25 PM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Hey OP, this should help you make your decision. And welcome to TW!
    https://youtu.be/oXlhmbvdKBo
  15. Mar 1, 2022 at 6:26 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Broadly speaking these these products fall into 3 categories: waxy, oily and rubbery/asphalt -- all are available in standard aerosol cans. To prevent rust you need a barrier between the steel and the enemies: moisture and oxygen, all the products attempt to achieve this.
    Waxy: Ex: Cosmoline, sprays on as a thin, penetrating liquid and dries to a soft, pliant barrier that is fairly difficult for road debris to scrape off. Since these products don't set hard like paint they don't chip and are said to be able to "self heal" some if scuffed. These are the longest lasting products.
    Oily: Ex: Fluid Film, very similar to coating the bottom of the truck with engine oil, the advantage is that they are very good at creeping in to seams and hard to access areas. The disadvantages are they make a mess under the truck, you can't touch anything under there without getting filthy between the oil and the dirt it holds. These products do wash away over time and need to be reapplied every Fall.
    Rubbery/Asphalt: Ex: Parts store undercoat spray, these products are typically thicker and provide sound deadening, many older cars (1960's-80's) had the asphalt style of undercoat from the factory. The high solvent formulas of the day were very durable.
    These products set from very firm to hard and here lies the problem -- they crack and chip. This allows moisture in with no way to escape, everything looks fine until the bond is so compromised that a big chunk falls off and reveals the damage that was cooking behind it. Stay away from these products and never buy a used vehicle with a nice fresh undercoat job either, they did that for hiding not protection.
    This is a great video on the topic, this fellow does a lot of product testing without bias, he does not accept anything from manufacturers, purchases everything himself.
    https://www.youtube.com/watch?v=lyWHF4NoNVk&t=3s
    boston23 likes this.
  16. Mar 1, 2022 at 6:26 PM
    DeuceDeuceBravo
    New England
    Cosmoline stays mostly viscous. Good stuff.
    boston23[QUOTED] likes this.
  17. Mar 1, 2022 at 6:27 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Cosmoline doesn't set hard, it remains pliant -- it won't crack.
  18. Mar 1, 2022 at 8:40 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Woolwax. I've used it myself now for 2 years and it's great stuff. @bob1008 is a member here on TW too!
    https://www.tacomaworld.com/threads...ves-to-fluid-film.466404/page-6#post-26529879
  19. Mar 1, 2022 at 9:10 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    I plan to give New Hampshire Oil Undercoating a try this spring as we have a NHOU dealer in western MT. AMD, "The Car Care Nut" YouTube channel, a Toyota Master Diagnostic Technician who works at home with his wife as videographer, in addition to his day job at a Chicagoland rust belt Toyota dealership, responded to my chat during a Saturday live stream that the plan for rustproofing the frame is highly recommended because "Toyota trucks need it!" The other Toyota/Lexus vehicles are pretty well sealed and protected with plastic. That channel is a great reference, with two playlists on the Tacoma, and more on various systems and maintenance.
  20. Mar 2, 2022 at 1:30 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    This guy is great I watch alot of his reviews
